Ifive mini 4s
Ifive mini 4s
Alex2zl
Forum Posts: 92
106
2017/07/14 - 23:13
In cwm, the computer does not see the tablet, only in loader mode, but, as I understand, in this mode it is impossible to get logs through aiolog. Install twrp and get the logs?
107
2017/07/14 - 23:15
Yes.
Alex2zl
Forum Posts: 92
108
2017/07/14 - 23:21
Installed twrp from the LOS firmware, with misc and parameter and LowerFormat
109
2017/07/14 - 23:42
No Lower Format, pls. This will wipe the partition layout.
Test kernel #14: http://crewrktablets.arctablet.com/?wpfb_dl=3131
Install again all images.
Alex2zl
Forum Posts: 92
110
2017/07/15 - 00:01
Kernel 14. No changes: in cwm the same errors. Installed twrp from the LOS firmware with misc and parameter, without LowerFormat. Touchscreen does not work anywhere. Logs in the attachment
Alex2zl
Forum Posts: 92
112
2017/07/15 - 00:20
Unfortunately, everything is the same as in kernel 14: cwm errors, twrp does not work with touchscreen.
Thanks for trying
113
2017/07/15 - 00:23
Hard Power-off. Power. Is it booting in Android?
Alex2zl
Forum Posts: 92
114
2017/07/15 - 00:26
No, it loads again either cwm or twrp
115
2017/07/15 - 16:20
Here is a fresh CWM: http://crewrktablets.arctablet.com/?wpfb_dl=3133
Download the lastet build v1.2.5: http://crewrktablets.arctablet.com/?wpfb_dl=3128
Change kernel/resource #15 in folder rockdev/Image.
Load CWM by clicking on the empty box.
Click Lower Format, then Run.
In CWM do Wipe Data and when screen comes back do Hard Power-off (CWM is just a quick and dirty one :-).
Reboot.
Alex2zl
Forum Posts: 92
116
2017/07/15 - 16:55
Did. After the firmware, cwm is loaded, but at the bottom there is an error (in the attachment), then the tablet, apparently, again reboots. Did Hard Power-off, after that the tablet is still loaded in cwm
IMG_20170715_174652.jpgImage Enlarger
117
2017/07/15 - 17:29
Pls do again changing the attached Loader.
Alex2zl
Forum Posts: 92
118
2017/07/15 - 17:39
No changes, everything is the same
119
2017/07/15 - 17:46
Pls do again changing the attached Parameter.
Alex2zl
Forum Posts: 92
120
2017/07/15 - 18:00
With the loader 2.30.10 and with this parameter after the logo the rockchip kernel screen goes blank and nothing happens
43 Guest(s)
Devices in use: Desktop (40), Phone (3)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
