There are multiples ways to do a master reset:
- if you have a CWM Recovery installed, you can do a wipe data / factory reset.
- or you can use the factory reset option in Android: go to Settings / Backup & Reset / Factory data reset.
- finally, the lowest level method is to reflash a firmware using Rockchip Batch Tool and the reset button.
2014/08/12
Hello,There are multiples ways to do a master reset:
thanks. but my tablet dont loading.always restarting.i markt simulate multiple screen.and no it still loading and loading.
 I did this :- finally, the lowest level method is to reflash a firmware using Rockchip Batch Tool and the reset button, but says restore failed
93 Guest(s)
Devices in use: Desktop (85), Phone (8)
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
