Here is a rooted custom firmware for the FNF iFive X2 tablet based on official version 1.2.0 published on 2013/12/26.
(ifiveX2_FW422_V1.2.0_11291100.img / ifiveX2_FW422_V1.2.0_11291100.rar)
Build information:
Linux Kernel:Â Linux version 3.0.36+ #35 SMP PREEMPT Fri Nov 29 10:41:30 CST 2013
Android build:Â IFive/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130916.144023:eng/opinions-on-teclast-p90hdst-keys
Manufacturer revision history (translated from Chinese)
   1 updates the HDMI output issues
   2 to optimize the system stability.
   3 debug wifi stability. of
- root with latest SuperSU version 1.86 (free version)
- increased space for applications (/data partition) to 4 GB
- disabled OTA updates
- removed iFive launcher, replaced with Android 4.2 AOSP stock launcher from here
- optional ClockworkMod (CWM) Recovery easy install package
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
Download: kasty-fnf_ifive_x2-422-120-rooted4.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, don't flash using the "sdcard" method.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive X2 to test it.
Thanks Cel1971 for the tipÂ
leechmilk, Fabriel, --Holger_p--, the tester, omar11, TecKnight, ram007 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/10/05
Thank you for this firmware.
But you wrote "removed most Chinese and unnecessary applications".
The ifive player is not unnecessary. He is like 2160p Gallery good optimized for MALI400 and can AVCHD Videos without timelag between picture and sound in any situation. Th MX Player can this, if you don´t touch the display while watching, so the player has not to show his symbols.
Was there a new version of the ifive Player?
2013/12/15
Thanks for the new firmware.:)
I personally quite happy with the stock task bar which I can fully ultilise the full screen by tap on the full screen icon and the kill all icon from the notification manuel, would it be possible to add this feature back or provide the apk , so we can have our own choice to install?
Android system supports many languages, including Finish. I don't have an X2 to confirm, but it is certainly present on the tablet.
2013/12/30
There's a pitfall with the busybox installation. There's a lonely busybox link for run-parts living in "/system/bin" that points to "busybox". This works fine with fresh rom install but if you grab stericson's busybox installer and update busybox, it'll stop working as busybox will move to "/system/xbin" by default. It appears the busybox installation included is far from complete, for example "find" command is missing. All other "busybox-like" links in /system/bin point to "toolbox" incidentally.Â
Stericson installer will not touch the run-parts shortcut by default and even if you force smart-install to overwrite it, it'll still point to "busybox" which will not work.Â
run-parts is of course needed for init.d support, it's called from /init.rc.Â
I believe including "/system/xbin" into path should fix the issue. Alternatively moving busybox to /system/xbin where stericson's installer defaults to should take care of it. Including the complete busybox installation created by stericson's apk in the ROM would be ideal of course.Â
Barleyman,
Current busybox build I use in the firmwares did good so far.
Thanks for your feedback, that's the first time this has been reported, I'll consider the request.
About including "the complete busybox installation created by stericson's apk", I would need to check with the author as I am not sure I am allowed to redistribute the binaries without permission.
iFive X2 Android 4.4.2 KitKat firmware posted:
Cheers
Currently Online: jenom
65 Guest(s)
Devices in use: Desktop (61), Phone (5)
jenom
kfwacky
fer30
culo1
dfrt
PQNY
