[ ROM ] FNF iFive mini3 (retina version) Android 4.4.2 KitKat custom rooted firmware based on v2.0.9 (2014/02/14)
2014/02/19 - 18:29
Here is an Android 4.4.2 KitKat rooted custom firmware for the iFive mini3 (Retina version) tablet. This firmware is based on the official iFive firmware 2.0.9 dated 2014/02/14. It is designed for the Retina model and won't work on the older mini3 device running at 1024x768 resolution.
(Ifive MINI3视网膜_442_V2.0.9_201402141423.rar / Ifive MINI3视网膜_442_V2.0.9_201402141423.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Linux Kernel: Linux version 3.0.36+ (root@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #83 SMP PREEMPT Fri Feb 14 13:37:17 CST 2014
Android build: IFive/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140214.140328:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.93 (free version)
  • disabled OTA updates (may cause problems)
  • added Google Experience Launcher (GEL) in addition to iFive stock launcher
  • use optional package to fix broken apps (Contacts/People and Calendar sync)
  • included temporary fix for multi-user support, thanks to didierm
  • optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-fnf_ifive_mini3_retina-442-209_20140214-rooted4_mu.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive mini3 retina to test it.
tipolam, bich0azul
yourstruly_astro
Forum Posts: 11
2014/02/20 - 06:01
I tried to install this custom rooted ROM but my MINI3 does not boot. Please fix.
tipolam
2014/02/20 - 08:12
This ROM is for mini3 "retina version".
2014/02/20 - 08:36
Thanks for the tip tipolam, actually that explains the bootanim resolution was double the size from the regular mini3. It's really bad FNF use the same name for two different products.
I am currently removing our custom firmware download and will clarify about the proper model in post #1.
yourstruly_astro
Forum Posts: 11
2014/02/20 - 11:16
I see. I thought this was for the first gen Mini3. Is there any new firmware for the first gen mini3?
2014/02/22 - 15:43
For those with a Mini 3 retina model, I have fixed the firmware, see post #1:
I haven't heard of updates for the Mini3 older (non retina) model.
grindio
2014/02/23 - 02:10
Would this rom run on the 9.7 retina tablets such as visture v97,  vido n90fhdrk?
soko
2014/02/23 - 17:58
Hi Guys I am new here.I would like to ask if there is a video of the new ifive mini3 retina version because i would like to buy it but I cannot find a video .Thanks in advance
tipolam
2014/03/02 - 04:41
This ROM work fine!
Thanks a lot.
miroslavgol
2014/03/05 - 03:36
Hi, guys! I need help. I flashed mini 3 retina with firmware for non retina mini 3. And now device don't boot. When I connect it to PC to flash with normal firmware it turning on but rockchip batch see device only for 5 or 10 seconds and then it's repeating and repeating.  Plese, help me! What can I do to make my mini3retina working.
P.s.
Sorry for my English
tipolam
2014/03/07 - 15:42
Official Firmware update for ifive mini3 retina
MINI3 视网膜版_442_V2.1.0_201403071015.rar
http://pan.baidu.com/s/1bnvhnvp?qq-pf-to=pcqq.c2c
2014/03/07 - 15:53
I should post a rooted custom firmware tonight.
2014/03/07 - 19:17
granderjoree
2014/03/12 - 04:15
I flashed my mini 3 and it worked but with one exception. I was using this BT controller I got from google play, its an app where I can use my phone as a controller for emulated roms in my mini 3 and it connects using bluetooth. After playing for 30 mins and after disconnecting the bluetooth connection, my mini 3 doesn't rotate the screen anymore. It's constantly on landscape mode.
It's only solution is to reset my mini 3 and it will get back to normal. It's just a small bug that I noticed. Thanks for the firmware ROMAN! :)
mtodak
2014/03/12 - 13:44
iFive Mini 3 Retina with stock 4.4.2 rom owner. ArcTool shows error 28 when trying to install downloaded generic CWM - no root i guess , so how to root it please?
Rockchip Batch Tool - how to enter recovery mode (or it has to be bootloader mode?) in order to flash rom using rockchip b. tool? ArcTool reboot options does not work.
Proper drivers please? http://www.cnx-software.com/2013/11/08/simplified-method-to-install-rockchip-usb-drivers-in-windows-xp78/  does not work. Tried on 3 systems.
58 Guest(s)
Devices in use: Desktop (48), Phone (10)
cutierogue
