Ifive mini 4s
Ifive mini 4s
121
2017/07/15 - 18:17
Did you unzip the file?
Alex2zl
Forum Posts: 92
122
2017/07/15 - 18:19
of course)
123
2017/07/15 - 18:28
Try again with attached parameter. Parameter file defines the partition layout. So Lower Format, pls.
Alex2zl
Forum Posts: 92
124
2017/07/15 - 18:45
The same behavior as in post 116.
I took los v1.2.5, replaced the Kernel and Resource 15 version, in RKAndroidTool I replaced the loader with version 2.30.10, the parameter cm14_2 and the CWM v4.0_qad. Clicked LowerFormat and Run
125
2017/07/15 - 18:47
Flash only attached misc.
Alex2zl
Forum Posts: 92
126
2017/07/15 - 18:55
Installed only misc, with no lower format. Only the logo rockchip kernel appears and everything, in cwm does not even come
127
2017/07/15 - 19:09
Does not boot into CWM? What is on the screen? Pls do dmesg and logcat log (adb should be there).
Alex2zl
Forum Posts: 92
128
2017/07/15 - 19:24
Displayed simply the logo of the rockhip kernel, the next boot does not go (not cwm, not the android). I can manually enter cwm (power + volume -), then cwm is loaded, but the same error is displayed below (116 post)
129
2017/07/15 - 19:26
What is the Rom size of the tab?
Alex2zl
Forum Posts: 92
130
2017/07/15 - 19:32
32GB ROM
131
2017/07/15 - 19:47
Ok, last test. Do as advised in post #115 & change Loader v2.30.10 & change misc from post #125.
Alex2zl
Forum Posts: 92
132
2017/07/15 - 20:36
OK, in about an hour I'll be home again and try. I take firmware and cwm from 115 posts. I replace the kernel and resource by version 15, replace the bootloader with version 2.30 and replace with the last misc. I do lower format and run
Alex2zl
Forum Posts: 92
133
2017/07/15 - 22:26
Did. The same as in the 128th post
134
2017/07/15 - 22:37
Flash this kernel, nothing else: http://crewrktablets.arctablet.com/?wpfb_dl=3134
Alex2zl
Forum Posts: 92
135
2017/07/15 - 22:50
Again, cleanly: LOS 1.2.5 + CWM v4 and replace the kernel and the resource 16?
Or LOS 1.2.5 + cwm 4.0 + loader 2.3 + misc empty + replace the kernel and resource 16?
54 Guest(s)
Devices in use: Desktop (50), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
