[ ROM ] FNF iFive MX 3G Android 4.1.1 custom rooted firmware based on v1.2.0 (2013/03/26)
Thanks Received: 3171
2013/04/26 - 14:06
PietKn said
making a firmware for just 2 people isn't really interesting for me, unless there is some donation/support...
I'll donate anyhow as i was flabbergasted to see that you just did the customisation within a couple of hours, saving me the time to do the rooting, deinstalling manually.
Thanks PietKn, that's kind of you and it's encouraging to better help the iFive tablet community Wink
Please understand that we rely on support from users to help paying the servers/bandwidth bills, buy new tablets to support and more generally keep the site alive.
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/26 - 15:15
I go to send a donation too ;)
2013/04/26 - 15:21
Thanks to you too.
Is there any other iFive tablet we could make a custom firmware for ?
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/26 - 15:29
Yes i know that tinm want a firmware based on this :
http://pan.baidu.com/share/link?shareid=571181&uk=992691768
And on our forum there is users off :
Mini : http://pan.baidu.com/share/link?shareid=480781&uk=992691768
and
ifive 2 : http://pan.baidu.com/share/link?shareid=497325&uk=992691768
Thanks a lot ;)
2013/04/26 - 15:44
All right, you should have two of them ready for the week-end.
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/26 - 15:45
Thanks a lot for the others members ;)
Tinm
2013/04/26 - 15:54
Hi admin,
thank you a lot for your help.
iFive is a new brand on the french market but we would like to create a community around it :)
2013/04/26 - 17:15
Please watch the iFive section for the new custom firmwares, I'll drop them here as they are ready.
PietKn
2013/04/26 - 22:13
Great: also on my tablet MX 3G all working.
some details
- downloading from ArcTablet.com considerably faster than Baidu (Donation helped?)
- flash version used V1.6
- no single hickup flashing your zipped "update.img"
- started oke without issue and noted your ArcTablet welcome-screen
- standard launcher working and old llife wall-paper present.
- ArcTools 0.78 added; to be studied.
- indeed Chinese apps uninstalled (thanks!)
To be studied:
- old lockscreen still present (was known)
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/27 - 15:30
Question for admin :
Why you don't add CWM recovery directly in your firmware ? Because i try to add misc.img and recovery.img of CWM recovery on stock ROM with wendal tool and it work. But after flash tablet reboot in CWM recovery with some errors. If you reboot normally, all is allright.
2013/04/27 - 17:06
Not everybody needs a custom recovery, so I prefer to leave the stock recovery by default.
I'll eventually add a CWM if I am told which one to use, it will need to be flashed thru RKAndroid tool or maybe I'll add CWM installation from ArcTools, our own tool to optimize Android tablets.
About PietKn remarks:
- our downloads are fast because it's probably nearer from you than Baidu server. Still, we have multiple servers for fast downloads all over the world, that cost and we won't maintain them if we don't receive donations/support from the community.
- arctablet.com boot logo is just a way to "sign" our work, it's just displayed for a second or so, it shouldn't be much of problem for most users. If you don't like it, just use another firmware, or make your own Wink
- stock wallpapers: I'll see what I can to remove them
- lockscreen: not much I can do for now, without having a tablet to test, I think it would be a pain to debug, no time for that, sorry.
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/27 - 19:55
If you don't affraid of french you can find tutorial for cwm here :
http://www.tablette-chinoise.net/t1145-tuto-installer-cwm-recovery-sur-une-tablette-ifive-a-base-de-rk3066
Actually i try to make my own custom rom but what is the method to root natively the rom ?
Thanks Received: 264
2013/04/27 - 20:15
You need to make yourself some scripts in linux to do`it automaticly.
Either you mount the system.img in linux, and you add manually the superuser app and su file, after which you need to set the permission for each one of them.
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/27 - 20:23
There is a tuto for this ?
2013/04/27 - 20:36
No, lol, you need to learn alone :)
179 Guest(s)
Devices in use: Desktop (165), Phone (13), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
