How to do a hard reset in ifive mx
marcus_porfirio
2014/11/05 - 12:46
I neede to do a hard reset in my ifive mx. How can i do this? thanks
2014/11/05 - 21:17
You should be able to wipe all contents on your tablet (and its sdcard if one is inserted) by going to Settings menu then Backup & reset then Factory data reset.
A lower level option would be to flash again the firmware, from either the stock firmware (check iFive website) or a custom firmware such as the one we built: http://www.arctablet.com/blog/forum/ifive-m-models/
These reset methods may leave some data that can eventually be recovered on the tablet, so you may want to use a wipe applications such as Secure Wipe to make sure your data are fully wiped, that may be useful if you plan to sell your tablet.
59 Guest(s)
Devices in use: Desktop (52), Phone (7)
jacksonrid
