Lost password?
The forums are currently locked and only available for read only access
Ifive mini 4s
Ifive mini 4s
This topic is locked
Alex2zl
Forum Posts: 92
196
2017/08/15 - 18:31
All the same as with the kernel 19.
tomorrow I will have a otg cable
Alex2zl
Forum Posts: 92
197
2017/08/16 - 19:06
Connected the mouse and turned on pointer location. The photo below. When you tap the screen, nothing happens.
Also does not work wi-fi, can not turn on
IMG_20170816_195611.jpgImage Enlarger
Forum Posts: 6314
198
2017/08/16 - 20:42
Reboot the tab and try to enable the wifi a few times. Then upload the dmesg.
Alex2zl
Forum Posts: 92
199
2017/08/16 - 21:04
Still noticed that when you choose to reboot, the tablet turns off the screen and as if hangs, you have to do hard power off, power on
Forum Posts: 6314
Alex2zl
Forum Posts: 92
201
2017/08/16 - 21:56
Without any changes: the touchscreen does not work either, the Wi-Fi can not turn on either. For some reason, the mac address is recorded 02: 00: 00: 00: 00: 00. Probably this is an error
Forum Posts: 6314
202
2017/08/16 - 22:06
Logs please.
Alex2zl
Forum Posts: 92
203
2017/08/16 - 22:13
And the tablet still can not reboot itself
Forum Posts: 6314
Alex2zl
Forum Posts: 92
205
2017/08/17 - 22:14
1)So, wi-fi does not work either. BUT, the display partially works, it understands the touch, but as if inverted from the right to the left, and does not reach to the bottom and to the left. Well, in general, behaves not very stable, there are double touch (in different places), etc..Logs and photos in the attachment
2)And still, the camera does not work. Writes it is impossible to connect to the camera. So it was on the past kernel.
3)When you select a reboot or shutdown, the tablet turns off the screen and seems to be turned off, but in fact it hangs, you have to do a hard power off,power on so that it re-engages.
if you make a hard power off while in Android, the tablet will turn off, but after some time (several minutes), turn on itself
UPD:
4)The percentage of battery or its capacity may not be displayed correctly.
Yesterday, the tablet was discharged at 0%, set at night for charging, in the morning, after 7 hours, the tablet was charged only to 47%.
Although when connecting the charging cable to the turned off tablet, a picture appears with the battery where the battery is charged 100%
IMG_20170817_230133_HDR.jpgImage EnlargerIMG_20170817_230139_HDR.jpgImage EnlargerIMG_20170817_230654_HDR.jpgImage Enlarger
Forum Posts: 6314
Alex2zl
Forum Posts: 92
207
2017/08/18 - 22:27
The inversion of the screen has passed, but the touches themselves are slightly shifted, and the touchscreen does not work on the left and below
Wifi also does not work.
Сamera does not work. Can not connect.
Problems with reboot and shutdown also left
Battery unchanged
Forum Posts: 6314
Alex2zl
Forum Posts: 92
209
2017/08/18 - 23:07
Now the touch is generally confused. I did not understand the law
Forum Posts: 6314
67 Guest(s)
Devices in use: Desktop (53), Phone (14)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
