Ifive mini 4s
Ifive mini 4s
Joeblah
Forum Posts: 33
2017/06/28 - 14:23
I'm not exactly sure how to do what you want. I factory restored the tablet to a fresh firmware image and then activated developer's options and then used adb to run adb shell dmesg   and the used cut and paste on the results. I thought that was what you needed. If you could tell me in a little more detail what to do I would be happy to help, just I am very new to this type stuff.
2017/06/28 - 14:42
No factory reset necessary. Just reboot the tab. Then the log will start at 0.000000 sec.
You can simply use such a PC tool: https://forum.xda-developers.com/showthread.php?t=1944776
Or on the Tab via app SysLog: https://play.google.com/store/apps/details?id=com.tortel.syslog&hl=de
Joeblah
Forum Posts: 33
2017/06/28 - 17:09
Thanks for explaining oma. Here you go.
Joeblah
Forum Posts: 33
2017/06/28 - 18:32
This tablet is so easy to restore with the rockchip factory tool and cwm backups even from a semi bricked state I'm willing to try anything you can come up with. Even  just any kind of experimental test you come up with. Let me know anything I can do to help.
2017/06/28 - 18:48
This is your hardware:
[ 0.553464] PMU1: ricoh619_pwrkey_probe: key_irq=193
[ 0.553611] input: ricoh619_pwrkey as /devices/ff650000.i2c/i2c-0/0-0032/ricoh619-pwrkey/input/input0
[ 1.166629] gsl line=1734[GSLX680] Enter gslX680_ts_init
[ 1.166872] input: gslX680 as /devices/ff160000.i2c/i2c-4/4-0040/input/input1
[ 6.405904] input: rk29-keypad as /devices/ff100000.adc/key.43/input/input2
[ 6.470284] reg=0x0,lsm330 acc set leakage is ok if sdo_a connect to GND
[ 6.470372] input: gsensor as /devices/ff140000.i2c/i2c-1/1-001e/input/input3
[ 6.470827] sensor_chip_init:ak8963:devid=0x48,ops=0xc104f8ec
[ 6.471352] input: compass as /devices/ff140000.i2c/i2c-1/1-000d/input/input4
[ 6.471797] sensor_chip_init:lsm330_gryo:devid=0xd4,ops=0xc104f9dc
[ 6.580175] input: gyro as /devices/ff140000.i2c/i2c-1/1-006a/input/input5
[ 6.443585] rockchip-rt5616 rockchip-rt5616.39: rt5616-aif1 <-> ff890000.rockchip-i2s mapping ok
[ 6.587644] input: rockchip_headset.42 as /devices/ff100000.adc/rockchip_headset.42/input/input6
[ 6.588212] ALSA device list:
[ 6.588217] #0: RK_RT5616
[ 18.669542] Current WiFi chip is AP6335.
[ 19.950488] Final fw_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
[ 19.950493] Final nv_path=/system/etc/firmware/nvram_AP6335.txt
[ 19.950498] Final conf_path=/system/etc/firmware/config.txt
[ 20.010720] NVRAM version: AP6335_NVRAM_V1.7_04102014
[ 9.084124] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8856) register success
[ 9.396811] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: GC2155) register success
PMU - Ricoh 619
7.9 inch IPS 10-points Capacitive Screen with 2048 x 1536 Resolution
Touch Controller - Goodix GSLX680
Gravity Sensor - lsm330
Geomagnetic Sensor - ak8963
Gyroscope - lsm330_gyro
Audio - RT5616
Wifi - AP6335 (802.11ac 2.4G/5G + BT4.0 + FM)
Rear Cam - OV8856
Front Cam - GC2155
dfahren
2017/06/28 - 18:51
Yeah, exploring new ground 🙂
Hardware is similar to Ifive Air and HaierPad 971.
Pls try this build as is (instructions are included in the download pack): http://crewrktablets.arctablet.com/?wpfb_dl=3067
2017/06/28 - 18:55
Download link corrected. Sorry.
Joeblah
Forum Posts: 33
2017/06/28 - 22:17
soft brick nothing comes on screen at all only thing i could do was get it back into loader mode and restore factory firmware.
same thing it did in past when i tried some of your ifive air mm aosp and lineage13 builds.
2017/06/30 - 16:16
I guess we need to do an own kernel for the tab. Maybe early next week.
Joeblah
Forum Posts: 33
2017/06/30 - 19:02
Sounds like a plan to me. One question, would it be possible with the info you have to compile a twrp recovery with touch enabled on it that would work on this tab?
2017/06/30 - 19:15
This is kernel related. The stock kernel is a bit strange.
There is also a lot of HDMI stuff in it. Does the tab have HDMI?
Joeblah
Forum Posts: 33
2017/06/30 - 19:44
No it don't have HDMI at least not a physical port it might have the contacts on the motherboard and such but I don't know as I have not opened the tablet
2017/06/30 - 20:31
Can you quickly check if this one boots: http://crewrktablets.arctablet.com/?wpfb_dl=3102
Joeblah
Forum Posts: 33
2017/06/30 - 22:09
could you tell me how to do that or make one of your files with everything set up with the rkandroid tool?
2017/06/30 - 22:27
Use the LineAgeOS flashpack. Just change kernel and resource in folder rockdev/image.
84 Guest(s)
3 Guest(s)
Devices in use: Desktop (75), Phone (9)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
