Here is a rooted custom firmware for the FNF iFive MX 3G tablet based on official version 1.20 (ifive_MX_3G_411_sdk2.0_V1.2.0.zip)
Build information:
Linux Kernel:Â Linux version 3.0.8+ (root@five-server) (gcc version 4.4.3 (GCC) ) #206 SMP PREEMPT Tue Mar 26 10:44:17 CST 2013
Android build:Â ifive/rk30sdk/rk30sdk:4.1.1/JRO03H/ifive.20130227.140424:eng/ifive-keys
- increased space for application (/data partition) to 2 Gb
- Google Play Store fixes so more applications are visible/compatible
- Android 4.2 AOSP stock launcher from here, thanks mad86
Download:Â kasty-fnf_ifive_mx_3g-411-120-rooted2.zip
Use Rockchip Batch Tool version 1.5 to flash the firmware, don't flash using the "sdcard" method.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive MX 3GÂ to test it.
PietKn, mad86 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I've removed most iFive applications, I have just left FiveVideoPlayer.apk as it may be required.
iFive launcher has been removed as well, actually, it's possible there's no launcher at all, which could be a problem  I'll need to know... so we could decide if we put back iFive launcher, a stock Android launcher or a replacement.
Yes so there is no lancher but the stock 4.2 android launcher work well
if you want i make a tuto here :
http://www.tablette-chinoise.net/t1078-tuto-suppression-surcouche-ifive
Do you know how to modify the lockscreen because there is the Shenzen meteo on it and i don't find where to modify this without to add another lockscreen like holo.
I'm removing this firmware then and I'll rebuilt it with Android stock launcher.
Post #1 updated, now included Android 4.2 AOSP launcher.
No idea about the lockscreen.
Just a question admin do you want anothers users of ifive tablets to create customs roms for the others ifive tablets like Tinm wich as an MX only wifi. I can redirect anothers members with ifive mini or ifive 2 for example
Flash is OK starting tablet OK just an issue for launcher but works with 4.2 launcher is OK.
The following users say thank you to mad86 for this useful post:
PietKn
2013/04/26
Yes you did implicitely. Via your French forum landed here to see what's ongoing. All knowledge is here available . . . . Thanks Mad86 to start this up!
So i install this firmware, all seems to be good and sems to be more responsive I just had a crash when android try to open the launcher at first start but launcher is 4.2 AOSP and work without problems
Great thanks for admin
For tinm his tablet is an MX WIFI only and he try your firmware but have not wifi activated. The hardware seems to be a little different
Last question, i'm not able to boot the tablet in recovery since th flas => i go trying to reinstall CWM Recovery
Edit : CWM Recovery is installed without problems
I am not sure to understand, does the firmware function right after flash or does it need any manipulation to work properly ?
About firmwares for other iFive tablet models, I'll eventually do a custom firmwares if there is enough demand, making a firmware for just 2 people isn't really interesting for me, unless there is some donation/support...
2013/04/26
I'll donate anyhow as i was flabbergasted to see that you just did the customisation within a couple of hours, saving me the time to do the rooting, deinstalling manually.Â
Currently Online: jessicapeterson
73 Guest(s)
Devices in use: Desktop (58), Phone (16)
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
andre92
