Flashing Problems with iFive X2 custom firmware 1.1.8, fixed
This topic is locked
This post is pinned 1
2013/09/18 - 09:18
I am making this topic to keep the history about firmware 1.1.8 problems that appear on the first releases of our custom firmware 1.1.8.
[ ROM ] FNF iFive X2 Android 4.2.2 custom rooted firmware based on v1.1.8 (2013/09/16)
The problems have now been fixed, see post #1 to download the proper firmware.
This topic is locked and cannot be posted, please use the main firmware topic if you need to report any bug.
Thank you.
xeph
2013/09/17 - 13:11
I treid to flash this rom, but the batch tool says 'Restore Done Success<0> Fail<1> Time>131094>ms' with red flag at almost end of the flashing.
*EDIT 1: I force reboot the device after the failure and it seems to work.
2013/09/17 - 13:14
That's weird, this custom firmware is build just the same way as the previous custom Ifive X2 firmware.
Is anyone else is having this problem ?
I'm having a look right now.
xeph
2013/09/17 - 13:21
Have no idea about that.
After force reboot, the device is working w/o problem(I was watching the batch tool while it was flashing the rom, and the fail thing happens like the end of(99%) firmware downloading.
sbr.harry
Forum Posts: 12
Thanks Received: 5
2013/09/17 - 14:25
can't flash
err massage below
19:38:38 250    Rockchip Batch Tool v1.7.1.1 start run
19:39:56 406    **********Restore Start Total<1>**********
19:39:56 406    <Layer 5-6> Test Device Start
19:39:56 406    <Layer 5-6> Test Device Success
19:39:56 406    <Layer 5-6> Lowerformat Device Start
19:40:20 437    <Layer 5-6> Lowerformat Device Success
19:40:20 437    <Layer 5-6> Test Device Start
19:40:20 437    <Layer 5-6> Test Device Success
19:40:20 484    <Layer 5-6> Check Chip Start
19:40:21 359    <Layer 5-6> Check Chip Success
19:40:21 359    <Layer 5-6> Get FlashInfo Start
19:40:21 359    <LAYER 5-6> INFO:FlashInfo: 0 0 0 1 0 20 20 28 22 1 3
19:40:21 359    <Layer 5-6> Get FlashInfo Success
19:40:21 375    <Layer 5-6> Prepare IDB Start
19:40:21 406    <LAYER 5-6> INFO:CS(1)        (8192MB)        (TOSHIBA)
19:40:21 406    <LAYER 5-6> INFO:CS(2)        (8192MB)        (TOSHIBA)
19:40:21 421    <Layer 5-6> Prepare IDB Success
19:40:21 421    <Layer 5-6> Download IDB Start
19:40:25 390    <Layer 5-6> Download IDB Success
19:40:25 390    <Layer 5-6> Reset Device Start
19:40:26 406    <Layer 5-6> Reset Device Success
19:40:26 406    <Layer 5-6> Wait For Loader Start
19:40:32 406    <Layer 5-6> Wait For Loader Success
19:40:32 406    <Layer 5-6> Test Device Start
19:40:32 421    <Layer 5-6> Test Device Success
19:40:32 421    <Layer 5-6> Download Firmware Start
19:44:58 187    <LAYER 5-6> ERROR:RKA_File_Check-->Memcmp failed,Read(8388608)
19:44:59 015    <LAYER 5-6> ERROR:DownloadImage-->RKA_File_Check failed(kernel)
19:44:59 031    <Layer 5-6> Download Firmware Fail
19:44:59 031    **********Restore Done Success<0> Fail<1> Time<302625>ms**********
Thanks Received: 268
2013/09/17 - 15:08
I've just made a few changes in the firmware, I hope it fixes the flashing issue :
Download: kasty-fnf_ifive_x2-422-118-rooted4b.zip
It's untested as I don't have an iFive X2, please let me know how it works for you, I'll do my best to fix the firmware if there are still problems.
xeph
2013/09/17 - 15:12
Can you tell me what changes did you made? I installed and customized(I mean, installed lots of apps) the first rom. Should I flash the new one?
Oh btw, 'view desktop page' thing(I don't know what it says in English locale) in Browser app is weird. It is always checked(enabled) whenver I open a new tab.
2013/09/17 - 15:41
Changes made for the kasty-fnf_ifive_x2-422-118-rooted4b.zip firmware compare to previous one are quite small things that are internal to our custom firmware build process. There should be any visible difference for the user apart from a slightly increased system partition size (now ~640 mb).
I'm hoping my changes do fix the flashing problem and I encourage you an anybody to reflash if previous flashing wasn't 100% successful.
xeph
2013/09/17 - 15:59
I tried the new version, but it fails too. Of course, the rom itself is working great.
**********Restore Action**********
<Layer 1-1-3> Test Device Start
<Layer 1-1-3> Test Device Success
<Layer 1-1-3> Lowerformat Device Start
<Layer 1-1-3> Lowerformat Device Success
<Layer 1-1-3> Check Chip Start
<Layer 1-1-3> Check Chip Success
<Layer 1-1-3> Get FlashInfo Start
<Layer 1-1-3> Get FlashInfo Success
<Layer 1-1-3> Prepare IDB Start
<Layer 1-1-3> Prepare IDB Success
<Layer 1-1-3> Download IDB Start
<Layer 1-1-3> Download IDB Success
<Layer 1-1-3> Reset Device Start
<Layer 1-1-3> Reset Device Success
<Layer 1-1-3> Wait For Loader Start
<Layer 1-1-3> Wait For Loader Success
<Layer 1-1-3> Download Firmware Start
<Layer 1-1-3> Download Firmware Fail
**********Restore Done Success<0> Fail<1> Time<129953>ms**********
**********Switch Action**********
<Layer 1-1-3> This operation didn't do,because of not supporting!
**********Switch Done Success<0> Fail<1>**********
sbr.harry
Forum Posts: 12
Thanks Received: 5
2013/09/17 - 16:43
flash err
22:31:51 796    Rockchip Batch Tool v1.7.1.1 start run
22:32:34 515    **********Restore Start Total<1>**********
22:32:34 531    <Layer 5-6> Test Device Start
22:32:34 531    <Layer 5-6> Test Device Success
22:32:34 531    <Layer 5-6> Lowerformat Device Start
22:32:58 625    <Layer 5-6> Lowerformat Device Success
22:32:58 625    <Layer 5-6> Test Device Start
22:32:58 656    <Layer 5-6> Test Device Success
22:32:58 671    <Layer 5-6> Check Chip Start
22:32:58 718    <Layer 5-6> Check Chip Success
22:32:58 718    <Layer 5-6> Get FlashInfo Start
22:32:58 718    <LAYER 5-6> INFO:FlashInfo: 0 0 0 1 0 20 20 28 22 1 3
22:32:58 718    <Layer 5-6> Get FlashInfo Success
22:32:59 125    <Layer 5-6> Prepare IDB Start
22:32:59 140    <LAYER 5-6> INFO:CS(1)        (8192MB)        (TOSHIBA)
22:32:59 140    <LAYER 5-6> INFO:CS(2)        (8192MB)        (TOSHIBA)
22:32:59 218    <Layer 5-6> Prepare IDB Success
22:32:59 218    <Layer 5-6> Download IDB Start
22:33:00 312    <Layer 5-6> Download IDB Success
22:33:00 312    <Layer 5-6> Reset Device Start
22:33:01 343    <Layer 5-6> Reset Device Success
22:33:01 343    <Layer 5-6> Wait For Loader Start
22:33:07 171    <Layer 5-6> Wait For Loader Success
22:33:07 171    <Layer 5-6> Test Device Start
22:33:07 171    <Layer 5-6> Test Device Success
22:33:07 203    <Layer 5-6> Download Firmware Start
22:34:23 406    <LAYER 5-6> ERROR:RKA_File_Check-->Memcmp failed,Read(8388608)
22:34:24 250    <LAYER 5-6> ERROR:DownloadImage-->RKA_File_Check failed(kernel)
22:34:24 250    <Layer 5-6> Download Firmware Fail
22:34:24 250    **********Restore Done Success<0> Fail<1> Time<109734>ms**********
2013/09/17 - 17:21
Not having an iFive X2 (or an RK3188 tablet) doesn't make it easy for me to reproduce and understand the flashing problem Confused  I'll see if I can get hold on one and try to fix the issue.
sbr.harry
2013/09/17 - 22:00
Here is a last test firmware, hopefully fixing the flashing problems:
Download: kasty-fnf_ifive_x2-422-118-rooted4c.zip
Please, let me know how it goes, thank you.
Dare
mar76ek
2013/09/17 - 22:36
Hello.
Does anyone know what are the differences between stock fimware ifive X2 422_V1.1.5 and ifive X2 422_V1.1.8 ?
osama001
2013/09/18 - 00:35
What are the differences between firmware ifive X2 422_V1.1.5 and ifive X2 422_V1.1.8 ? Is it faster, smoother and more stable?
Also in ifive X2 422_V1.1.5 firmware, the available memory is less than 650MB (that is more than 1.3GB of RAM is used by the system), How it increase available RAM?
49 Guest(s)
Devices in use: Desktop (43), Phone (6)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
