[ ROM ] FNF iFive X2 Android 4.4.2 KitKat custom rooted firmware based on v2.0.0 (2014/01/08)
--Holger_p--
Forum Posts: 19
46
2014/01/11 - 11:02
Of course you need the Rockchip drivers. How did you rooth your x2 without drivers? (I ask, because i have trouble with rooting another rk3188 device)
This is a good introduction how to install drivers: http://www.cnx-software.com/2013/11/08/simplified-method-to-install-rockchip-usb-drivers-in-windows-xp78/
Unzipping the zip file is no problem. I use 7zip and there is nor warning or so.
makso
47
2014/01/11 - 13:25
Thank man really help
I installed the drivers, how do I continue from here ?
Written
Use Rockchip Batch Tool flash the firmware, use Restore button
I turn off the iFive X2 ?
Using the shutdown button and volume up?
in Rockchip Batch Tool
I go to the file extracted in
Folder ?
Need some guidanceConfused
--Holger_p--
Forum Posts: 19
48
2014/01/11 - 13:32
After installing the driver and the Rockchip Tool you ca go several ways. The easiest is to enable USB Debugging Mode in the setting. After pluggin with the PC and starting the Rockchip Tool, the tool should find a "Loader Device". Than you choose the image file and start flashing with the RESTORE Button. Dont plug off while flashing. And charge the tablet. The flashing need very high current (more than the USB from the PC delivers) - its no good idea doing this with an empty battery.
There are several instructions in the net - Google will find them.
sbr.harry
Forum Posts: 12
Thanks Received: 5
49
2014/01/11 - 13:41
cifs.ko and md4.ko don't work. I use cifs manager with these modules. X2 just crash then reboot no matter in art or dalvik. They used to work fine in 4.2.2. Maybe they don't compatible with new kernel.
50
2014/01/11 - 14:00
I have converted ManuPC CWM custom recovery and overclocked kernel built for this iFive X2 KitKat firmware into ArcTools packages.
In ArcTools, the two packages should be visible only on iFive X2 tablets running the KitKat firmware (2014/01/08) and are named as follows:
iFive X2 Android 4.4.2 CWM Recovery by ManuPC
iFive_X2_Android_442_CWM_ArcTools_package_b.pngImage Enlarger
iFive X2 2014/01/08 Overclocked Kernel (cpu1800_gpu800) by ManuPC
iFive_X2_Android_442_FW_20140108_overclocked_kernel_ArcTools_package_b.pngImage Enlarger
Please check this ArcTools tutorial making sure you correctly select the packages above.
I don't have an iFive X2 so I haven't been able to test the packages on a real device. Still, I can confirm the CWM package works fine on my PiPO M9 Pro tablet running a KitKat firmware.
The packages come with no warranty, use them at your own risk.
Your feedback is encouraged to confirm these packages work fine, I will then update post #1.
sbr.harry, rockabilly, TecKnight
makso
51
2014/01/11 - 14:37
I did what you said
1.jpgImage Enlarger
superbunika
52
2014/01/11 - 14:46
bjorndell said
Hi!
Does  anybody experience graphicproblems with this new rom?
After flash everything seems good but when doing something like open a browser or Play store the glitches begin and after a couple of glithes the whole screen seems offset, ive attached a photo of it. See below link.
 https://www.dropbox.com/s/5jyysss2jwbntpj/ifivex2_glitch.jpg
One way to redeem the problem is to lock the tablett (using power button) and unlock it. Then everything is back to normal for a few minutes. Then the graphicglitches starts again.
I have tried to reflash but with the same issues.
Any ideas?
I have the same problem also. The solution is to lock it and unlock it again, but the glitch very often comes back. I haven't been able to reproduce it constantly, so have no idea what might be the cause of it.
Other than that this ROM is great, hopefully this little graphical glitch is resloved and finally this tablet becomes usable!
makso
53
2014/01/11 - 15:21
If you look at the picture above and tell me what I'm doing wrong
I thank you very much
ok
I clicked the switch button
Something started to move
Then I clicked on Restore
And it looks wnload frimware
FlowDesign
Forum Posts: 23
54
2014/01/11 - 15:50
CWM installed from ArcTools works perfectly.
makso
55
2014/01/11 - 16:34
bigggg Problem
I made
Only the beginning
reboot recovery
Then the system crashes
After she rises
android.systemui.com
Unfortunately, the process was stopped
Nano2k
56
2014/01/11 - 16:48
Install with arctools worked, reboot, run antutu, black screen at 21%, guess frequencies are too high for some tablets. Flashed ROM again to get stock kernel back, 20025 in Antutu.
rwanek
57
2014/01/11 - 16:50
superbunika said
bjorndell said
Hi!
Any ideas?
just got the same glitch. very strange...
makso
58
2014/01/11 - 17:55
bigggg Problem
I made
Only the beginning
reboot recovery
After she rises
I tried twice
fails Every time
flash the firmware Again
bjorndell
59
2014/01/11 - 19:57
superbunika said
bjorndell said
Hi!
Any ideas?
I also noticed that locking and unlocking removes the glitches but it usually only takes a couple of secs to glitch again.
Compizfox
Forum Posts: 24
60
2014/01/11 - 20:37
Doesn't work for me. Downloaded the overclock kernel, installed it, rebooted but 1,608 GHz is still the highest clock I can choose in No-frills CPU Control.
57 Guest(s)
Devices in use: Desktop (54), Phone (3)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
