Ifive mini 4s
Ifive mini 4s
Alex2zl
Forum Posts: 92
166
2017/07/16 - 15:51
The FNF logo (5) appears on a blue background, and the tablet reboots. And so endlessly
Thanks Received: 1378
167
2017/07/16 - 15:59
Did you flash misc? Hard Power-off and flash misc.
Alex2zl
Forum Posts: 92
168
2017/07/16 - 16:02
Installed everything exactly as in the picture, kernel, resource, misc and parameter
169
2017/07/16 - 16:03
And the stock kernel is from the download above or from your dump?
Alex2zl
Forum Posts: 92
170
2017/07/16 - 16:06
From the post number 163
171
2017/07/16 - 16:31
Ok. Flash back stock. Flash CWM v4.0qad with RKAndroidTool (make sure everything else is unticked). Try to wipe.
Alex2zl
Forum Posts: 92
172
2017/07/16 - 16:48
Hmm, when i try to enter cwm(Power+ vol-), it reboots. Past CWM were loaded normally
173
2017/07/16 - 16:58
Ok, check wipe with CWM 3.0.
Alex2zl
Forum Posts: 92
174
2017/07/16 - 17:02
Wipe data completed. Everything went as it should
175
2017/07/16 - 17:09
Now flash kernel/resource #16 and boot/system from Lineage.
flash.pngImage Enlarger
Alex2zl
Forum Posts: 92
176
2017/07/16 - 17:20
After the logo rockchip is just a black screen, the backlight of the screen is off
177
2017/07/16 - 17:38
Let it go 3-4 min and then let me have dmesg and logcat log.
Alex2zl
Forum Posts: 92
178
2017/07/16 - 17:41
ADB is not supported, the device is not visible
179
2017/07/16 - 18:17
Roboot into CWM. Can you wipe now?
Alex2zl
Forum Posts: 92
180
2017/07/16 - 18:24
Cwm is loaded with an error, when you try to make a wipe data, the tablet reboots. Hard power-off, power-on does not give anything, just the black screen after the logo rockchip
IMG_20170714_193516-1.jpgImage Enlarger
84 Guest(s)
Devices in use: Desktop (70), Phone (9), Tablet (5)
pawel255
elpacox
Kolokolov Pavel
Ikeman
martn28
dazzlindazz
