See post #80.
Sorry, wrong link: http://crewrktablets.arctablet.com/?p=5336
Test kernel #12: http://crewrktablets.arctablet.com/?wpfb_dl=3129
Pls flash again the complete package, incl. Lower Format.
Use the Lineage pack as is. Just change kernel, resource and CWM.
Test kernel #13: http://crewrktablets.arctablet.com/?wpfb_dl=3130
2017/07/01
I do so. I take the archive with iFive_Air_LineageOS_14.1_7.1.2_v1.2.4 firmware. I replace the files kernel and resource in the folder rockdev \ Image. In RKAndroidTool_v2.35 instead of TWRP I specify the path to CWM. I press LowerFormat and Run. At 13 kernel in the recovery are the same errors. In the mount and storage section, when you try to mount system partitions, date and cache, "error mounting"
Just do a factory reset and reboot (no is the answer).
The errors are ok. CWM can't mount last log 🙂
Wiping looks good. What is at the end? The tab reboots?
2017/07/01
The errors are ok. CWM can't mount last log 🙂Wiping looks good. What is at the end? The tab reboots?
- Oma -Â Â
Yes, after the message Formatting / cache ... The tablet reboots again in CWM, with the same errors.
If I click reboot system now, the tablet just turns off
Ok. Hard Power off - press Power for about 12 sec. Then Power on. What happens?
Let me have dmesg and last_kmsg log.
68 Guest(s)
Devices in use: Desktop (59), Phone (9)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
