- CWM 6.0.3.1 recovery
- system ext4
- latest kernel
- internal Storage 4,0 GB
- TabletUI & Multi-User
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial, audio)
- latest hosts, su, su-binary, busybox
- MX Video-Player, Play Music & FX Sound
- Reboot Menue, Kernel Tuner, Pimp my Rom
- Dateimanager HD (Root)
- Nova Launcher
format_NAND Instructions see download pack (written for Chuwi V88).
Please do not install OTA-updates.
admin, elvisfriendly, uguiPer aspera ad astra, we rock the Tablets !
Please find enlcosed the instructions from ifive.
Unfortunately in Chinese ... sounds like hold power for 10 sec and plug usb in.
elvisfriendlyPer aspera ad astra, we rock the Tablets !
You need to install the format_NAND fix via CWM.
You can try (not sure if it works): http://crewrktablets.arctablet.com/?wpfb_dl=948
For installation you can also use the stock recovery: http://crewrktablets.arctablet.com/?wpfb_dl=910
Can you navigate in CWM by usb-mouse?
2013/09/19
OK, I am just not getting the Beasty boy into Flash Mode to Update..
Tried the Hold Power for 10 sec's and then plug the USB in, it simply reboots the device back up and then gets me back to the login screen.
I just can't get it to Flash Mode, never had issues with other models, as they had the volume option..
Grrrrr, any other suggestions?
Currently Online: yazansp
69 Guest(s)
Devices in use: Desktop (64), Phone (6)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
