[ROM] iFive Mini3 Retina MIUI ROM Beta
Arqtico
2014/05/24 - 19:07
The following users say thank you to Arqtico for this useful post:
Legard, avant
ricxgp
2014/06/02 - 12:15
Here you can see a video:
I recommend you install OC 1.7 GHz after install MIUI rom, whether you want try this rom.
stefano2566
2014/06/03 - 11:40
I tried to install this rom.
I can not get root permissions.
Do you have any education.
thanks
ricxgp
2014/06/03 - 14:01
Instructions
http://www.retroandroid.com/
gongbaojiding
2014/06/03 - 18:06
http://www.mgyun.com/
hello,guy!i think the application upon will do some help,you can have a try.
plus :i'v root my pad successfully with this applicacion.
Thanks Received: 1385
2014/06/15 - 12:42
Ok, I can adapt this on Odys Iron by compiling the RTL8723 wifi system
Is the source code available somewhere?
MIUI_4.pngImage EnlargerMIUI_6.jpgImage EnlargerMIUI_5.jpgImage Enlarger
Legard
2014/06/19 - 23:28
Not released new ver yet? Just need fix problem with USB connect to PC.
fozyb
2014/06/30 - 04:16
ROM works nice and smooth, however there is no Themes app present. I can see it in system/app, but even if I install it it doesn't show up on the homescreen even after a reboot. Does anyone know how to get the Themes Market to work? Cheers
PanDa
2014/12/06 - 16:19
Dude im ifive is stuck because of u i cant flash any firmware couse when i plug the cable the rom tablets boots up
jhomssss
2015/01/12 - 19:49
just want to share.. if you just want to root the tablet you can use ROOT Genius..
download the installer from this site.. ROOT GENIUS
Root ProofImage Enlarger
root proof2Image Enlarger
66 Guest(s)
2 Guest(s)
Devices in use: Desktop (50), Phone (16)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
