Ifive mini 4s
Ifive mini 4s
Joeblah
Forum Posts: 33
61
2017/07/06 - 22:58
I was basically pointing out that it was a new hardware revision and I have not had any of those problems on the original version.
dfahren
62
2017/07/07 - 13:58
This is your hardware:
PMU - Ricoh 619
7.9 inch IPS 10-points Capacitive Screen with 2048 x 1536 Resolution
Touch Controller - Goodix GSLX680
Gravity Sensor - lsm330
Geomagnetic Sensor - ak8963
Gyroscope - lsm330_gyro
Audio - RT5616
Wifi - AP6335 (802.11ac 2.4G/5G + BT4.0 + FM)
Rear Cam - OV8856
Front Cam - GC2155
Hi all,
FNF issued a new revision of this min 4S tablet. Its serial number starts with a "B". I have got one of those newer tablets. I "grepped" a dmesg log to see if other hardware could be found than what OMA extracted. Here is what I got:
[ 0.000000] Linux version 3.10.0 (root@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #2 SMP PREEMPT Fri May 19 09:25:27 CST 2017
[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
[ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00020000@0x0039A000(radical_update),-@0x003BA000(userdata) storagemedia=emmc loader.timestamp=2017-05-08_17:18:23
[ 0.358911] SMP: Total of 4 processors activated (192.00 BogoMIPS).  "Wrong calculation of bogo mips!"
[ 0.392319] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc11c6ecc (version 0.1)
[ 0.394496] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.394520] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.394540] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.394565] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.394651] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.394719] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.394784] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.394849] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.394914] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.394980] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.395045] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.395110] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.395182] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.395250] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.395266] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.395281] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.395296] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.395368] gpiochip_add: registered GPIOs 0 to 23 on device: gpio0
[ 0.395434] gpiochip_add: registered GPIOs 24 to 55 on device: gpio1
[ 0.395491] gpiochip_add: registered GPIOs 56 to 87 on device: gpio2
[ 0.395548] gpiochip_add: registered GPIOs 88 to 119 on device: gpio3
[ 0.395610] gpiochip_add: registered GPIOs 120 to 151 on device: gpio4
[ 0.395665] gpiochip_add: registered GPIOs 152 to 183 on device: gpio5
[ 0.395720] gpiochip_add: registered GPIOs 184 to 215 on device: gpio6
[ 0.395779] gpiochip_add: registered GPIOs 216 to 247 on device: gpio7
[ 0.395835] gpiochip_add: registered GPIOs 248 to 279 on device: gpio8
[ 0.395890] gpiochip_add: registered GPIOs 280 to 311 on device: gpio15
[ 0.395913] rockchip_interrupts_register:bank_num=7
[ 0.408727] DDR DEBUG: version 1.00 20150126
[ 0.408752] DDR DEBUG: Channel a:
[ 0.408763] DDR DEBUG: LPDDR2 Device
[ 0.408778] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Total Capability=1024MB
[ 0.408789] DDR DEBUG: Channel b:
[ 0.408798] DDR DEBUG: LPDDR2 Device
[ 0.408812] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Total Capability=1024MB
[ 0.408824] DDR DEBUG: addr=0x10d1000
[ 0.408835] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.408845] DDR DEBUG: socAddr[0]=0x10d1000, socAddr[1]=0x10d1100
[ 0.408857] DDR DEBUG: chAddr[0]=0x10d1000, chAddr[1]=0x10d1000
[ 0.408870] DDR DEBUG: dtar[0]=0x1021a000, dtar[1]=0x1021a000
[ 0.408925] DDR DEBUG: init success!!! freq=396MHz
[ 0.408934] DDR DEBUG: Channel a:
[ 0.408948] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=2,2 extra clock, DGPS=180,270
[ 0.408964] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=3,3, DGSL=2,2 extra clock, DGPS=270,270
[ 0.408979] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,3, DGSL=2,2 extra clock, DGPS=180,270
[ 0.408994] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,3, DGSL=2,2 extra clock, DGPS=180,270
[ 0.409009] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.409020] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.409031] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.409040] DDR DEBUG: Channel b:
[ 0.409053] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=3,3, DGSL=2,2 extra clock, DGPS=270,270
[ 0.409068] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=2,2 extra clock, DGPS=270,270
[ 0.409083] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=3,3, DGSL=2,2 extra clock, DGPS=270,270
[ 0.409098] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=3,3, DGSL=2,2 extra clock, DGPS=270,270
[ 0.409112] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.409123] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.409134] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.452753] ricoh619_i2c_probe,line=825
[ 0.550526] input: ricoh619_pwrkey as /devices/ff650000.i2c/i2c-0/0-0032/ricoh619-pwrkey/input/input0
[ 0.558006] ricoh619-rtc ricoh619-rtc: PMU: print_time *** rtc-time : 7/7/2017 9:29:2 *****
[ 0.643701] rk3288-lcdc lcdc0: lcdc0: dclk:230000000>>fps:60
[ 1.121573] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.121592] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.122880] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.122899] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.124009] arm_release_ver of this mali_ko is 'r12p0-04rel0', rk_ko_ver is '13', built at '14:45:47', on 'May 17 2017'.
[ 1.129294] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 1.132779] mali ffa30000.gpu: Probed as mali0
[ 1.132898] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 389; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-2a99ac6', rk_ko_ver is '5', built at '14:45:52', on 'May 17 2017'.
[ 1.133113] Mali: Mali device driver loaded
[ 1.139153] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.139164] ehci-platform: EHCI generic platform driver
[ 1.141717] EHCI: ehci_rk_probe e2f00000 e2f00010
[ 1.154887] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.154903] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.154917] usb usb1: Product: EHCI Host Controller
[ 1.154930] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.154943] usb usb1: SerialNumber: ff500000.usb
[ 1.155385] hub 1-0:1.0: USB hub found
[ 1.155408] hub 1-0:1.0: 1 port detected
[ 1.155579] EHCI: ehci_rk_probe ok
[ 1.155689] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.155905] ohci-platform: OHCI generic platform driver
[ 1.157027] usb20_otg: version 3.10a 21-DEC-2012
[ 1.157798] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.157825] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.157853] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.157908] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.157924] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.157938] usb usb2: Product: DWC OTG Controller
[ 1.157950] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.163423] GSLX680 Enter gsl_ts_probe
[ 1.163771] input: gslX680 as /devices/ff160000.i2c/i2c-4/4-0040/input/input1
[ 6.390161] sensor_register_slave:lsm330,id=23
[ 6.390175] sensor_register_slave:akm8963,id=26
[ 6.390185] compass_akm8963_init:---test
[ 6.390195] sensor_register_slave:lsm330_gyr,id=44
[ 6.393325] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 6.397571] genirq: Flags mismatch irq 192. 00002002 (rtc_hym8563) vs. 00002008 (ricoh619)
[ 6.397617] hym8563_probe:fail to request irq = 192, ret = 0xfffffff0
[ 6.480646] USB Video Class driver (1.1.1)
[ 6.480658] CamSys driver version: v0.33.0, CamSys head file version: v0.11.0
[ 6.481617] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 6.482946] rockchip_temp_probe,line=379
[ 6.538156] rtk_btusb: Realtek Bluetooth USB driver module init, version 3.0
[ 6.543876] Synopsys Designware Multimedia Card Interface Driver
[ 6.613720] mmc0: new HS200 MMC card at address 0001
[ 6.613960] mmcblk0: mmc0:0001 BJNB4R 29.1 GiB
[ 6.614220] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 6.614231] misc: 0x000800000 -- 0x000c00000 (4 MB)
[ 6.614240] resource: 0x000c00000 -- 0x001c00000 (16 MB)
[ 6.614249] kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[ 6.614257] boot: 0x002c00000 -- 0x004c00000 (32 MB)
[ 6.614266] recovery: 0x004c00000 -- 0x006c00000 (32 MB)
[ 6.614274] backup: 0x006c00000 -- 0x00a000000 (52 MB)
[ 6.614282] cache: 0x00a000000 -- 0x012000000 (128 MB)
[ 6.614290] kpanic: 0x012000000 -- 0x012400000 (4 MB)
[ 6.614299] system: 0x012400000 -- 0x072400000 (1536 MB)
[ 6.614307] metadata: 0x072400000 -- 0x073400000 (16 MB)
[ 6.614315] radical_update: 0x073400000 -- 0x077400000 (64 MB)
[ 6.614324] userdata: 0x077400000 -- 0x747800000 (27908 MB)
[ 6.614346] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 6.658634] input: rk29-keypad as /devices/ff100000.adc/key.43/input/input2
[ 6.695776] rockchip-rt5616 rockchip-rt5616.39: rt5616-aif1 <-> ff890000.rockchip-i2s mapping ok
[ 6.698861] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 6.699313] [BT_RFKILL]: ap6335 device registered.
[ 6.711334] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 6.712639] sensor_chip_init:gs_lsm330:devid=0x40,ops=0xc104f890
[ 6.713845] input: gsensor as /devices/ff140000.i2c/i2c-1/1-001e/input/input3
[ 6.714292] sensor_chip_init:ak8963:devid=0x48,ops=0xc104f8ec
[ 6.714821] input: compass as /devices/ff140000.i2c/i2c-1/1-000d/input/input4
[ 6.714953] sensor_probe:initialized ok,sensor name:akm8963,type:3,id=26
[ 6.715267] sensor_chip_init:lsm330_gryo:devid=0xd4,ops=0xc104f9dc
[ 6.823107] input: gyro as /devices/ff140000.i2c/i2c-1/1-006a/input/input5
[ 6.823246] sensor_probe:initialized ok,sensor name:lsm330_gyr,type:4,id=44
[ 6.830630] input: rockchip_headset.42 as /devices/ff100000.adc/rockchip_headset.42/input/input6
[ 6.831196] ALSA device list:
[ 6.831201] #0: RK_RT5616
[ 7.351689] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[ 7.357529] Dongle Host Driver, version 1.201.59.6 (r506368)
[ 7.357529] Compiled in drivers/net/wireless/bcmdhd on May 17 2017 at 14:46:42
[ 7.381803] keychord: using input dev ricoh619_pwrkey for fevent
[ 7.381816] keychord: using input dev rk29-keypad for fevent
[ 7.522180] init: Warning! Service zygote needs a SELinux domain defined; please fix!
[ 9.590718] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8856) register success
[ 9.867262] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: GC2155) register success
[ 18.530898] Current WiFi chip is AP6255.
[ 18.540916] Dongle Host Driver, version 1.201.59.6 (r506368)
[ 19.035147] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm43455c0_ag.bin
[ 19.035184] Final nv_path=/system/etc/firmware/nvram_ap6255.txt
[ 19.378885] NVRAM version: AP6255_NVRAM_V1.0_29052015
CPU: RK3288 with flattened device tree
DRAM: 2 LPDDR2 memory chips 1GB each accessed at ~400MHz
PMU: Ricoh 619, Power mgmt. system device, thermal shutdown,
battery voltage detector, power-on key input detector,
Li-Ion battery charger, real time clock with alarm,
interrupt controller, LCD backlight driver
RTC: HaoYu Micro. HYM8563 real time clock / calendar conflicts with Ricoh 619 (s.a.) probably driver issue. Hardware not inbuilt.
DMA: PrimeCell PL330 implements TrustZone secure technology (direct memory access)
Graphics: Inbuilt Mail GPU with id 0x750
USB: Standard Linux EHCI (USB 2.0) and OHCI (USB 1.1) controllers, DWC OTG controller (implements USB host function)
Touch: Silead GslX680 - Capacitive Touch Screen Controller
3D accelerometer: STMicro. LSM330
3D gyroscope: STMicro. LSM330
Geomagnetic Sensor: Asahi Kasei Microdev. AK8963 3-axis electronic compass IC (end-of-life no longer recommended, so it's old crap)
Temp: Rockchip inbuilt
Bluetooth USB: Rockchip inbuilt
Headset detect: Rockchip inbuilt
eMMC: Samsung BJNB4R 29.1 GiB
Audio codec: Realtek Micro. RT5616
Wifi: Ampak AP6255, but chip=0x4345 (Broadcom BCM4345(5) 802.11ac, 2.4/5GHz BT 4.1/BLE, FM)
Bluetooth: AP6335 (wrong label in log! Is in fact AP6255, driver works)
Rear Cam: OmniVision OV8856 1/4 inch 8 mpix, full res @ 30 fps, 1080p @ 60fps, smallest sensor on the market
Front Cam: Galaxycore GC2155 1/5 inch 2 mpix
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
63
2017/07/07 - 15:01
dfahren said
130|root@IFive_US:/ # uname -a
Linux localhost 3.10.0 #2 SMP PREEMPT Fri May 19 09:25:27 CST 2017 armv7l
excerpt from build.props
ro.build.description=IFive_US-userdebug 6.0.1 MXC89K user.root.20170519.105734 release-keys
ro.build.fingerprint=IFive/IFive_US/IFive_US:6.0.1/MXC89K/root05191101:userdebug/release-keys
does this help?
Yes, this is what i thought, this is a "new" kernel for the "new" B - Revision.
I don't know exactly the differences, but i would recommend you, that you flash the Stock Firmware with Erase MMC in Factory Tool first. But i guess, if the kernel from oma boot on the "old" rev, it will also boot on the "new" rev.
Because, according to your dmesg, there is no really differences...
The following users say thank you to MiGHT. for this useful post:
dfahren
dfahren
64
2017/07/07 - 15:43
Might, thanks for the info, but hold on for a second ....
First of all, what are the real differences between the old and the new revision of this tablet.
Well, as far as I can tell the only difference is an alternative Wifi chip. Old revision uses AP6335, which is basically a rebranded Broadcom BCM4339, whereas the new revision has an inbuilt AP6255, which is a rebranded BCM43455.
What manufactures sometimes like to do is that they change Wifi chips. Downstream this becomes a very common (driver) problem with Libreelec TV boxes based on Amlogic processors, for example.
I already reflashed the original firmware, unfortunately the problems remain the same, which is really shitty because the tablet keeps rebooting every now an then without any interaction from my side.
Relfashing the 1.0.6 kernel may solve this very problem, but will create a new one! My wifi won't work, which should be clear by now.
Of course, it would be very nice to test and run a potentially much more bug-free kernel from OMA, but that's gonna take some time I presume ....
dfahren
65
2017/07/07 - 16:23
I have to amend my previous post a bit ...
I can confirm my tablet also "swallows" 1.0.6 firmware and Wifi is working. So my previous statement about Wifi is wrong.
But my crashes appear more frequent ALSO with this 1.0.6 firmware, sooo .... this means I have some hardware failure and now I presume it might be the DRAM which might have broken cells.
@Might : Do you know a programm with which I'm able to test the tablet's DRAM?
I'm very frustrated because this inevitably means I have to send my tablet back to China, which is not only expensive from Germany but also takes AGES! YellCry
66
2017/07/07 - 20:37
Try to run Antutu benchmark a few times and report back whats going on.
67
2017/07/07 - 20:41
Alex2zl
Joeblah
Forum Posts: 33
68
2017/07/07 - 22:15
Slight setback. My laptop just died. Was a old piece of trash anyways. Screen ribbon cable was messed up anyways and showed off color and slightly garbled picture. Was fine for working on tablets and such. now its just backlit with no picture so I'm guessing the display cable finally broke to much. Possibly getting another laptop soon will let you know when I do.
Sorry for the trouble.
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
69
2017/07/07 - 22:22
Try :A1 SD Bench: a few times.
also Check emmc.
Can you get the Info which NAND is Inside?
Try the App "emmc brickbug check"
dfahren
Alex2zl
Forum Posts: 92
70
2017/07/07 - 23:29
 Hello. Finally today came my tablet. Came revision b. No problem as the user above, did not notice, everything works well. Is it possible to detect through the log whether there are any changes in the drivers? Log attached
71
2017/07/07 - 23:59
Not really a fundamental difference. Just the wifi chip.
[ 0.588368] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 21.465424] Current WiFi chip is AP6255.
Alex2zl
Forum Posts: 92
72
2017/07/08 - 01:06
understood thanks.Do you need any more logs?Or now we just need to try to flash different kernels until the system starts?
73
2017/07/08 - 10:50
No more logs. However, take your time to play around with your new toy as is 😉
dfahren
74
2017/07/08 - 13:27
also Check emmc.
Yeah, that's an idea. Thanks!
Hmm, I think I'm going to issue an RMA. I have the impression I don't need any more tests. Since the segmentation faults which show up in the dmesg log always occur at pretty the same address I'm more or less convinced that it's some DRAM failure.
Once I have got a replacement one, I chime in here again.
Thanks all for your help and cooperation, appreciate it!
dfahren
75
2017/07/08 - 13:31
Exactly my finding in Post #64! CoolCoolSmile
Currently Online: desluk
98 Guest(s)
Devices in use: Desktop (95), Phone (4)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
