Here is a rooted custom firmware for the FNF iFive 2S tablet based on official version 1.0.5
(ifive2S_FW_411_V1.0.5.zip)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@five-server) (gcc version 4.4.3 (GCC) ) #422 SMP PREEMPT Thu May 23 15:09:50 CST 2013
Android build: IFive/rk30sdk/rk30sdk:4.1.1/JRO03H/ifive.Quad-Core.20130417.175843:eng/ifive-keys
- root with latest SuperSU 1.30 (free version)
- Google Play Store fixes so more applications are visible/compatible
- Android 4.2 AOSP stock launcher from here
Download: kasty-fnf_ifive_2s-411-105-rooted2.zip
Use Rockchip Batch Tool version 1.6 to flash the firmware, don't flash using the "sdcard" method.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive 2S to test it.
2013/06/24
i just got my ifive 2s today and want to flash it, i have the drivers and the flash tool installed on win7 64bit, but i dont know how to put the tablet into recovery mode, i tried holding the vol - down at the same time as the power, it puts it into safe mode. i dont see a pin hole button, just mic, i think. can anyone point me in the right direction. thanks
2013/06/24
thanks, played with the power and vol keys and found that vol + and power for 2 seconds gets me to the screen with an android laying down with a red triangle coming out of it, i think that means im on the right track, im just not holding the power key long enough or to long, but thanks for the push, i'll keep playing around with it
What do you exactly need, because i don`t manage to understand your request.
2013/06/25
I am able to start the rockchip tool and my tablet with the adroid lying with the red triangle.
But I am not able to connect my tablet with windows.I tried two different systems with win 7 32 bit and 64 bit and different drivers. But always there is code 10 coming up that during installing an error occured.
Does anybody know how I can fix that? Otherwise I can't root my tablet!
Thanks!
2013/06/25
You need to do the following steps to connect the FNF iFive 2S tablet with your windows PC and the Rockchip tool:
1. Shut down the tablet by pushing the power button and choose "Ok";
2. Push on the volume + button and put the USB cable in the tablet, hold on the volume + button;
3. Windows will see a new unknown USB connection. Install the Rockchip driver which has been delivered with the Rockship tool.
4. After installing the driver you can release the volume + button.
5. Start the Rockship tool and you will see that it recognize the tablet and you can install the new firmware.
After installing the new firmware you can starting up the tablet by pushing the power button.
2013/06/24
Thanks to the instructions, I was able to install the drivers and get the rooted firmware on my I five 2s. The rom works great, I think it boosted the WiFi signal, not really sure. All the apps I installed have worked like their supposed to. I ran antutu with this ROM and got a 17006, not bad considering I had apps in the back ground to try to simulate normal use, thanks for the rooted ROM.
I don't know of any, if one comes out I'm pretty sure it will be reported in the forum.
Android 4.2.2 Jelly Bean custom firmware for the iFIVE 2S just posted:
2013/08/29
smartthijs said
You need to do the following steps to connect the FNF iFive 2S tablet with your windows PC and the Rockchip tool:1. Shut down the tablet by pushing the power button and choose "Ok";
I did steps 1-4 installed Rockship drivers successfull, but Rockship tool (v.1.7) did not recognized my iFive 2S
;(( What to do?
2013/08/29
YEAH!
I did it. Rockchip Batch Tool recognized my device (iFive 2S), i followed those instructions:
Now: as for the config.ini modification, I found on minixforums a post by user Snurb that does the trick. You open config.ini (located in the same folder where the .exe file is) and look for this line:
LOGFLAG=TRUE
#SUPPORTLOWUSB=TRUE时,扫描支持full speed usb设备,默认只支持high speed usb设备
SUPPORTLOWUSB=
This you change into:
LOGFLAG=TRUE
SUPPORTLOWUSB=TRUE
FULLSPEEDUSB=TRUE
Save & close.
Then you start Rockbatch Tool and all of a sudden, I had a green flashing light… ready to flash the new firmware!
92 Guest(s)
Devices in use: Desktop (82), Phone (8), Tablet (2)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
