[ ROM ] FNF iFive X2 Android 4.4.2 KitKat custom rooted firmware based on v2.0.0 (2014/01/08)
FlowDesign
Forum Posts: 23
91
2014/01/13 - 21:05
And there I was thinking I was having no glitches... I was wrong.
My tablet was lying somewhere all day doing nothing for hours after I had switched it back on this morning and when I took it and pushed the on button...boom, total glitch stuff in the unlock screen. I couldn't even unlock it and after a few times trying to it totally shut down and I had to reboot the thing. After that everything was fine again.
So, conclusion: I guess there's a memory leak in the display driver that has to be fixed.
For comparison:
Read 23.78 MB/s Write 17.43 MB/s on Kasty 4.4.2
Compizfox
Forum Posts: 24
92
2014/01/13 - 21:20
For comparison:
I almost forgot to mention, but I had that too! It was like the first time I booted up the tablet after flashing to this ROM. I got those (pretty severe) distortion/artifacts, but in the unlock screen only. After rebooting it was fine again and I've never seen it again so far.
bklm1234
Forum Posts: 44
Thanks Received: 11
93
2014/01/13 - 21:50
bklm1234 said
This Rom is so good. However I found that it doesn't support ntfs write and it doesn't read exfat formatted microsd. I really like to have >4g file support back cause I want to watch 1080p videos on it, which are mostly > 4g. It can read ntfs, but just can't write to ntfs. It means I can't do use the microsd to do titanium backup.
Kasty, can you add ntfs write support or full exfat support?
Problem solved. Installed SELinux Mode Changer app, chose Permissive mode. I can now write to ntfs.
FlowDesign
Forum Posts: 23
94
2014/01/14 - 00:14
I just had some funny glitches again whil scrolling Google search results in Chrome browser.
Maybe we have to twiddle a bit with the ro.hwui settings in build.prop since these seem to control Android's 2D hardware accelerated rendering pipeline.
http://source.android.com/devices/tuning.html
Can someone please post the build.prop file from a 4.2 ROM ?
Lafetoo
95
2014/01/14 - 00:22
How come you guy have such good read write speed, I bought mine in less than a month ( running kasty 1.20) but only get 11ish read and 7ish write, are there any difference between fresh clean system (minimal apps) and fully loaded system?
Compizfox
Forum Posts: 24
96
2014/01/14 - 00:43
I did some tests with different I/O schedulers:
CFQ      Read 24,31 MB/s, Write 12,71 MB/s
NOOP    Read 23,69 MB/s, Write 15,21 MB/s
Deadline Read 24,73 MB/s, Write 14,92 MB/s
You can see NOOP and Deadline perform substantially better than CFQ. The difference between NOOP and Deadline however is negligible.
xZeRox
97
2014/01/14 - 04:22
xZeRox said
Hello everyone
i installed the KitKat room yesterday and everything is just perfect and i havent had any problems with it so far except one :
i tried to connect a USB 3G Doungle and i can see the Doungle flashing blue but when i try going to settings and put the APN settings and such as .. the tablet doesnt save the settings no matter what i do .. can anyone try doing the same and see how it goes .. thanks in advance :)
anyone ?
Lafetoo
98
2014/01/14 - 05:10
Anyone here notice that the display quality pf the 4.4 version not as good as the 4.2.2?
Is this related to the display driver?
TecKnight
Las Vegas, NV
Forum Posts: 91
Thanks Received: 20
99
2014/01/14 - 07:51
build.prop from kitkat
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=JDQ39
ro.build.display.id=rk30sdk-eng 4.2.2 JDQ39 eng.root.20130916.144023 test-keys
ro.build.version.incremental=eng.root.20130916.144023
ro.build.version.sdk=17
ro.build.version.codename=REL
ro.build.version.release=4.2.2
ro.build.date=2013年 09月 16日 星期一 14:44:59 CST
ro.build.date.utc=1379313899
ro.build.type=eng
ro.build.user=root
ro.build.host=five-server2
ro.build.tags=test-keys
ro.product.model=ifiveX2
ro.product.brand=IFive
ro.product.name=rk30sdk
ro.product.device=rk30sdk
ro.product.board=rk30sdk
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=IFive
ro.product.locale.language=zh
ro.product.locale.region=CN
ro.wifi.channels=
ro.board.platform=rk30xx
# ro.build.product is obsolete; use ro.product.device
ro.build.product=rk30sdk
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=rk30sdk-eng 4.2.2 JDQ39 eng.root.20130916.144023 test-keys
ro.build.fingerprint=IFive/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130916.144023:eng/opinions-on-teclast-p90hdst-keys
ro.build.characteristics=tablet
# end build properties
# system.prop
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyUSB2
# Default ecclist
ro.ril.ecclist=112,911
# ADDITIONAL_BUILD_PROPERTIES
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
dalvik.vm.heapstartsize=16m
dalvik.vm.heapgrowthlimit=192m
dalvik.vm.heapsize=512m
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.heapminfree=512k
dalvik.vm.heapmaxfree=8m
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.hwui.texture_cache_size=72
ro.hwui.layer_cache_size=48
ro.hwui.path_cache_size=16
ro.hwui.shape_cache_size=4
ro.hwui.gradient_cache_size=1
ro.hwui.drop_shadow_cache_size=6
ro.hwui.texture_cache_flush_rate=0.4
ro.hwui.text_small_cache_width=1024
ro.hwui.text_small_cache_height=1024
ro.hwui.text_large_cache_width=2048
ro.hwui.text_large_cache_height=1024
ro.hwui.disable_scissor_opt=true
persist.sys.ui.hw=true
ro.config.facelock=enable_facelock
persist.facelock.detect_cutoff=5000
persist.facelock.recog_cutoff=5000
ro.sf.lcdc_composer=1
keyguard.no_require_sim=true
ro.com.android.dataroaming=true
ril.function.dataonly=0
persist.sys.strictmode.visual=false
dalvik.vm.jniopts=warnonly
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
sys.hwc.compose_policy=6
sys.wallpaper.rgb565=0
sf.power.control=2073600
sys.rkadb.root=0
ro.sf.fakerotation=true
ro.sf.hwrotation=270
ro.rk.MassStorage=false
ro.rk.systembar.voiceicon=false
ro.rk.systembar.tabletUI=true
wifi.interface=wlan0
ro.tether.denied=false
ro.sf.lcd_density=240
ro.rk.screenoff_time=60000
ro.rk.def_brightness=150
ro.rk.homepage_base=http://www.ifive.com.cn
ro.rk.install_non_market_apps=false
ro.rk.hdmi=true
ro.rk.vibrator=true
ro.rk.3g=false
ro.rk.gps=false
ro.rk.autobrightness=true
ro.default.size=100
persist.sys.timezone=Asia/Shanghai
ro.product.usbfactory=ifive
wifi.supplicant_scan_interval=15
ro.opengles.version=131072
ro.factory.tool=0
ro.kernel.android.checkjni=1
ro.rk.bt_enable=true
ro.factory.storage_policy=0
persist.sys.usb.config=mass_storage
testing.mediascanner.skiplist=/mnt/sdcard/Android/
ro.product.version=1.2.0
ro.product.ota.host=115.28.50.95:2300
net.bt.name=Android
build.prop from 4.2.2
ro.build.id=JDQ39
ro.build.type=eng
ro.build.user=root
ro.product.locale.language=en
ro.product.locale.region=GB
ro.wifi.channels=
# system.prop
# Default ecclist
ro.carrier=unknown
sys.rkadb.root=0
ro.rk.hdmi=true
ro.rk.vibrator=true
ro.rk.3g=false
ro.rk.gps=false
ro.default.size=100
persist.sys.timezone=Europe/London
wifi.supplicant_scan_interval=180
ro.factory.tool=0
ro.kernel.android.checkjni=0
#ro.product.ota.host=115.28.50.95:2300
ro.product.ota.host=localhost:2300
net.bt.name=Android
TecKnight
Las Vegas, NV
Forum Posts: 91
Thanks Received: 20
100
2014/01/14 - 08:15
I just checked iFive's forum (translated) and they are reporting the same issues on ifive X2 4.4.2 V2.0.0 firmware. Here are some of the comments (translated from chinese):
It seems that there is some problem, so painted!
Report Props
Reply Support Opposition
35 #
poe Bronze 5 Posted 4 days ago | Show This Author
Can firmware update 4.4 to win8.1 the way to send a driver ah?? Else how to brush ah
Report Props
36 #
Aescinate concentric grass platinum small 5 Posted 4 days ago | Show This Author
How about 4.4, said brush under
Report Props
37 #
hz150 Moderator Posted 4 days ago from Mobile | Show This Author
Greatly, some reactions can not find the SD card, root difficulty flash back your own software problems
Comments
yzak
It seems that the next version, such as cough  Posted 4 days ago
Report Props
38 #
a86402534 small platinum 5 Posted 4 days ago | Show This Author
Sure enough, I guess right to say what really is the mentality 2S of X2. . .
Report Props
39 #
hz150 Moderator Posted 4 days ago | Show This Author
084307120 Posted at 2014-1-10 09:10
look great God of the card brush version
You're signing, said get in space
Report Props
40 #
291,036,368 silver small 5 Posted 4 days ago | Show This Author
Certain probability ghosting
Posted at 2014-1-10 12:16 Vulcan king
after power has been automatically double shadow, it is simply impossible to turn off and then turn on the screen, will be good for a while, and then continue to double image, reboot is useless, I decisive brush back ...
badbi3 Posted at 2014-1-11 20:46
I was ghosting, reset or so later. Wait and see there is no solution, it is impossible to brush back
Automatic boot after been double shadow, it is simply impossible to turn off the screen and then turn, will be good for a while, and then continue to double image, reboot is useless, I determined to brush back ...
This indicates the issue is present in the original ROM, so it is very likely not even possible for kasty to fix.
bjorndell
101
2014/01/14 - 09:39
ro.build.id=JDQ39
ro.build.type=eng
ro.build.user=root
ro.wifi.channels=
# system.prop
# Default ecclist
ro.carrier=unknown
sys.rkadb.root=0
ro.rk.hdmi=true
ro.rk.vibrator=true
ro.rk.3g=false
ro.rk.gps=false
ro.default.size=100
ro.factory.tool=0
net.bt.name=Android
ro.build.id=JDQ39
ro.build.type=eng
ro.build.user=root
ro.wifi.channels=
# system.prop
# Default ecclist
ro.carrier=unknown
sys.rkadb.root=0
ro.rk.hdmi=true
ro.rk.vibrator=true
ro.rk.3g=false
ro.rk.gps=false
ro.default.size=100
ro.factory.tool=0
net.bt.name=Android
Not much of a difference
-sh-3.2$ diff kitkat 422
23,24c23,24
< ro.product.locale.language=zh
< ro.product.locale.region=CN
103c103
< persist.sys.timezone=Asia/Shanghai
105c105
< wifi.supplicant_scan_interval=15
108c108
< ro.kernel.android.checkjni=1
114c114,115
< ro.product.ota.host=115.28.50.95:2300
TecKnight
Las Vegas, NV
Forum Posts: 91
Thanks Received: 20
102
2014/01/14 - 12:40
Flowdesign, just an FYI.
I tried mucking around with a number of those settings and found that a number of them put my tablet into a boot loop. I then had to restore the old build.prop via adb then reboot.
Thanks Received: 3169
103
2014/01/14 - 13:32
Just to confirm that our modifications to the stock firmware are always very conservative and should not bring glitches such as the ones reported in this topic, these are definitely an issue from the manufacturer firmware.
Also, I have posted a minor custom firmware update, see post #1:
  • Edit 2014/01/14: updated SuperSU to latest version 1.89 (free version)
  • Edit 2014/01/14: added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
  • Edit 2014/01/14: use optional package to fix broken apps (Contacts/People and Calendar sync)
Download: kasty-fnf_ifive_x2-442-200_20140108-rooted4c.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
--Holger_p--, Compizfox
FlowDesign
Forum Posts: 23
104
2014/01/14 - 14:36
I've changed some ro.hwui items too but mine boots just fine.
Although it doesn't seem to make any difference at all for the screen.
I'm thinking it must be a GPU (Mali-400) driver thingy and not the screen itself, because on a FullHD TV connected over HDMI I see exactly the same gliches (for instance when scrolling text in Chrome).
FlowDesign
Forum Posts: 23
105
2014/01/14 - 14:43
ro.build.id=JDQ39
You've posted a 4.2.2 build.prop twice, not 4.4.2 😉
94 Guest(s)
Devices in use: Desktop (89), Phone (5)
kepew69619
axelorban
yisidin858
panchaud
ionmih83
brau10g21234
