2013/04/04
ifiveX2 4.2.2 SDK2.0 20130625 AOSP
am working on a rom... everything working... smooth... boots fast... first beta! will you try it?
More info when upload is down! my last internal test is finish soon, and you can get freedome for your X2
Screenshots: https://www.dropbox.com/sh/wrnvt5pkiq59d67/gMpz2qEMlU
If ther is any swedish in this form, Hej! Testa den
The following users say thank you to stassen for this useful post:
koradris, tobago, tarjan, kage69
2013/04/04
stassen said
ifiveX2 4.2.2 SDK2.0 20130625 AOSPam working on a rom... everything working... smooth... boots fast... first beta! will you try it?
Download: https://www.dropbox.com/sh/74luj7rlb8p0vm7/28hKTz4DAE (Uploading started... its in the link then its finished!)
Screenshots: https://www.dropbox.com/sh/wrnvt5pkiq59d67/gMpz2qEMlUIf ther is any swedish in this form, Hej! Testa den
tobago
2013/06/29
Great job. I was flashing many ROMs and this will be one of the greatest ROM.
But, There is one bug or problem.
When I use chrome or firefox I experience flickering. Especially white goes to greeny and back again goes again and again. I think this is some kind of bug. Can you fix this bug? Please ~
2013/06/28
Hi stassen,
again, thanks so much for this ROM, it's close to magical - since it's based on AOSP there are no extra frills or peculiarities that one would have to worry about, it's running smooth like butter, graphics are excelllent.
Regarding KingMetalSlime's flicker problem, I for one can't reproduce that, firefox is running great with mine, and I got rid of chrome... so, conclusively, a genuine masterpiece of a custom rom!
The following users say thank you to tobago for this useful post:
stassen
2013/06/29
tobago said
Hi stassen,again, thanks so much for this ROM, it's close to magical - since it's based on AOSP there are no extra frills or peculiarities that one would have to worry about, it's running smooth like butter, graphics are excelllent.
Hmm ..
Now I'm flashing ROM again and check again. But unfortunately this color changing problem not disappeared.
Did you change between landscape and potrait? Just open system default web-browser and change between landscape and portrait (also revese) you can see greeny white change normal white(little bit red). You can also check when loading keyboard app. This happened short time.
Very weird, this problem disappeared when check "Disable HW overlays" option in Settings -> Developer options. But check this option, UI performance little bit down.
I don't understand why this problem cause and what is that option.
...thank you for this rom! After deleting some (system)apps it run smooth and quickly. Chrome won't run first, must delet it and install new from market ...
Auto-brightness is not aviable in this rom but wifi is t more stable
Deletet apps by myself are (German Settings):
Browser
TalkBack
Hangouts
System Update
Arctools
Phase Beam
Mobilfunk ... (Sprachbox)
Konfiguration des Mobilfunknetzes
com.android.smspush ...
Chrome deinstalled an reinstalled from GooglePlay cause won't run perfect before ...
Apps backuped and deinstalled with "Titanium Backup"
2013/07/11
I love this ROM so far. But I can confirm that the KingMetalSlime's bug IS happening for me as well. It is pretty subtle, but the it just seems to me the the backlight is gets brighter and dimmer over and over again when using firefox, and it does kinda give it a greenish hue for a second, and then back to normal.
Currently Online: vonkarayan, astosenix
66 Guest(s)
Devices in use: Desktop (58), Phone (10)
grielgryel
klaus1255
neverever007
favorit
Альфвоф
kevbez
