(ifive_100_422_V1.0.6_20140421.rar / ifive 100_422_V1.0.6_20140421.img)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@ubuntu-0A) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #148 SMP PREEMPT Fri Apr 4 14:37:51 CST 2014
Android build:Â IFive/rk3026/rk3026:4.2.2/JDQ39/eng.root.20140418.101439:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.94 (free version)
- increased space for applications (/data partition) to 3 GB
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
- optional ClockworkMod (CWM) Recovery easy install package
Notes:Â
Download: kasty-fnf_ifive_100-422-106-rooted3.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, don't flash using the "sdcard" method.
If you like our work, please support us to keep the site alive and contribute to our efforts. |
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive 100 to test it.
gmax_jp, arkim34 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2014/05/07
Here is a rooted custom Android 4.2.2 firmware for the FNF iFive 100 tablet based on official version 1.0.6 dated 2014/04/21(ifive_100_422_V1.0.6_20140421.rar / ifive 100_422_V1.0.6_20140421.img)
Build information:
Notes:Â
If you like our work, please support us to keep the site alive and contribute to our efforts. Â
Hi, I've just done brief check. To put it shortly, working great.
OpenGLESv2 problems has gone and other functions are working perfect!
Antutu Benchmark X score marked 9492 and this sould be a typical for RK3026. I think the score is a little bit better than ROM rev 1.01 based. Cool.
I found some little issue regarding timezone. I couldn't change "Europe/London" from "setting".
But solution is clear, modify build.prop and change like "persist.sys.timezone=Asia/Tokyo"('cause I'm in Japan). Or install TimeZoneChanger app from google play, set your favoriate TZ there and reboot.
Thanks admin !
2014/05/07
Hi, I found other issue caused by definitions in /etc/permissions directory. I modified handheld_core_hardware.xml for "phablet" mode operation. It seems that following two lines required in order to use GPS tethering client.
   <feature name="android.hardware.location.gps" />
   <feature name="android.hardware.location.provider" />Â
The other hardware definition in tablet_core_hardware.xml are correct, so this fix should be useful for users who want phablet mode by setting ro.rk.systembar.tabletUI=false in /system/build.prop.
The following users say thank you to gmax_jp for this useful post:
Fitzcarraldo said
Apologies for the silly question but: How do you put it in update mode? Do you press volume - or + when inserting the usb cable?I still have problem, will try and remove all driver as suggested by gmax_jp (thanks for the advice!)
Hi friend, I'm doing flash as directed at:
Flashing your Arnova G2, Arnova G3, Rockchip RK29xx/RK30xx based tablet with Rockchip flashing tool
There is a difference for iFive 100, I have to press "Vol -" button to enter update mode. Screen of the tablet is still turned off and I can recognize update mode by seeing "green square" is displayed in Rockchip Batch tool panel.
In addition, two more cases I met were:
- When I didn't connect to PC, this method boots "recovery mode"(I could see CWM or TWRP screen).
- When I connect the tablet to PC via USB hub, Rockchip Batch tool didn't recognize the tablet. Tablet seems to be in "update mode" but PC didn't recognizes it's status.
I hope this help you a bit,
49 Guest(s)
Devices in use: Desktop (39), Phone (10)
hellander
elousstad
relaytester
revoltown
tdomnic024
