Here is an Android 4.4.2 KitKat rooted custom firmware for the FNF iFive X2 tablet. This firmware is based on the official iFive firmware 2.0.0 dated 2014/01/08.
(ifiveX2_FW_442尝鲜版_V2.0.0_201401081800.rar / FNF/五元素 ifive X2 4.4.2V2.0.0)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #9 SMP PREEMPT Wed Jan 8 17:13:21 CST 2014
Android build: IFive/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140108.161906:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.89 (free version)
- disabled OTA updates (may cause problems)
- edit: added back iFive Music and Video players
- optional ClockworkMod (CWM) Recovery easy install package
- Edit 2014/01/14: updated SuperSU to latest version 1.89 (free version)
- Edit 2014/01/14: added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
- Edit 2014/01/14: use optional package to fix broken apps (Contacts/People and Calendar sync)
Download: kasty-fnf_ifive_x2-442-200_20140108-rooted4c.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive X2 to test it.
--Holger_p--, the tester, networker, obolox, Cel1971, Fabriel, tobago, manupc, guapper, rockabilly, yuranbo, diego.m If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/10/05
I installed yet. Better Antutu index, now 19817.
But there are three problem i found after a few minutes.
First: ifive skin is back.
Does anbody know how to kill it?
The second: The gallery is too slow for AVCHD files and the old ifive player from 4.2.2 doesnt work with this new version. Can we get the actual ifive player please?
The third: The Lookscreen shows me now always the weather of Shenzen. Nice to know, but far away from germany and im really not interested in the the waether of Shenzen...
Holger
2013/10/06
Not sure if I'm doing something wrong (I installed 4.2.2/1.18 previously with no issues) but I got a "Download Firmware Fail" on the Batch Tool after a while...Had some problems getting into flash mode in the first place which I put down to being on Win 8.1, but it seemed to be working fine up to this point.
Not actually sure what to do now to get back to previous version/exit the flash tool
If anyone is reading this live - Do I just exit the tool and try again?
FNF iFive X2 (Kasty 4.4.2 KitKat ROM)
2013/10/06
Ok, problem was solved for me as got a BSOD and a force reboot of PC - Second time worked fine and tablet has now just booted up with no issues, Phew! Hopefully a way to get rid of the iFive skin will be forthcoming soon.
Thanks - Will report on any other discovered issues
2013/10/06
As far as looks go it's really hard to get past the iFive skin which I hate, but for performance everything I'm trying seems good - smooth and slick.
My Antutu score was 20072.
Can't find the FiveWeather.apk file so cannot follow the weather removal tool from previous version posts.
Probably not installing too much at this stage or trying too much more tonight as I'm holding out for skin removal update.
--Holger_p--,
I have rebuilt the firmware adding back the iFive Video and Music players. Please let me know if they are worth to be kept in the firmware.
Post #1 updated and new firmware posted:
Download: kasty-fnf_ifive_x2-442-200_20140108-rooted4b.zip
As for the Skin, are you talking about the launcher or is it an external APK (I may have missed it when cleaning the firmware) ?
Regarding Shenzen Weather in the lockscreen, I have found some traces of it, but I am not sure how to disable it, it won't be easy to check without having an actual iFive X2 to test on. If anyone has suggestions...
2013/10/05
The video Player is very performant. It is the Rockchip Videoplayer and extreme optimized for MALI400. But i´m not sure if it fix the problem with AVCHD in the new ROM. I got last week a Finger On Tab engeneered from a company named Trulux (Japan) - wonderful tablet with RK3188 and Android 4.2. and a brandnew Kernel from Rockchip with MultiWindows, Miracast and so on. Antutu Benchmark was good, but the AVCHD Performance is very poor. Even with the optimized Rockchip Player, preinstalled.
This new Kitkat ROM has new Rockchip stock Kernel too and suddenly exact the same problems with AVCHD. I think they changed the Kernel. So i did downgrade a few minutes ago.
2013/08/09
My X2 will arrive Tuesday, would there be a way to get Stock launcher in this Rom like in the latest 4.2.2 1.2.0 ROM?
I can't check it yet but the APK for Nexus 5 Kitkat launcher can be found here:
http://forum.xda-developers.com/showthread.php?t=2529594
96 Guest(s)
Devices in use: Desktop (86), Phone (10)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
