[ ROM ] FNF iFive MX 3G Android 4.1.1 custom rooted firmware based on v1.2.0 (2013/03/26)
mad86
Forum Posts: 71
Thanks Received: 4
46
2013/04/29 - 11:26
Hi Globula,
I search for permissions and my conclusions are :
/system/xbin/busybox
user : root group : root permissions : ugo=wrx sticky : 0
/system/xbin/su
/system/app/superuser.apk
user : root group : root permissions : u=wrx go=r sticky : 0
Is it right ? :)
I try to make a bash script of this after :)
Thanks Received: 264
47
2013/04/29 - 12:30
from what i remember on su/superuser is chmod 777 anyway here is a more understanding way to set the permissions using numerical values
http://gd.tuwien.ac.at/linuxcommand.org/lts0070.html
mad86
Forum Posts: 71
Thanks Received: 4
48
2013/04/29 - 12:32
OK so ugo=wrx is the same signification of 777 ;)
Thanks i go to try it :)
mad86
Forum Posts: 71
Thanks Received: 4
49
2013/04/29 - 19:50
This afternoon i find another utility here :
http://www.rockchipfirmware.com/developer-tools
I go to try it ;)
dedemitmaya
50
2013/05/01 - 04:47
Here is a rooted custom firmware for the FNF iFive MX 3G tablet based on official version 1.20 (ifive_MX_3G_411_sdk2.0_V1.2.0.zip)
Build information:
Linux Kernel: Linux version 3.0.8+ (root@five-server) (gcc version 4.4.3 (GCC) ) #206 SMP PREEMPT Tue Mar 26 10:44:17 CST 2013
Android build: ifive/rk30sdk/rk30sdk:4.1.1/JRO03H/ifive.20130227.140424:eng/ifive-keys
  • root with latest SuperSU 1.25 (free version)
  • increased space for application (/data partition) to 2 Gb
  • Google Play Store fixes so more applications are visible/compatible
  • Android 4.2 AOSP stock launcher from here, thanks mad86
Download: kasty-fnf_ifive_mx_3g-411-120-rooted2.zip
Use Rockchip Batch Tool version 1.5 to flash the firmware, don't flash using the "sdcard" method.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive MX 3G to test it.
Hi, tested this, first thing checked is GPS. As you know this tablet has problem with fixing locking GPS. Wit latest official firmware 1.20 it worked but must enable agps, what the hell. Then tried your ROM. The agps does not work at all. It can not be enabled. Always come back unticked. No profile listed also. Hence GPS does not work at all. Flashing back original ROM. Working now but somehow, when I bought this in china, they must have special ROM that gps/agps cna work with wifi without enabling the modem. can work with WiFi. Now have to enable data from agps. Can not locked in with WiFi data. Even before I don't have toturn on modem.
51
2013/05/01 - 10:28
Well, this tablet does not have a GPS module, maybe you need enable from settings/location services/google location services which will help determine the location based on the wifi
Also restart the tablet after you enable that.
mad86
Forum Posts: 71
Thanks Received: 4
52
2013/05/01 - 10:43
No there are two versions of this tablet, one with only GPS and a second with both GPS and Wifi module ;)
53
2013/05/01 - 10:47
then that means that he needs a different firmware.
mad86
Forum Posts: 71
Thanks Received: 4
54
2013/05/01 - 10:51
Exactly if you take a look admin make two customs fimwares ;) one for wifi version and one for 3G version
For example at first test of tinm he take the 3G version for his wifi version and the result is wifi issue ;)
55
2013/05/01 - 10:53
Some places from where to download the 2 versions of firmware will be good.
dedemitmaya
56
2013/05/02 - 02:26
Hi'
The 3g version has GPS module. Since this modded ROM comes from 3g original firmware, it should work.
Sadly, if it runs standalone, GPS can not lock the satellites. It is well known issue.
Including battery problem. Battery sucks. I was hoping this modded ROM can make the battery last longer.
You can search in Chinese and Russian forum.
mad86
Forum Posts: 71
Thanks Received: 4
57
2013/05/02 - 12:44
I'm steel trying to make my own rom but after mounting my system.img i'can't add anything in mounted folders i have a "missing space error"
Anyone to help me ? :)
my command line to mount :
sudo mount -t ext4 -rw unpack/Image/system.img ./system_mount/ -o loop
58
2013/05/02 - 14:21
mkdir system_new
mount -o loop system_new/
mad86
Forum Posts: 71
Thanks Received: 4
60
2013/05/02 - 14:38
I have aldready created the system_mout folder before ?! I need to create another one ?
171 Guest(s)
Devices in use: Desktop (159), Phone (12)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
