Here is a rooted custom firmware for the FNF iFive mini2 tablet based on official version 1.3.4Â
(ifive-MINI-2_FW_411_V1.3.4.rar)
Build information:
Linux Kernel:Â Linux version 3.0.8+ (root@five-server) (gcc version 4.4.3 (GCC) ) #142 SMP PREEMPT Tue Mar 12 11:29:57 CST 2013
Android build:Â IFive/rk30sdk/rk30sdk:4.1.1/JRO03H/ifive.20130114.155911:eng/ifive-keys
- root with latest SuperSU 1.30 (free version)
- increased space for application (/data partition) to 2 Gb
- Google Play Store fixes so more applications are visible/compatible
- Android 4.2 AOSP stock launcher from here, thanks mad86
- hopefully fixed boot logo issue (scrambled picture)Â
Download:Â kasty-fnf_ifive_mini2-411-134-rooted4.zip
Use Rockchip Batch Tool version 1.5 to flash the firmware, don't flash using the "sdcard" method.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive mini2 to test it.
jays021, ronnel0918, theramlewis, madskills, hbbz, manilaboy, feljurcross, h2h_9x, freeman1778 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
What do you mean by flash in stock recovery ?
This custom firmware isn't tested yet, at least nobody gave feedback on it.
2013/05/05
I have test this firmware. and the launcher is so cool. it feels so much faster than the stock. I have tried many firmware, and I think this is the best so far for a non chinese person. all the other firmware that I have tried is full of irritating chinese apps. I just hope that a firmware willl be made to improve the wifi stability of ifive mini 2 ) I'm very dissapointed by the wifi stablity in the stock firmware.Â
2013/05/06
Can anyone please tell me how to get into recovery for this device so I can flash via Rockchip batch tool? I have tried volume + & power, volume - & power, menu & power. All I get for the volume key and power is the initial logo, and then it turns off. It's like the stock recovery isn't even working
Update: I managed to work it out. Power device off, hold down the menu button, then connect USB cable from PC.
Custom ROM flashed, and so far it seems good. Thanks!
@ jbjamison23 : i don't think this firmware improve wifi because it make with original firmware. But it support init.d so you can find script which could improve this and if you want try to modify your wifi network on wifi channel diffusion and level encryption key. Maybe there is an conflict here.
@markfnz : it flash with rkbatchtool like this french tutorial : http://www.tablette-chinoise.net/t919-tuto-comment-flasher-sa-ifive-ou-autre-tablette-a-base-de-rockchip
@ admin : i don't know if you agree of external link of my tutorial. If you have one you can modify my link to yours
The original link (ifive-MINI-2_FW_411_V1.3.4.rar) is here:
http://pan.baidu.com/share/link?shareid=510134&uk=992691768
I got it from here:
markfnz, ronnel0918 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/05/06
This method worked for me
http://www.slatedroid.com/topic/46929-rooting-rk3066-tablets-the-right-way/
The latest version of the script is V30 though, search for "Root_with_Restore_by_Bin4ry_v30.zip"
If not the custom ROM posted at the top of this topic is already rooted, so you can try flashing that. You will need this tool though:
To put your Mini 2 into recovery for flashing, run the flash tool, disconnect USB from PC, power off tablet, hold down menu button on the top, then plug in USB while still holding down menu button. The flash tool should then see the tablet. Flash as per the instructions above
2013/05/06
You're welcome.
To get into recovery to use the flash tool, do the following:
- Disconnect all cables
- Power off tablet
- Hold down the menu button (next to the volume buttons)
- While still holding down the menu button, connect the USB cable between your table and PC
- Keep holding down the button until you hear Windows add a new device
- You will either be prompted to install the drivers, or go into Device Manager to install the rockusb.sys driver which is included in the "Rockusbdriver" directory in the Flash tool zip file
- You should now see the RK30 device in device manager, and can run up the RKBatchTool.exe. You should see a green box with "1" in connected devices
- Follow the instructions to flash the tablet. I used the "restore" button as it's cleaner, but it will reset all data
I just tried this again to make sure, and discovered that unless you have the right USB cable, Windows doesn't recognise the device properly. If you get this, try a different cable.
Good luck! The custom ROM is worth it!
The following users say thank you to markfnz for this useful post:
jays021, ronnel0918Most Users Ever Online: 749
Currently Online: floki
83 Guest(s)
Devices in use: Desktop (73), Phone (11)
floki
orocamora
Ellocojoe
Tonysc17
olegator
Ur
