Ifive mini 4s
Ifive mini 4s
136
2017/07/15 - 22:52
No, we still need the latest upset. Leave it as it is. Just flash kernel/resource.
Alex2zl
Forum Posts: 92
137
2017/07/15 - 23:00
did. It's still not loaded further than the logo of the rockhip kernel. Simply displays the logo, and that's it.
138
2017/07/15 - 23:03
Ok. Pls use build v1.2.5 as is, just change kernel/resource #16. Flash incl. Lower Format.
Alex2zl
Forum Posts: 92
139
2017/07/15 - 23:10
TWRP was loaded, but it also does not work with a touchscreen
140
2017/07/15 - 23:14
Somewhere reaction on the screen? Dmesg log please.
Alex2zl
Forum Posts: 92
141
2017/07/15 - 23:20
Nowhere there is no reaction
142
2017/07/15 - 23:28
Ok, now flash the latest CWM and try to wipe data.
Alex2zl
Forum Posts: 92
143
2017/07/15 - 23:36
All the same error in CWM.
Could this be an error in the CWM build? Because it does not even show the recovery menu, where you can select wipe, etc.
IMG_20170715_174652-1.jpgImage Enlarger
144
2017/07/16 - 08:44
I don't know whats going on. I do any step in parallel here on my tab, which works flawlessly.
145
2017/07/16 - 09:12
When booted in TWRP pls open an adb shell and type
umount /data
umount /cache
umount /system
twrp wipe cache
twrp wipe data
mount /system
rm -f /system/etc/cam_board.xml
reboot
Alex2zl
Forum Posts: 92
146
2017/07/16 - 11:07
Did. For some reason, it can not mount \ unmount partitions. And after entering "reboot", the tablet simply turns off. At power-on, again gets in twrp, where it is necessary to make swipe for access permission
2017-07-16.pngImage Enlarger
147
2017/07/16 - 12:02
Curious. Pls type:
cat /proc/partitions
ls -l /dev/block
ls -l /dev/block/platform
Alex2zl
Forum Posts: 92
148
2017/07/16 - 12:08
2017-07-16-1-1.pngImage Enlarger
149
2017/07/16 - 12:10
Wrong pic, I guess ...
Alex2zl
Forum Posts: 92
150
2017/07/16 - 12:12
Sorry. Amended
2017-07-16-1-2.pngImage Enlarger
65 Guest(s)
Devices in use: Desktop (61), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
