[ ROM ] FNF iFive mini3 (retina version) Android 4.4.2 KitKat custom rooted firmware based on v2.1.1 (2014/03/25)
dun74fr
Forum Posts: 16
76
2014/06/20 - 16:30
turm99 said
dun74fr said
Thats a great new (remove the Shen Zhen" meteo). But I can remove it by doing a long press and move it on the upper left cross to delete, but I do no have a + sign to add another one.
Any idea ?
Dun
Just do this steps:
    1. Open up the Settings app and tap ‘Security’
      1. Tap ‘Enable Widgets’
        1. Go to your lock screen, then swipe over to the left and then tap the plus symbol
          1. Pick the widget you’d like to add to your lock screen
          // <![CDATA[
          (function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);
          b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};
          O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};
          O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=
          new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};
          O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};
          N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();
          pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=973cf05631&post=43642&forumid=182','5Czn0lsVdP',false,'RABEuiwD6Cw');
          Great !!!
          Thank you very much.. Was always strange to see this shen zhen meteo !!
          Dun
          dun74fr
          Forum Posts: 16
          77
          2014/06/24 - 22:24
          I am sorry to come back with my problem, but there is a lot more members now.
          On my IFive mini 3 Retina with this last custom rom and OC to 1.7Ghz I've got
          problem with bluetooth connection. I can pair, but never transmit or connect to anything.
          Always "connection failed" or something similar. Do you think it is software or hardware ? I didn't see any report of similar problem by anyone. I'am the only one ?
          Dun74
          sothoms
          78
          2014/06/25 - 22:34
          I have the same rom and OC at 1.7 also.
          I have no problem with bluetooth.
          I tested with my samsung galaxy s4 and I can receive-sent any file
          dun74fr
          Forum Posts: 16
          79
          2014/06/25 - 22:59
          Thank you for your feedback.
          Do you think it could be a hardware problem?
          Dun74
          sothoms
          80
          2014/06/25 - 23:37
          I dont know but it sounds unlikely to be a HW problem.
          Did you try to test it with other devices?
          If the problem continues, try to install the official rom and check again
          dun74fr
          Forum Posts: 16
          81
          2014/06/25 - 23:43
          Yes I tried keyboards. File transfer on various devices etc..
          You are right I will check with the original ROM
          Is there a way to put the root and the oc on the original ROM?
          Dun
          sothoms
          82
          2014/06/25 - 23:51
          Sorry, I cant help you with that.
          I have just bought mine and I dont know a lot of tweaks.
          dun74fr
          Forum Posts: 16
          83
          2014/06/26 - 22:54
          Hi there !!
          I think I soft briked my tablet. :-(
          I tried to install CWM from arctool (ManuPC) it works.
          I started the recovery mode.. and now I cant get out of it. Each reboot
          goes back to CWM.
          Is there a way to get out of this ? or retore the original recovery to let me flash again ?
          dun74fr
          Forum Posts: 16
          84
          2014/06/27 - 17:39
          Ok I managed to get out and reflash.
          I had to send "adb reboot bootloader" from my PC. Another user gave my other method with the power button but I did not try.
          During my reflashs, I tried MIUI. It is reactive and clean but I didn't managed to get the gapps installed.
          Nevertheless, my bluetooth problem is the same in MIUI and this custom rom. I couldn't try the original one because se download from baidu failed for my. Any one has it on is drive and can upload on another place for security ?
          Dun
          anu2013
          Thanks Received: 4
          85
          2014/06/28 - 09:20
          I flashed CWM recovery 6.0.31 for kk gen2 loader by Oma with RKAndroidTool 1.37
          worked on mini3 retina with this rom except sideload not to send file from PC
          It have small text but no problem to touch. I can install zip file,backup and restore rom and wipe everything.
          #My trick for to fix boot loop in to recovery
            -Use RKAndroidTool 1.37 in overclock folder to reflash boot.img
          #My trick for easy entry to bootloader with manual method
          1. In PC open RKAndroidTool 1.37
          2. Connect usb cable to tablet and PC
          3. Long press power button when screen off  release it and press again (do it fast)
          4. Tablet will go to bootloader, installed driver see show "Found ..." in RKAndroidTool 1.37
          5. for boot loop in recovery use the same method 1-4
          6. for boot loop in CWM recovery touch down to highlight color out off menu "-reboot system now" and  use the same method 1-4
          Hope to help another user
          Anucha.
          dun74fr
          Forum Posts: 16
          86
          2014/06/28 - 17:55
          Ok, after switching on various ROMs, I seriously consider it could be a HW problem.
          But I also checked out the logcat to see if there is any important information
          Here is the interesting part :
          I/ActivityManager(  469): START u0 {act=android.bluetooth.device.action.PAIRING_REQUEST flg=0x10000000 cmp=com.android.settings/.bluetooth.BluetoothPairingDialog (has extras)} from pid 12961
          D/LocalBluetoothManager(12961): setting foreground activity to null
          I/ActivityManager(  469): Displayed com.android.settings/.bluetooth.BluetoothPairingDialog: +232ms
          D/hwcomposer(  128): fb1 realy close!
          E/BTLD    (13247): ######################################################################
          E/BTLD    (13247): #
          E/BTLD    (13247): # WARNING : BTU HCI(id=0) command timeout. opcode=0xc20
          E/BTLD    (13247): #
          W/bt-hci  (13247): HCI Cmd timeout counter 1
          E/BTLD    (13247): #
          E/BTLD    (13247): # WARNING : BTU HCI(id=0) command timeout. opcode=0x405
          E/BTLD    (13247): #
          E/bt-hci  (13247): Num consecutive HCI Cmd tout =2 Restarting BT process
          I/BluetoothBondStateMachine(13247): bondStateChangeCallback: Status: 1 Address: 20:73:00:09:61:4E newState: 0
          D/BluetoothAdapterProperties(13247): Failed to remove device: 20:73:00:09:61:4E
          I/BluetoothBondStateMachine(13247): Bond State Change Intent:20:73:00:09:61:4E OldState: 11 NewState: 10
          W/BluetoothEventManager(12961): showUnbondMessage: Not displaying any message for reason: 9
          D/BluetoothHeadset(  675): Proxy object disconnected
          D/BluetoothTethering(  469): got CMD_CHANNEL_DISCONNECTED
          E/BluetoothTethering(  469): attempted to stop reverse tether with nothing tethered
          D/BluetoothHeadset(  469): Proxy object disconnected
          D/BluetoothPan(  469): BluetoothPAN Proxy object disconnected
          D/BluetoothManagerService(  469): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
          D/BluetoothA2dp(  469): Proxy object disconnected
          D/BluetoothManagerService(  469): BluetoothServiceConnection, disconnected: com.android.bluetooth.gatt.GattService
          D/BluetoothManagerService(  469): Message: 41
          E/BluetoothManagerService(  469): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED: 1
          D/BluetoothManagerService(  469): Calling onBluetoothServiceDown callbacks
          D/BluetoothManagerService(  469): Broadcasting onBluetoothServiceDown() to 4 receivers.
          W/MediaFocusControl(  469): RemoteControl: display android.media.IRemoteControlDisplay$Stub$Proxy@41d22888 died
          E/BluetoothAdapter( 2320):
          E/BluetoothAdapter( 2320): android.os.DeadObjectException
          E/BluetoothAdapter( 2320): at android.os.BinderProxy.transact(Native Method)
          E/BluetoothAdapter( 2320): at android.bluetooth.IBluetooth$Stub$Proxy.getState(IBluetooth.java:615)
          E/BluetoothAdapter( 2320): at android.bluetooth.BluetoothAdapter.getState(BluetoothAdapter.java:511)
          E/BluetoothAdapter( 2320): at android.bluetooth.BluetoothAdapter.getBondedDevices(BluetoothAdapter.java:925)
          E/BluetoothAdapter( 2320): at com.android.systemui.statusbar.policy.BluetoothController.updateBondedBluetoothDevices(BluetoothController.java:82)
          E/BluetoothAdapter( 2320): at com.android.systemui.statusbar.policy.BluetoothController.onReceive(BluetoothController.java:74)
          E/BluetoothAdapter( 2320): at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:768)
          E/BluetoothAdapter( 2320): at android.os.Handler.handleCallback(Handler.java:733)
          E/BluetoothAdapter( 2320): at android.os.Handler.dispatchMessage(Handler.java:95)
          E/BluetoothAdapter( 2320): at android.os.Looper.loop(Looper.java:136)
          E/BluetoothAdapter( 2320): at android.app.ActivityThread.main(ActivityThread.java:5017)
          E/BluetoothAdapter( 2320): at java.lang.reflect.Method.invokeNative(Native Method)
          E/BluetoothAdapter( 2320): at java.lang.reflect.Method.invoke(Method.java:515)
          E/BluetoothAdapter( 2320): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
          E/BluetoothAdapter( 2320): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
          E/BluetoothAdapter( 2320): at dalvik.system.NativeStart.main(Native Method)
          D/BluetoothManagerService(  469): Bluetooth State Change Intent: 12 -> 13
          D/BluetoothAdapter( 2320): 1207501208: getState() :  mService = null. Returning STATE_OFF
          As you can see, after 2 timeouts it reset the BT. During my google investigation I saw other users on other material resolving this with a kernel patch, but it do not explain why I am the only one having this on my tablet.
          If you have a clue..
          Dun
          lcw264630
          87
          2014/07/04 - 01:54
          I just use this ROM last night, the performance better than before.
          Many thanks!
          Keep go on
          lcw264630
          88
          2014/07/06 - 07:13
          I just operate this ROM 2 days, it suddenly boot several times.
          I found if I run several apps then quit. It will easy to boot !!
          Thanks for support.
          lcw264630
          89
          2014/07/07 - 03:40
          It seen when install memory apps very easy to crash.
          cabrera_gc
          90
          2014/07/20 - 00:53
          hi does anybody knows how to flashing the Rom original??? because of the Kasty ROM has not to much intern memory.
          53 Guest(s)
          2 Guest(s)
          Devices in use: Desktop (45), Phone (8)
          wogoko8553@yubua.com
          hellander
          elousstad
          relaytester
          revoltown
