[HELP] Lockscreen mod
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/27 - 08:37
i create this new topic to say help for modifying the ifive lockscreen. First there is 12 chinese wallpapers in framework-res.apk that i have already changed with success. But there is shenzen meteo which i can not find where to modify.
my goal is if we can modify meteo location is great or if is not possible replace ifive lockscreen by AOSP android lockscreen :) and finally upgrade this in custom firmware.
an example of ifive lockscreen :
photo.JPGImage Enlarger
Thanks a lot by advance for help :)
2013/04/27 - 10:23
Well, changing the lockscreen is probably easier than trying to modify the existing one.
Have you tried yet ?
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/27 - 14:18
Yes i try to replace framework-res.apk by 4.1.1 AOSP one => the tablet don't boot.
i also try to modify framework-res by replacing keyguard_screen_tab_unlock.xml
keyguard_screen_tab_unlock_land.xml => there is no effect.
the problem is that i don't find any informations about files necessary for screenlock :P
Thanks Received: 264
2013/04/27 - 23:40
mad86
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/28 - 08:18
Thanks i go to read this ;)
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/28 - 18:46
Hi
I look your link but i don't understand in what that help me for lockscreen ?
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/29 - 11:31
Hi Globula and/or admin :P
Do you knows which files i need to replace in firmware to get AOSP lockdcreen ? :) because i don't find with my friend google :P
2013/04/29 - 11:32
No idea, I couldn't find either, the customization of the lockscreen is probably done in the framework files.
2013/04/29 - 11:58
have a go with this
http://uot.dakra.lt/
mad86
Forum Posts: 71
Thanks Received: 4
2013/04/29 - 12:13
Thanks for you two ;) i go to test online kitchen :)
radokizi
2013/06/19 - 11:27
Has anyone solved the problem with this lockscreen?
shoa
Thanks Received: 6
2014/05/22 - 16:09
Go to settings - security - and check the box @ widgets enable
Then you can replace the widget at the lockscreen
Please explain me how to change the lockscreen images
85 Guest(s)
Devices in use: Desktop (70), Phone (15)
hans41
rickybk
soniya07
ironmangitar
