Ifive mini 4s
Ifive mini 4s
Thanks Received: 1378
151
2017/07/16 - 12:13
getprop ro.bootmode
Alex2zl
Forum Posts: 92
152
2017/07/16 - 12:16
2017-07-16-2.pngImage Enlarger
153
2017/07/16 - 12:31
Wow ... an rk32board with no eMMC? Seems this tab has NAND. Unbelievable ...
Flash back stock and let me have the result of:
cat /proc/partitions
Alex2zl
Forum Posts: 92
154
2017/07/16 - 12:44
2017-07-16-3.pngImage Enlarger
Is it good or bad?: D
155
2017/07/16 - 13:28
Ok. What is the result of:
lsmod
Alex2zl
Forum Posts: 92
156
2017/07/16 - 13:30
2017-07-16-4.pngImage Enlarger
157
2017/07/16 - 13:34
Let me see the Chip. Load eMMC Brickbug Check app from Play Store.
v1.2.5_04.pngImage Enlarger
Alex2zl
Forum Posts: 92
158
2017/07/16 - 13:38
Screenshot_20170716-0437381.pngImage Enlarger
159
2017/07/16 - 14:01
Ok, fine. Samsung eMMC.
We will try now to flash the firmware with the FactoryTool v1.33, coming as the Flash Tool for the stock firmware.
Therefor we need to build an update.img. Here is a building pack: http://crewrktablets.arctablet.com/?wpfb_dl=3135
Just copy all files from folder rockdev/Image over, incl. kernel/resource #16.
Make sure you flash with Restore option.
Alex2zl
Forum Posts: 92
160
2017/07/16 - 14:21
I understand correctly: I take all the files from the folder CrewRKTablets_RK32_iFive_Air_LineageOS_14.1_7.1.2_v1.2.5 \ rockdev \ Image, copy them to the folder Oma_RK3288_make_update.img_2 \ rockdev \ Image, there copy the kernel and resource 16, run mkupdate.bat, wait for the build Img file with firmware. In the foctory tool I specify the path to this .img file, switch to restore and press the run?
Use TWRP from LOS or CWM in the folder Oma_RK3288_make_update.img_2?
Files: parameter_cm14.1, package-file, recover-script, and others from the folder CrewRKTablets_RK32_iFive_Air_LineageOS_14.1_7.1.2_v1.2.5 \ rockdev do not copy with replacement to the folder Oma_RK3288_make_update.img_2 \ rockdev?
161
2017/07/16 - 15:13
Just the images.
copy-over.pngImage Enlarger
Alex2zl
Forum Posts: 92
162
2017/07/16 - 15:37
The same error >_< IMG_20170715_174652-2.jpgImage Enlarger
163
2017/07/16 - 15:43
Flash the stock kernel/resource with RKAndroidTool: http://crewrktablets.arctablet.com/?wpfb_dl=3127
flash_kernel-2.pngImage Enlarger
Alex2zl
Forum Posts: 92
164
2017/07/16 - 15:46
With LowerFormat?
165
2017/07/16 - 15:47
No.
83 Guest(s)
Devices in use: Desktop (71), Phone (9), Tablet (3)
teomanfbm
pawel255
elpacox
Kolokolov Pavel
Ikeman
martn28
