[ ROM ] FNF iFive X2 Android 4.4.2 KitKat custom rooted firmware based on v2.0.0 (2014/01/08)
Compizfox
Forum Posts: 24
31
2014/01/10 - 19:02
I know, but I was referring to the background (wallpaper). By default this is a slideshow of some preset pictures. I was wondering if you could change that.
--Holger_p--
Forum Posts: 19
32
2014/01/10 - 19:18
Hi admin,
thank you for your engagement. I would prefer stock loader. And the ifive Video player.
I can test it this weekend - flashing is no problem. Flashing and restore backuped Apps was made in less than one hour yesterday and i did it twice ;-)
Holger
hars73
33
2014/01/10 - 22:53
--Holger_p-- said
Hi admin,
Holger
Holger
I flashed my X2 after I bought it with kasty rom 1.1.8. But now I want to flash to the new kitkat rom without losing my apps and data of these apps. How did you do this? Using Titanium backup? I never done this, that's why I ask.
--Holger_p--
Forum Posts: 19
34
2014/01/10 - 23:06
Hello hars73,
yes, i made a backup with Titanium Backup. You have to backup the data to your EXTERNAL SD, because the internal SD (Default) will be erased when flashing the new rom. So pay a little attention about the backup space.
Compizfox
Forum Posts: 24
35
2014/01/10 - 23:07
I would like to know this to.
With ROMs for most phones (I have experience with some HTC phones) you can just flash the ROM in Clockworkmod without wiping /data and you keep your apps and settings. So that would be called a update, and of course that doesn't work when switching to another ROM.
How do you do that with Kasty ROM? I noticed that there is an "update" button in Rockchip Batch Tool. Can I just hit that instead of the "restore" button, or won't that work?
Or could you just supply a CWM .zip file?
manupc
Forum Posts: 18
Thanks Received: 12
36
2014/01/10 - 23:13
Hi. Thanks for your custom rom.
I have made a working CWM recovery and overclocked kernel for ifive x2 4.4.2. Flash the new files together with the parameter file from your rom.
CWMflash.pngImage Enlarger
Download CWMrecovery:
https://app.box.com/s/pk098mmskzoxx4il3vy8
Download OCkernel (cpu1800mhz  gpu798mhz):
https://app.box.com/s/5d7r1l3yqi8lowhv6n1k
The following users say thank you to manupc for this useful post:
admin, Fabriel, sbr.harry, tarjan, validatus, DarthJabba, usestel
--Holger_p--
Forum Posts: 19
37
2014/01/10 - 23:30
Hi manupc,
is it possible to overclock the x2 without cwm?
I prefer flashing with the ifive/rockchip tool. Its simple. cwm seems to be much more difficult and my english isn´t good enough for using it.
Holger
Thanks Received: 3171
38
2014/01/10 - 23:38
Thanks for that manupc.
If anyone is interested and manupc is OK with that, I can make the CWM and overclocked kernel available as ArcTools packages that would be a little easier to install (directly from the tablet) than using a Windows Flash tool. Let me know...
sbr.harry, validatus
manupc
Forum Posts: 18
Thanks Received: 12
39
2014/01/10 - 23:43
--Holger_p-- said
Hi manupc,
Holger
You dont need cwm. You can use RK3xxx_firmware_tools to extract the parameter file from the rom and to flash it with the kernel.
https://app.box.com/s/tuomks1okchlnkcobiqc
manupc
Forum Posts: 18
Thanks Received: 12
40
2014/01/10 - 23:49
No problem. Its fine to share it for everyone.
Cheers
--Holger_p--
Forum Posts: 19
41
2014/01/10 - 23:57
manupc said You dont need cwm. You can use RK3xxx_firmware_tools to extract the parameter file from the rom and to flash it with the kernel.
I m sure somebody can do this. But without knowledge of Android/Linux i think it is no good idea. Thought it is only a file to copy with a explorer and a restart.
Holger
manupc
Forum Posts: 18
Thanks Received: 12
42
2014/01/11 - 00:03
Holger, You could wait for admin to implement it as ArcTools packages as installation is then easier.
FlowDesign
Forum Posts: 23
43
2014/01/11 - 04:01
How the h3ll do I extract that parameter file from the ROM?
CWM zip file or via ArcTools is much simpler than this...
bjorndell
44
2014/01/11 - 07:36
Hi!
Does  anybody experience graphicproblems with this new rom?
After flash everything seems good but when doing something like open a browser or Play store the glitches begin and after a couple of glithes the whole screen seems offset, ive attached a photo of it. See below link.
 https://www.dropbox.com/s/5jyysss2jwbntpj/ifivex2_glitch.jpg
One way to redeem the problem is to lock the tablett (using power button) and unlock it. Then everything is back to normal for a few minutes. Then the graphicglitches starts again.
I have tried to reflash but with the same issues.
Any ideas?
makso
45
2014/01/11 - 10:40
Hi friends I made Root
I want to install a ROM on the device but do not understand the order of things
1 Use Rockchip Batch Tool
2 kasty-fnf_ifive_x2-442-200_20140108-rooted4b.zip
Do I need to install drivers before on Rockchip Batch Tool ?
When I try to open the file kasty-fnf_ifive_x2-442-200_20140108-rooted4b.zip
Weinzip refuses iso format Something?
55 Guest(s)
Devices in use: Desktop (53), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
