[ ROM ] FNF iFive mini3 (retina version) Android 4.4.2 KitKat custom rooted firmware based on v2.1.0 (2014/03/07)
shinxsetsuna
61
2014/05/29 - 22:21
the mini3 retina has the same specs same gpu same everything except the screen size wouldnt just changing that aspect of this rom to fit the 9.7 version work ?
Picota92
62
2014/06/13 - 01:49
Hi i have some questions:
I really dont know how to flash the rom i have rockchip 1.7 and my tablet appears like a pink square and i dont know if ive installed the drivers properly (i dont think so)
And another thing is that updated via ota and now i dont have battery? Like it looks black and at 0% wth
PS: Okay finally i could flash it i used a tool to install the drivers here and it worked fine. Thanks.
trucolo
63
2014/06/20 - 15:18
Hi guys,
my ifive mini 3 retina has arrived on the past week, then I flashed the Kasty Rom and overclocked it to 1.8GHz, however the tablet is laggy when browsing on the Internet, are you having the same experience? Is there any way to make it smoother? Besides that, the wifi reception is very unstable too Cry
ved
64
2014/08/01 - 18:22
hi,
recently I bought this tablet and some OTA update I accepted, dont remember but I think it was firmware update. I loaded your latest ROM and now tablet is not booting any more....any ROM update?
tnx!
Thanks Received: 3177
65
2014/08/01 - 19:38
So you flashed our custom firmware using Rockchip Batch Tool ? Did you use Restore button ?
Are you sure your device is an iFive Mini 3 retina model ?
ved
66
2014/08/01 - 19:54
thank you for prompt answer!
yes its retina model RK3188 chipset
and i did as you wrote, just RESTORE button.
it is recognized in device manager, ADB is there but I am not even able to repeat the procedure.
it  says:
no device
ADB driver version is:
27.08.2012
v 7.0.0.1
is that correct driver?
67
2014/08/01 - 20:08
Are you sure you are using the same cable and same USB port on the computer like when you flashed with Rockchip Batch Tool previously ?
Does the square number 1 in the Connected devices panel on Rockchip Batch Tool changes color when you connect the tablet ?
ved
68
2014/08/01 - 20:15
yes i am sure
when i start RKBatchTool.exe it doesnt see device any more...before it was in pink color, then i pressed SWITCH and then it went to green. then i pressed RESTORE button.
after that tablet is in bad state, not booting any more....
now i dont even see pink number 1 (connected devices)
its the same cable and the same USB port
ved
69
2014/08/01 - 20:16
but maybe its important thing to say that two weeks ago i had OTA update...maybe that is causing the problem now
70
2014/08/01 - 20:28
The OTA update you have applied shouldn't really matter as flashing a new firmware with Erase on Rockchip Batch Tool should format the tablet and reinstall a fresh system.
In your case, what needs to be done is to put the tablet in bootloader mode so it's recognized by Rockchip Batch Tool (green square). This can usually be achieved using hardware buttons (power/volume / reset pinhole) on the tablet. I am not sure about which should work on your mini3 retina, others iFive owners may help you on that or you can read about similar procedures in our other iFive forum sections.
bklm1234
Forum Posts: 44
Thanks Received: 11
71
2014/08/01 - 20:28
try Riley's ROM.  It uses a different mechanism to flash.  Hopefully it works for you. http://www.freaktab.com/showthread.php?12525-iFive-Mini-3-Retina-RileyROM-1-1-KitKat
ved
72
2014/08/01 - 20:37
tnx for this but this link is not active any more for download
ved
73
2014/08/01 - 20:38
my model doesnt have volume button on it, only power OFF/ON button. how can I set it in bootloader mode?
bklm1234
Forum Posts: 44
Thanks Received: 11
74
2014/08/01 - 23:34
Send Riley a message.  He's very helpful
dun74fr
Forum Posts: 16
75
2014/08/02 - 01:56
You said the adb is working.. I found useful to send the command :
adb reboot-bootloader
to reboot in bootloader mode and managed to reflash.
Hope it help
Dun
38 Guest(s)
Devices in use: Desktop (36), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
