2013/11/28
bjorndell said
ÂHi!
Does  anybody experience graphicproblems with this new rom?
After flash everything seems good but when doing something like open a browser or Play store the glitches begin and after a couple of glithes the whole screen seems offset, ive attached a photo of it. See below link.
 https://www.dropbox.com/s/5jyysss2jwbntpj/ifivex2_glitch.jpg
One way to redeem the problem is to lock the tablett (using power button) and unlock it. Then everything is back to normal for a few minutes. Then the graphicglitches starts again.Â
I have tried to reflash but with the same issues.
Any ideas?
Have same glitch effect in browser or play store. But it very stange it not appears when playing 3D games (GTA SA or Dungeon Hunter 4)
2014/01/01
bach0405 said
Hi,Thanks for this firmware
Antutu result between 21,4 and 21,7 k with overclocked kernel. First, I didn't have the calendar sync, so I had to put the relevant apk in system/app with adapted authorizations.
I found out the same thing goed for the Contacts apk. It wasn't visible, then I saw in Titanium Backup it was frozen, so I clicked Defrost. Then it was available, but I still can't sync my contacts with Google...Â
What do you mean with "with adapted authorizations" ?
2014/01/01
Ched666 said
bjorndell said
ÂHi!
Any ideas?
Maybe turn on or off HW Overlay (in Developer options) ?
2013/09/11
FlowDesign said
Ched666 said
bjorndell said
ÂHi!
Any ideas?
I have tried that but without luck.
2012/10/11
FlowDesign said
Ched666 said
bjorndell said
ÂHi!
Any ideas?
I added GooglecalendarSyncadapter.apk and googlecontactssyncadapter.apk in system/app from another rom. By fixing the authorizations, the files have to be changed to rw-r--r--
Cheers
bach0405,
Sorry for the forum issues, it is acting strange lately and I am having hard time fixing all the bugs on the forum software.
About the two  apk you added (GooglecalendarSyncadapter.apk and googlecontactssyncadapter.apk) could you tell me on which tablet and firmware you extract those ? Do you have a download link for the files so I can include them in next X2 firmware rebuild.
2012/11/04
I installed this ROM as well and so far I have had no graphic glitches whatsoever. I have installed a ton of stuff from Google Play. One thing I did (and I always do this on rooted ROMs), is I installed and ran Busybox Installer by Jrummy Apps, inc. This uninstalls the installed busybox binary and then downloads and installs the latest busybox binary. It also symlinks the installed busybox. I do this with any new rooted ROM as a kind of litmus test to confirm I have root. I don't know if this has anything to do with my lack of glitches, however.
I have noticed a couple of minor issues. The mount points must not be standard as I noticed when I set the screen capture to save to my sdcard, I get an error when trying to do a screenshot.
MX Video Player will not play any of my videos in HW+ mode. MX player played all my videos in HW+ mode on all the 4.2 ROMs.
2014/01/11
Hello everyoneÂ
i installed the KitKat room yesterday and everything is just perfect and i havent had any problems with it so far except one :
i tried to connect a USB 3G Doungle and i can see the Doungle flashing blue but when i try going to settings and put the APN settings and such as .. the tablet doesnt save the settings no matter what i do .. can anyone try doing the same and see how it goes .. thanks in advance
2014/01/01
FlowDesign said
bach0405 said Hi, Thanks for this firmware Antutu result between 21,4 and 21,7 k with overclocked kernel. First, I didn't have the calendar sync, so I had to put the relevant apk in system/app with adapted authorizations.
I found out the same thing goed for the Contacts apk. It wasn't visible, then I saw in Titanium Backup it was frozen, so I clicked Defrost. Then it was available, but I still can't sync my contacts with Google...  What do you mean with "with adapted authorizations" ?
FlowDesign said
Ched666 said
bjorndell said  Hi!   Does  anybody experience graphicproblems with this new rom?  After flash everything seems good but when doing something like open a browser or Play store the glitches begin and after a couple of glithes the whole screen seems offset, ive attached a photo of it. See below link.  https://www.dropbox.com/s/5jyysss2jwbntpj/ifivex2_glitch.jpg One way to redeem the problem is to lock the tablett (using power button) and unlock it. Then everything is back to normal for a few minutes. Then the graphicglitches starts again.  I have tried to reflash but with the same issues.  Any ideas?
I added GooglecalendarSyncadapter.apk and googlecontactssyncadapter.apk in system/app from another rom. By fixing the authorizations, the files have to be changed to rw-r--r-- Â Cheers
Funny thing... I installed Google Calendar from the Play Store and that synces my calendar with Google without any problems whatsover... also I see 'Calendar' under Settings>Accounts>MyGoogleAccountName. But in System/app I don't have a GooglecalendarSyncadapter.apk.
I copied and installed the GooglecalendarSyncadapter.apk from my phone but that's from Android 4.2. It shows up under the Google account settings, but it won't sync and causes a com.google.process.gapps has stopped error.
So I've downloaded the 4.4.2. gapps (Slim_minimal_gapps.4.4.2.beta.1.x) from Slimroms.net, unzipped and copied GoogleContactsSyncAdapter.apk to System/app, installed the apk and now my contacts sync as well 🙂Â
Another thing:Â
Of course I've set it to use ART instead of Dalvik. But everytime I boot the tablet, it says Google is optimizing apps (but only the twenty something apps I've installed myself).Â
How do I get rid of this?
2014/01/09
FlowDesign said
Another thing:Â
I get this too, but it doesn't bother me that much. I guess it is compiling the apps over again, dunno if that's normal.
@admin: Have you seen my previous posts? If you have time, could you please answer my questions? Thanks
2013/07/10
This Rom is so good. However I found that it doesn't support ntfs write and it doesn't read exfat formatted microsd. I really like to have >4g file support back cause I want to watch 1080p videos on it, which are mostly > 4g. It can read ntfs, but just can't write to ntfs. It means I can't do use the microsd to do titanium backup.
Kasty, can you add ntfs write support or full exfat support?
Currently Online: 2256667898, mogabi
83 Guest(s)
Devices in use: Desktop (74), Phone (11)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
