Next try: http://crewrktablets.arctablet.com/?wpfb_dl=3118
Can you try to get a dmesg log? Here is a PC tool: https://forum.xda-developers.com/showthread.php?t=1944776
Next try: http://crewrktablets.arctablet.com/?wpfb_dl=3119
And this one is a heavy test with 8 different resources (try each one with the kernel): http://crewrktablets.arctablet.com/?wpfb_dl=3120
2014/09/11
No i guess, the goal is that you can boot up the LineAgeOS Build 1.2.4.
Nevermind, according to your dmesg, the kernel doestn crash...so it must be a lcd driver issue.
You can do the following, repetitive for every testkernel:
- Flash one of oma's kernel
- Then flash back stock kernel
- Go with ADB on that tablet
- Type: adb shell
- Type: cat /proc/last_kmsg
- Post the output from last_kmsg here.
I will have a look at the output.
2017/05/09
Hi there,
I received my ifive mini 4s a couple of days ago. Is a very nice tablet and works as designed and comes with Version 1.0.8B.
Unfortunately I have some major problems. Right out of the box the software on the tablet is pretty old and once Google Play Store updates Services and other Apps. The tablet starts to crash as hell. More often than not I start an app, it runs for a couple of seconds and then it is killed by Android or EVEN BETTER the whole tablet reboots. Now I can't even start the tablet normally, it keeps booting and booting and some time in the future it says "Optimizing Apps ...".
Do you guys have the same problems? Could anybody do something about it? Do you think my tablet is faulty? I already reflashed the firmware, but that does not fix the problems.
Cheers, DFahren
P.S.: Some "nice" errors from the logcat:
07-06 06:00:04.768 3409 4762 W DownloadManager: [29] Stop requested with status HTTP_DATA_ERROR: Failed reading response: javax.net.ssl.SSLProtocolException: Read error: ssl=0xb7b8ff18: Failure in SSL library, usually a protocol error
07-06 06:00:04.768 3409 4762 W DownloadManager: error:1e06e065:Cipher functions:aead_aes_gcm_open:BAD_DECRYPT (external/boringssl/src/crypto/cipher/e_aes.c:1188 0xab365b27:0x00000000)
07-06 06:00:04.768 3409 4762 W DownloadManager: error:100bd08f:SSL routines:ssl3_get_record:DECRYPTION_FAILED_OR_BAD_RECORD_MAC (external/boringssl/src/ssl/s3_pkt.c:358 0xab365b27:0x00000000)
07-06 06:00:04.770 3409 4762 D DownloadManager: [29] Finished with status WAITING_TO_RETRY
07-06 05:59:54.652 2573 2748 E RKPowerHAL: Error opening /sys/devices/system/cpu/cpufreq/interactive/input_boost: No such file or directory
07-06 05:59:54.655 2573 2748 E RKPowerHAL: Error opening /sys/devices/system/cpu/cpu2/online: Permission denied
07-06 05:59:54.655 2573 2748 E RKPowerHAL: Error opening /sys/devices/system/cpu/cpu3/online: Permission denied
07-06 05:59:54.655 2573 2748 E RKPowerHAL: Error opening /sys/devices/system/cpu/cpu4/online: No such file or director
y
07-06 05:59:54.655 2573 2748 E RKPowerHAL: Error opening /sys/devices/system/cpu/cpu5/online: No such file or director
y
---------------------------------- Tons of this one --------------------------
07-06 06:09:32.537 4615 4639 E Finsky : [178] com.google.android.finsky.installer.au.run(11): Session for com.android.chrome unexpectedly closed: java.lang.RuntimeException: android.os.DeadObjectException
---------------------------------- The main culprit seems to be ART (and kernel), if I'm not totally mistaken ---------
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7a556f0 SpaceTypeMallocSpace begin=0x12c00000,end=0x13b03000,limit=0x32c00000,size=15MB,capacity=512MB,non_growth_limit_capacity=512MB,name="mainrosalloc space"]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7962a28 allocspace main rosalloc space live-bitmap 3[begin=0x12c00000,end=0x32c00000]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7864898 SpaceTypeImageSpace begin=0x706f4000,end=0x70e1b990,size=7MB,name="/data/dalvik-cache/arm/system@framework@boot.art"]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb78704d0 imagespace /data/dalvik-cache/arm/system@framework@boot.art live-bitmap 0[begin=0x706f4000,end=0x70e34000]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7a78090 SpaceTypeZygoteSpace begin=0x7470a000,end=0x747d9000,size=828KB,name="Zygote space"]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7865e40 allocspace zygote/ non moving space live-bitmap 0[begin=0x7470a000,end=0x747d9000]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7a71110 SpaceTypeMallocSpace begin=0x747d9000,end=0x747f0000,limit=0x7870a000,size=92KB,capacity=63MB,non_growth_limit_capacity=63MB,name="no moving space"]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb79712f8 allocspace non moving space live-bitmap 4[begin=0x747d9000,end=0x7870a000]
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:190] 0xb7864f58 mem map large object space:GcRetentionPolicyAlwaysCollect
07-06 06:09:30.064 2573 2584 F art : art/runtime/gc/space/large_object_space.cc:191] Attempted to free large object 0x33655970 which was not live
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] Runtime aborting...
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] Aborting thread:
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] "HeapTaskDaemon" prio=5 tid=7 WaitingPerformingGc
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] | group="" sCount=0 dsCount=0 obj=0x12c071c0 self=0xb7a6a610
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] | sysTid=2584 nice=0 cgrp=default sched=0/0 handle=0xb3f33930
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] | state=R schedstat=( 1890155801 147454860 835) utm=172 stm=17 core=2 HZ=100
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] | stack=0xb3e31000-0xb3e33000 stackSize=1038KB
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] | held mutexes= "abort lock" "large object map space lock" "heap bitmap lock"(exclusive held)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #00 pc 003712d9 /system/lib/libart.so (_ZN3art15DumpNativeStackERNSt3__113basic_ostreamIcNS0_11char_traitsIcEEEEiPKcPNS_9ArtMethodEPv+160)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #01 pc 00350947 /system/lib/libart.so (_ZNK3art6Thread4DumpERNSt3__113basic_ostreamIcNS1_11char_traitsIcEEEE+150)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #02 pc 00333cff /system/lib/libart.so (_ZNK3art10AbortState10DumpThreadERNSt3__113basic_ostreamIcNS1_11char_traitsIcEEEEPNS_6ThreadE+26)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #03 pc 00333fe7 /system/lib/libart.so (_ZN3art7Runtime5AbortEv+642)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #04 pc 000f4f3b /system/lib/libart.so (_ZN3art10LogMessageD2Ev+2226)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #05 pc 001cfbe5 /system/lib/libart.so (_ZN3art2gc5space19LargeObjectMapSpace4FreeEPNS_6ThreadEPNS_6mirror6ObjectE+332)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #06 pc 0019db41 /system/lib/libart.so (_ZN3art2gc9collector9MarkSweep10SweepArrayEPNS0_10accounting11AtomicStackINS_6mirror6ObjectEEEb+620)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #07 pc 0019d5f5 /system/lib/libart.so (_ZN3art2gc9collector9MarkSweep12ReclaimPhaseEv+248)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #08 pc 001a205b /system/lib/libart.so (_ZN3art2gc9collector9MarkSweep9RunPhasesEv+234)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #09 pc 001976d5 /system/lib/libart.so (_ZN3art2gc9collector16GarbageCollector3RunENS0_7GcCauseEb+284)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #10 pc 001bb4b7 /system/lib/libart.so (_ZN3art2gc4Heap22CollectGarbageInternalENS0_9collector6GcTypeENS0_7GcCauseEb+1490)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #11 pc 001bcab1 /system/lib/libart.so (_ZN3art2gc4Heap16ConcurrentGCTask3RunEPNS_6ThreadE+104)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #12 pc 001d7de5 /system/lib/libart.so (_ZN3art2gc13TaskProcessor11RunAllTasksEPNS_6ThreadE+52)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] native: #13 pc 0000037f /data/dalvik-cache/arm/system@framework@boot.oat (???)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] at dalvik.system.VMRuntime.runHeapTasks(Native method)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] at java.lang.Daemons$HeapTaskDaemon.run(Daemons .java:355)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] at java.lang.Thread.run(Thread.java:818)
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] Dumping all threads without appropriate locks held: thread list lock mutator lock
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] All threads:
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] DALVIK THREADS (85):
07-06 06:09:31.285 2573 2584 F art : art/runtime/runtime.cc:366] "HeapTaskDaemon" prio=5 tid=7 Runnable
[... and so on, and so on ...]
07-06 06:09:31.348 4585 4585 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-06 06:09:31.348 4585 4585 F DEBUG : Build fingerprint: 'IFive/IFive_US/IFive_US:6.0.1/MXC89K/root05191101:userdebug/release-keys'
07-06 06:09:31.348 4585 4585 E DEBUG : AM write failed: Broken pipe
07-06 06:09:31.348 4585 4585 F DEBUG : Revision: '0'
07-06 06:09:31.348 4585 4585 F DEBUG : ABI: 'arm'
07-06 06:09:31.348 4585 4585 F DEBUG : pid: 2573, tid: 2584, name: HeapTaskDaemon >>> system_server <<<
07-06 06:09:31.348 4585 4585 F DEBUG : signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-06 06:09:31.365 4585 4585 F DEBUG : Abort message: 'art/runtime/gc/space/large_object_space.cc:190] 0xb7a556f0 SpaceTypeMallocSpace begin=0x12c00000,end=0x13b03000,limit=0x32c00000,size=15MB,capacity=512MB,non_growth_limit_capacity=5 12MB,name="main rosalloc space"]'
07-06 06:09:31.365 4585 4585 F DEBUG : r0 00000000 r1 00000a18 r2 00000006 r3 b3f33978
07-06 06:09:31.365 4585 4585 F DEBUG : r4 b3f33980 r5 b3f33930 r6 0000000b r7 0000010c
07-06 06:09:31.365 4585 4585 F DEBUG : r8 b4cd4378 r9 b7870c98 sl 00000001 fp 00000001
07-06 06:09:31.365 4585 4585 F DEBUG : ip 00000006 sp b3f331e8 lr b6c85ec9 pc b6c882b8 cpsr 40070010
07-06 06:09:31.379 4585 4585 F DEBUG :
07-06 06:09:31.379 4585 4585 F DEBUG : backtrace:
07-06 06:09:31.379 4585 4585 F DEBUG : #00 pc 000442b8 /system/lib/libc.so (tgkill+12)
07-06 06:09:31.379 4585 4585 F DEBUG : #01 pc 00041ec5 /system/lib/libc.so (pthread_kill+32)
07-06 06:09:31.379 4585 4585 F DEBUG : #02 pc 0001badf /system/lib/libc.so (raise+10)
07-06 06:09:31.379 4585 4585 F DEBUG : #03 pc 00018c91 /system/lib/libc.so (__libc_android_abort+34)
07-06 06:09:31.379 4585 4585 F DEBUG : #04 pc 00016784 /system/lib/libc.so (abort+4)
07-06 06:09:31.379 4585 4585 F DEBUG : #05 pc 00333e49 /system/lib/libart.so (_ZN3art7Runtime5AbortEv+228)
07-06 06:09:31.379 4585 4585 F DEBUG : #06 pc 000f4f3b /system/lib/libart.so (_ZN3art10LogMessageD2Ev+2226)
07-06 06:09:31.379 4585 4585 F DEBUG : #07 pc 001cfbe5 /system/lib/libart.so (_ZN3art2gc5space19LargeObjectMapSpace4FreeEPNS_6ThreadEPNS_6mirror6ObjectE+332)
07-06 06:09:31.379 4585 4585 F DEBUG : #08 pc 0019db41 /system/lib/libart.so (_ZN3art2gc9collector9MarkSweep10SweepArrayEPNS0_10accounting11AtomicStackINS_6mirror6ObjectEEEb+620)
07-06 06:09:31.379 4585 4585 F DEBUG : #09 pc 0019d5f5 /system/lib/libart.so (_ZN3art2gc9collector9MarkSweep12ReclaimPhaseEv+248)
07-06 06:09:31.379 4585 4585 F DEBUG : #10 pc 001a205b /system/lib/libart.so (_ZN3art2gc9collector9MarkSweep9RunPhasesEv+234)
07-06 06:09:31.379 4585 4585 F DEBUG : #11 pc 001976d5 /system/lib/libart.so (_ZN3art2gc9collector16GarbageCollector3RunENS0_7GcCauseEb+284)
07-06 06:09:31.379 4585 4585 F DEBUG : #12 pc 001bb4b7 /system/lib/libart.so (_ZN3art2gc4Heap22CollectGarbageInternalENS0_9collector6GcTypeENS0_7GcCauseEb+1490)
07-06 06:09:31.379 4585 4585 F DEBUG : #13 pc 001bcab1 /system/lib/libart.so (_ZN3art2gc4Heap16ConcurrentGCTask3RunEPNS_6ThreadE+104)
07-06 06:09:31.379 4585 4585 F DEBUG : #14 pc 001d7de5 /system/lib/libart.so (_ZN3art2gc13TaskProcessor11RunAllTasksEPNS_6ThreadE+52)
07-06 06:09:31.379 4585 4585 F DEBUG : #15 pc 72fd137f /data/dalvik-cache/arm/system@framework@boot.oat (offset 0x1ee1000)
07-06 06:09:32.264 4585 4585 F DEBUG :
07-06 06:09:32.264 4585 4585 F DEBUG : Tombstone written to: /data/tombstones/tombstone_05
07-06 06:09:32.264 2573 2598 I BootReceiver: Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
Could anybody make sense out of this?
2017/05/09
MiGHT. said
Which Kernelversion and which Build Number from Kernel?
130|root@IFive_US:/ # uname -a
Linux localhost 3.10.0 #2 SMP PREEMPT Fri May 19 09:25:27 CST 2017 armv7l
excerpt from build.props
ro.build.description=IFive_US-userdebug 6.0.1 MXC89K user.root.20170519.105734 release-keys
ro.build.fingerprint=IFive/IFive_US/IFive_US:6.0.1/MXC89K/root05191101:userdebug/release-keys
does this help?
2017/03/25
dfahren said
Hi there,I received my ifive mini 4s a couple of days ago. Is a very nice tablet and works as designed and comes with Version 1.0.8B.
Do you guys have the same problems? Could anybody do something about it? Do you think my tablet is faulty? I already reflashed the firmware, but that does not fix the problems.Cheers, DFahren
I think your mini 4s is a different hardware version. http://en.5-fnf.com/rom/index?id=25 has that firmware listed and it says ifive_mini_4S_US_1.0.8B_20170519Firmware(SN begins with letter"B") I'm thinking they have changed something on the tablet and it was significant enough to get its own firmware version.
2017/05/09
Yep, definitely it is! But rest assured my serial number definitely begins with a "B", otherwise the tablet would not start at all I presume. Furthermore I don't believe this hard error that the tablet reboots while working with it doesn't have something to do with a revised hardware. In my opinion it looks like some misconfiguration or not fitting library components .... I'm going to write in FNF's forum, maybe they issue a new revision in a couple of days time. If so, I would be very pleased because like so the tablet is unusable.
58 Guest(s)
Devices in use: Desktop (56), Phone (2)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
