Any feedback on the latest test kernel before summer holiday break?
2017/07/01
Any feedback on the latest test kernel before summer holiday break?- Oma -
Tried to install the firmware with the kernel 9 and 10, appears logo rockchip, goes into the TWRP, but the TWRP touch screen does not work. Correspondingly, further TWRP does not go, do not do wipe data. If we replace TWRP with CWM, there are errors in the recovery: E: Cant open and the path
I understandably explained?
Ok, screen is there now 🙂
Try CWM from this pack: http://crewrktablets.arctablet.com/?wpfb_dl=2804
2017/07/01
Ok, screen is there now 🙂Try CWM from this pack: http://crewrktablets.arctablet.com/?wpfb_dl=2804
In twrp the touchscreen also does not work. Also at the first start a blue spot appeared, which then disappeared. + Twrp loaded for a long time. And the backlight of the screen flashes slightly on the right
Test kernel #11: http://crewrktablets.arctablet.com/?wpfb_dl=3126
2017/07/01
Test kernel #11: http://crewrktablets.arctablet.com/?wpfb_dl=3126- Oma -
In twrp the touchscreen does not work either. TWRP_3.0.0.0_MM_v1.0 similarly, the touchscreen does not work
Is the screen better now? Is the swipe somewhere else on the screen?
Can you pls check if an usb mouse is working?
Can you also pls try to get a dmesg log via PC tool: https://forum.xda-developers.com/showthread.php?t=1944776
2017/07/01
In the attachment dmesg log via PC tool: LOS 14, kernel 11, standart TWRP
Unfortunately, I do not yet have an OTG cable, still in transit
As well as a link to the video with the first inclusion on the 11th kernel
https://drive.google.com/open?id=0Bxvs9ZzcSC37OXBuQllmU25UZU0
<6>[ 1.597827] input: gslX680 as /devices/ff160000.i2c/i2c-4/4-0040/input/input1
Can you pls swipe elsewhere on the screen?
2017/07/01
I used CWM from this post
http://crewrktablets.arctablet.com/?wpfb_dl=2389
There is a version of CWM CWM_CrewRKTablets_v1.1. In the attached picture version 3.0. When downloading version 1.1, errors appear in the recovery, the wipes can not be made
67 Guest(s)
Devices in use: Desktop (57), Phone (10)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
