Here is a rooted custom firmware for the FNF iFive 2S HD tablet based on official version 1.1.9 published 2013/10/19
Build information:
Linux Kernel:Â Linux version 3.0.36+ (root@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #171 SMP PREEMPT Sat Oct 19 11:37:13 CST 2013
Android build:Â IFive/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131019.114704:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
- root with latest SuperSU version 1.65 (free version)
- increased space for applications (/data partition) to 4 GB
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
Notes:Â
I have left the stock iFive launcher, please let me know if it's working fine or if you prefer having a stock Android launcher.
Download:Â kasty-fnf_ifive_2s_hd-422-114-rooted4.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, don't flash using the "sdcard" method.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive 2SHD to test it.
nghiakhanh, TecKnight If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/11/04
2012/11/04
danielt said
I just got my ifive 2s HDand I have flashed your firmware
It's now doing well~
really good tablet I think
the high resolution was just epic!!!!!!
I will report if meeting any problem~
THX a lot
Daniel,
Glad to hear that FNF continues to make high quality tablets that push the envelope in both graphic quality and in price. I saw it on sale the other day for $242 with free shipping, which is a real steal for a quad core 10" tablet with 2048x1536 resolution !!
FYI, the firmware on the 2S HD is almost identical to the X2--The only real difference between the two is screen resolution, so I would expect almost all of the procedures on the X2 wiki here:
https://www.miniand.com/wiki/iFive+X2
should also work on your tablet, except I would avoid the change your boot graphic procedure and you would want to use kasty's firmware image for the 2S HD for the firmware flashing procedure.
2013/10/30
TecKnight
thank you for your endeavor to the fw!!
it's has been working great on my tablet till now^^
BTW
I replace the origin ifive UI with nova launcher
and it becomes better i think
I am now learning to modify fw , trying to enhance wifi and reduce ram usage
anyway thank you a lot!! for making such a awesome thing!
2012/11/04
bigfoot53 said
Hello All,Just got my Ifive S2 HD today. Just wanted to see if the new firmware is working well?
Is this still the newest version? do I need any special tools to flash it?
Bruce
Bruce,
As far as I am aware, the posted image:
http://www.arctablet.com/blog/downloads/firmware/FNF_ifive/kasty-fnf_ifive_2s_hd-422-114-rooted4.zip
is the latest version for your tablet.
Just download the .zip above and extract the contents. You will find a .img file within it.
Follow the instructions linked below using the .img file you extracted in step 12.
https://www.miniand.com/wiki/Flashing+a+new+firmware+image+to+the+iFive+X2+Step+by+Step
Note: those instructions were written for an iFive X2, but will work perfectly for your tablet as well.
Please let us know how it goes, we haven't heard from many S2 HD owners yet.
2013/12/12
!!!Update!!!Â
I flashed the Ifive and all seems to be fine. Running smooth. Do have one question I installed Titanium Backup and it says it failed to obtain root access. Is this an issue with the free version of SU or do I need to configure Titanium Backup?
also any way to get the temp app on the main launcher to be in English ?
Bruce
2012/11/04
bigfoot53 said
!!!Update!!!ÂI flashed the Ifive and all seems to be fine. Running smooth. Do have one question I installed Titanium Backup and it says it failed to obtain root access. Is this an issue with the free version of SU or do I need to configure Titanium Backup?
Bruce
Bruce,
Sounds like you never granted root access to Titanium Backup. Launch the SuperUser app and it should have a log and a list of applications that have been granted root. See if it will let you grant root to Titanium there. I use SuperSU myself and it is very user friendly once you launch it.
As for the weather app, It is Chinese only. I suggest you follow the instructions here:
https://www.miniand.com/wiki/Removing+all+traces+of+the+iFive+chinese+weather+app
Cheers
88 Guest(s)
Devices in use: Desktop (82), Phone (6)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
