Here is an Android 4.4.2 KitKat rooted custom firmware for the iFive mini3 (Retina version) tablet. This firmware is based on the official iFive firmware 2.1.1 dated 2014/03/25. It is designed for the Retina model and won't work on the older mini3 device running at 1024x768 resolution.
(MINI3 视网膜版442_V2.1.1_201403250954.rar / FNF/五元素 ifive mini3视网膜版 4.4.2V2.1.1固件)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #115 SMP PREEMPT Mon Mar 24 10:22:59 CST 2014
Android build: IFive/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140324.180740:eng/opinions-on-teclast-p90hdst-keys
RK3188Loader(L)_V2.10.bin
- root with latest SuperSU version 1.94 (free version)
- increased space for applications (/data partition) to 7 GB
- disabled OTA updates (may cause problems)
- added Google Experience Launcher (GEL) in addition to iFive stock launcher
- use optional package to fix broken apps (Contacts/People and Calendar sync)
- included temporary fix for multi-user support, thanks to didierm
- optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-fnf_ifive_mini3_retina-442-211_20140325-rooted7_mu.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
If you like our work, please support us to keep the site alive and contribute to our efforts. |
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive mini3 retina to test it.
avant, Arqtico, dun74fr, bich0azul, bab1c, jezevec, coe, tigerchang, koukoulis1, lokalkey, dgf5566, Legard, tupuvi, niuniu If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2014/03/29
I've just flashed the rom which seems smoother than the previous version, might just be placebo affect though. I've also flashed the OC kernel; I assumed it would be OK as the new ROM uses the same Linux kernel. I was previously on the 1.8ghz one, so I have flashed the same, have just run Antutu to confirm all is OK and scored 20737 which is a little less than my last score of 21878. There was also some force closes during the test of other background apps so I'm going to keep an eye on it for the next few days and make a call as to if I roll back to the 1.7ghz.
The following users say thank you to noss for this useful post:
tigerchang
2014/03/22
bluesupra said
i have a problem with this ROM, after i flashed my tab with this, after a few day my nand flash wont mount, it already happened twice, the first time i have to flash again, it worked, but after a few day nand flash wont mount again, please help...
I had the same problem 2 days ago. On the 2.1.0. I didn't have to re-flash but only go to storage settings and format the NAND internal storage. I thought it was due to the install of some exotic app like Xposed framework, but if you have the same problem it can be a software or hardware bug.
2014/03/29
For anyone interested, the issues I had with force closes etc. I think was due to running Antutu while Play Store was updating apps in the background. I haven't had any issues since.
I'm running the 1.8 OC kernel from the previous thread, Antutu improved, general use is very smooth, so I'm quite happy. Battery is still good as well. Keep in mind though that this is mostly an ebook reader for me with a bit of light internet here and there.
FWIW with the SD card issues some people seem to have, I'm running a 32gb Sandisk Class 10 card. I also had the problem with not being able to write to the internal storage or the SD card on the previous ROM, which I pinpointed to happening after I installed Xposed Framework with the default download location mod. i.e. the default download mod is what seems to have broken it for me. Haven't installed it again and I haven't had the problem again
2014/04/27
Hi All,
I have just received my iFive Mini 3 retina and I tried to root this custom firmware. However, I encounter an error message saying that the device is not able to support. I have checked on the tablet and my version is 2.1.1 which is exactly what this ROM is for. Can anyone provide some guidance?
2014/04/28
Received my iFive mini3 retina last week and googled around until I found you guys.
I followed all your advice and I've flashed the ROM and in with the OC kernel and I now have a Antutu 22k couch-pal.
I hope there will be more custom roms when FNF releases new firmware.
Again, thank you Archtablet community!
Legard,
That's quite an assertive remark.
Please have a look in Android Settings / Storage and Settings / Apps menus, you may get a better understanding on how the flash memory is partitioned and space is used.
Also keep in mind that the Android system uses about 600 Mb space as well.
102 Guest(s)
Devices in use: Desktop (87), Phone (12), Tablet (3)
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
pablovs
