[ ROM ] FNF iFive mini3 (retina version) Android 4.4.2 KitKat custom rooted firmware based on v2.1.0 (2014/03/07)
kns
46
2014/04/09 - 12:22
Compass and pressure sensors do not work
avant
Forum Posts: 31
Thanks Received: 4
47
2014/04/11 - 02:15
Just a quick update from my side: after realizing that the battery drain of the 1,8GHz OC kernel is *very* high, I switched back to the 1,7GHz OC kernel and I'm happy now since weeks. I saw some stability issues right after deep sleep, so I've set the min frequency to 504MHz and my issues are entirely gone now.
My mini3 retina is now a perfect companion for my daily business tasks.
Jo
The following users say thank you to avant for this useful post:
tupuvi
fa99x24
48
2014/04/11 - 09:11
Thank you for this great rom! Just one question, why is "auto brightness" missing?
yourstruly_astro
Forum Posts: 11
49
2014/04/12 - 11:46
any of you here who have the default ebook reader of ifive mini models that works on this rooted rom?
hendrikx
50
2014/04/13 - 16:16
Anyone know if it is possible to increase the maximum brightness of this tabet? When compared to my ipad mini retina it id very dark... Full brightness is equal to 50% brightness on the ipad..
Also, stil no success in overclocking my tablet. Keeps rebooting on both 1704 and 1800mhz, guess i got to stay with the origional clock frequence..
Arqtico
51
2014/04/17 - 10:18
With this rom, android can not mount /system/ in R/W mode, for example, integration a update of a system app with Titanium Backup.
Is it a issue only for my or it is a rom bug?
avant
Forum Posts: 31
Thanks Received: 4
52
2014/04/18 - 06:11
... And since some hours ago, there is a new ROM version for the mini3 retina on ifive.com.cn available!
Cheers,
Jo
robertmeister
53
2014/04/18 - 07:46
Cheers,
Jo
Hi! Could you post the direct link, please?? I can't find it. Thanks!
54
2014/04/18 - 11:33
robertmeister
55
2014/04/18 - 20:53
robertmeister said
Cheers,
Jo
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=95729db2f9&post=41486&forumid=182','W4fY5kTX1u',false,'IR5edUxeV70');
Nevermind! i found it, here i leave the 2 links of the OFFICIAL UPDATED ROM v.2.1.0, the 1st link is of the original post, and the 2nd one of the download page Cool
1. http://www.5fans.com.cn/thread-109179-1-1.html
2. http://pan.baidu.com/s/1bnvhnvp?qq-pf-to=pcqq.c2c (379.55mb)
avant
Forum Posts: 31
Thanks Received: 4
56
2014/04/20 - 08:42
koukoulis1
wullie1974
Forum Posts: 18
57
2014/04/23 - 23:11
i'm having a issue with SD card, when I install a game from Play store and it needs to use SD card I get an error to say I need an SD card. I have a 2GB one installed.
Any Ideas? maybe custom ROM??
trucolo
58
2014/04/24 - 15:18
Hi all,
I bought ifive mini 3 retina version and it is already on the way to here, after seen many discussions about OC Kernel and custom roms, I would like to know if the device is laggy or slow in some way with the stock rom, I have already seen a bunch of reviews and did not notice it. Can you please share your experiences with the tablet?
Thanks!
shinxsetsuna
59
2014/05/29 - 21:57
does anyone know if this rom can work for the 9.7 version of the ifive mini 3 ?
60
2014/05/29 - 22:09
shinxsetsuna,
It's quite unlikely that the mini3 retina firmware will work on a different model.
90 Guest(s)
Devices in use: Desktop (65), Phone (25)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
