[ ROM ] FNF iFive MX 3G Android 4.1.1 custom rooted firmware based on v1.2.0 (2013/03/26)
mad86
Forum Posts: 71
Thanks Received: 4
31
2013/04/27 - 20:41
Ok i try to find some indications on the web and i try on firmware :)
Thanks ;)
mad86
Forum Posts: 71
Thanks Received: 4
Thanks Received: 264
33
2013/04/27 - 22:41
This one is for making a basic cwm flashable firmware
http://rootzwiki.com/topic/2962-making-your-own-rooted-android-rom/
You can use it only if you know your mount points and other stuff related with the META-INF, though I recommend that you use dsixda kitchen
http://forum.xda-developers.com/showthread.php?t=1886460
This is only a script similar to this one http://globula.arctablet.com/AN7CG3/ that enables root on your device.
mad86
Forum Posts: 71
Thanks Received: 4
34
2013/04/27 - 22:44
Thanks for your help ;)
i go look at this
another question how do you change default language in android ?
edit : for mount point, you speak about what it is in /mnt ? There is a fstab in android ?
35
2013/04/27 - 22:59
You can set up a default language in build.prop
No
In the META-INF/com/google/android you have a file called updater-script which is used to determine the mount points and what to flash, what needs to be formated, it is setting permission and many other things.
An example, on arnova 7c g3 it looks something like this
show_progress(0.1, 0);
format("ext4", "EMMC", "/dev/block/mmcblk0p12");
mount("ext4", "EMMC", "/dev/block/mmcblk0p12", "/system");
format("ext4", "EMMC", "/dev/block/mmcblk0p13");
mount("ext4", "EMMC", "/dev/block/mmcblk0p13", "/data");
delete("/data/local");
But this is only the beginning there are more lines after, the idea is that when you do a CWM flashable firmware you need to set t up these mounting points properly because you can either delete your current firmware, or flash the cache with the system and many other situations.
For example, i spend 10 minutes to correct the mounting points and write them in a proper way (on android 2.3 the scripting arguments are a little bit different)
mad86
Forum Posts: 71
Thanks Received: 4
36
2013/04/28 - 08:21
Thanks  a lot for your help ;)
mad86
Forum Posts: 71
Thanks Received: 4
37
2013/04/28 - 09:49
So if i have to resume to mahe root ROM i haver to make a script that do this steps :
- Copy of supersu in /system/app
- Copy of su in /system/sbin
- Copy of busybox in /system/sbin
- Finally a chmod that modify rights for /system in modifications
38
2013/04/28 - 12:17
Something like that.
Lets assume that you unpack the the update.img with wendal tools, after which you take the system.img and you mount it in linux.
What do you do now:
-you need to do everything manually to understand the concept
-therefore you will have the copy the supersu to /system/app where you will set the permissions and ownership (if you don`t set them proper the tablet will not be able to access the files that you copy)
-do the same with the rest of the files
-sync
-umount system.img
-back with the system.img in wendal tools, re-pack the system.img with rest of the files (boot/misc,recovery ect)
-flash the new modified update.img with rockchip tools.
From here you should first start, to do a CWM flashable firmware is much more complicated at this step, so you should stick in editing the system.img in linux as much as you can.
mad86
Forum Posts: 71
Thanks Received: 4
39
2013/04/28 - 18:42
The extraction with wendal, virtual machine on debian, mount system.img is allright :)
For the ownership i have to give right only on supersu, su and busybox or on all files of system.img ?
40
2013/04/28 - 18:45
only for the new added files.
mad86
Forum Posts: 71
Thanks Received: 4
41
2013/04/28 - 18:50
OK so root a rom only consist to add these 3 files with good ownership ? :)
42
2013/04/28 - 18:57
yes.
mad86
Forum Posts: 71
Thanks Received: 4
43
2013/04/28 - 18:58
Oh yeah thanks a lot ;) for ownership i take example on a system app already exist ? :)
44
2013/04/28 - 20:14
Yes, but the permissions are a little bit different, because it has the rights to read/write
mad86
Forum Posts: 71
Thanks Received: 4
45
2013/04/28 - 20:27
Ok i look this on your rom ;) thanks a lot. I go to try this yesterday :)
204 Guest(s)
Devices in use: Desktop (190), Phone (14)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
