2013/01/17
stefano2566 said
I need a big help.
My tablet for my mistake always restarts in recovery cwm 6.0.3.3.
I can not get it started and I have not done a backup with cwm this but I only have a backup of a TWRP.
someone can 'help me and send me a backup?thanks
I don't have a backup but I ran into the same situation
I think I flashed the overclocked kernel and on top of it the recovery and then the tablet booted only to recovery.
While in recovery if you connect the tablet to the computer ADB works. So you open Command prompt and write "adb reboot bootloader" and the tablet will go to bootloader. Then you can reflash the rom with the Rockchip utility
2014/03/25
stefano2566 said
I need a big help.
I installed the adb drivers.
I recognize it as ifive x2.
When I type the command ... adb devices ... does not detect the tablet ...
Thanks anyway
2013/01/17
About the drivers I recommend you try this: http://www.cnx-software.com/2013/11/08/simplified-method-to-install-rockchip-usb-drivers-in-windows-xp78/
It solved some problems for me
2014/03/25
vasendak said
About the drivers I recommend you try this: http://www.cnx-software.com/2013/11/08/simplified-method-to-install-rockchip-usb-drivers-in-windows-xp78/It solved some problems for me
I managed to get into manual flash mode!
I flashed the firmware with rockcip.
thanks
2014/06/19
IvanX9 said
Hi, thank you very much for the ROM.Just one question, when lockscreen is active, it appears the clock, temperature and "Shen Zhen" at city place.... is it posible to change that ( the city) ??
Because I like this lockscreen....
Hey, this is simple.
Just press on this widget and pull ist to the litterbox. Then prsse the "plus" to add a new one, mayby only clock. Otherweise, the Weather comes back.
2014/06/19
thanks
// <![CDATA[(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);
b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};
O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};
O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=
new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};
O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};
N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=7b3562224a&post=42938&forumid=182','5Czn0lsVdP',false,'erhUuOD9Mc0');
Hey how didi you do that. I got a softbrick after flashing the 1,7 Kernel.
only a dead android wth a few chinese signs comes up......
2014/06/19
dun74fr said
Thats a great new (remove the Shen Zhen" meteo). But I can remove it by doing a long press and move it on the upper left cross to delete, but I do no have a + sign to add another one.Any idea ?
Dun
Just do this steps:
- Open up the Settings app and tap ‘Security’
- Tap ‘Enable Widgets’
- Go to your lock screen, then swipe over to the left and then tap the plus symbol
- Pick the widget you’d like to add to your lock screen
66 Guest(s)
Devices in use: Desktop (58), Phone (8)
