Enable multi-user on RK3188 4.4.2
This procedure disables Rockchip's forced single-user patch
didierm
Forum Posts: 12
Thanks Received: 4
2014/01/26 - 20:56
Admin edit: I have removed the <PRE> tags in this post HTML code so it appears properly formatted.
This is a guide to re-enable multi-user support on Rockchip-based Android 4.4.2.
Disclaimers :
- Please note : as I am a complete Android novice, it is entirely possible (and even probable) that alternative and more straightforward solutions exist.
- I accept no responsability should you brick or otherwise make defunct your device by following this guide.
- AOSP seems to be licensed under ASLv2.0 and GPLv2 ; should this guide conflict with Rockchip's rights, I kindly ask the forum admins to remove this post.
Preamble :
Examining the MK908 Android 4.4.2 source code (*), Rockchip uses the build.prop "ro.factory.hasUMS" property to apply custom codepaths.
(*) http://www.cnx-software.com/2013/12/31/android-4-4-2-kitkat-sdk-released-for-rockchip-rk3188-mini-pcs-mk908-mk908-ii-mk918-and-a9/
'hasUMS' is used in :
device/rockchip/rksdk/device.mk
device/rockchip/rksdk/init.rk30board.rc
frameworks/base/core/java/android/os/UserManager.java
frameworks/base/services/java/com/android/server/MountService.java
frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java
packages/providers/MediaProvider/src/com/android/providers/media/MediaProvider.java
packages/apps/Settings/src/com/android/settings/deviceinfo/UsbSettings.java
Examining init.rk30board.rc, it appears 'hasUMS' decides between emulated and physical storage (hence my guess UMS stands for 'USB Mass Storage').
Problem :
In Android 4.4 (and possibly earlier) and for reasons hitherto unknown (maybe because VFAT does not support multi-user file ownership ?), Rockchip disables multi-user support in UserManager.java if "ro.factory.hasUMS=true" (which is the default) :
        String enableUms= SystemProperties.get("ro.factory.hasUMS","false");
        if("true".equals(enableUms))
            Log.d(TAG,"---getMaxSupportedUsers,we has UMS,force disabled M-user---");
            return 1;
Re-enabling multi-user by setting "ro.factory.hasUMS=false" in /system/build.prop (and adding the property "fw.max_users=X", with X>1) is not possible, as this renders the O/S unusable (probably due to the custom codepaths in other parts of the source tree, see above).
Hence it seems the solution requires the "hasUMS=true" condition to be removed from UserManager.java.
My testing device is an FNF iFive X2, with the most recent firmware ifiveX2_FW_442_V2.0.1_201401221700 .
Recompiling the published source tree (see above) is not feasible, as the code may be oriented to the MK908, and the status and/or existence of custom patches by FNF/iFive is unknown.
Solution :
Patch the binary containing the compiled UserManager.java code.
Step-by-step guide :
(Linux-oriented, similar tools exist for Windows)
* Download and unpack 'APK-Multi-Tool' (http://forum.xda-developers.com/showthread.php?t=1808319)
* Download 'baksmali'/'smali' (https://code.google.com/p/smali/), and move these files into APK-Multi-Tool's "other" directory
* Run 'setup.sh' :
    - apply file permissions and create default directories
* 'UserManager.java' was compiled into 'framework.jar' :
    $ adb pull /system/framework/framework.jar
    $ mv framework.jar place-jar-here-for-modding/
* Disassemble the jar by running './script.sh' :
    - choose option 14 ('decompile Jar / classes.dex')
* In another shell, modify UserManager.java, so the Rockchip-added codepath never gets executed :
    $ sed -i 's/ro.factory.hasUMS/ro.factory.ha__MS/' working/framework.jar/android/os/UserManager.smali
* Back to APK-Multi-Tool, recompile classes.dex :
    - choose option 15 ('Compile Jar / classes.dex'), and exit the tool
* Reassemble the jar :
    $ mkdir framework-new ; cd framework-new
    $ unzip ../place-jar-here-for-modding/org-framework.jar
    $ cp -a ../place-jar-here-for-modding/classes.dex .
    $ jar cf ../framework-new.jar classes.dex preloaded-classes
* Replace the old jar and enable multi-user :
    $ adb remount
    $ adb push ../framework-new.jar /system/
    $ adb shell chown 0.0 /system/framework-new.jar
    $ adb shell chmod 0644 /system/framework-new.jar
    $ adb shell echo "fw.max_users=8" >> /system/build.prop
    $ adb shell mv /system/framework-new.jar /system/framework/framework.jar
    $ adb reboot recovery
* In recovery mode, clean the dalvik-cache and reboot
Notes :
1. As code changes between firmware updates, you will need to repeat this procedure after every firmware upgrade.
The string "we has UMS,force disabled M-user" in /system/framework/framework.jar/classes.dex may be a good indicator of the presence of Rockchip's patch.
2. Considering the fact that the above is based on Rockchip's source code, this procedure should apply to all RK3188-based 4.4.2 tablets.
HTH.
The following users say thank you to didierm for this useful post:
admin, manupc
manupc
Forum Posts: 18
Thanks Received: 12
2014/01/28 - 12:54
Hi, thanks for effort. I have followed all your steps and tested the modified framework.jar but somehow multi-user is not full working at all. I am able to create so many users as stated in fw.max_users but the problem is when swichting to a new created user, im not able to use the back button and not able to change the new user´s name since keyboard wont appear. There must be something else needed to be changed to make it completely work. The new added ro.factory.hasUMS in ifive X2 could be messing somewhere else...
didierm
Forum Posts: 12
Thanks Received: 4
2014/01/28 - 19:52
When you navigate to Settings > Language & input > Keyboard & Input Methods, you'll notice [Default] is an empty field, and the [Android Keyboard Settings (AOSP)] is not activated and greyed out.
By activating [Google voice typing], [Android Keyboard Settings (AOSP)] gets activated too.
Entering and exiting the settings of AOSP, renders it as [Default], after which you can deactivate [Google voice typing] again.
You should now have a working virtual keyboard.
Thanks Received: 3177
2014/01/28 - 20:51
Thanks again didierm Wink
I have patched and rebuilt the framework.jar file for the PiPO M9 Pro and will be testing it shortly, I will then post the results here.
2014/01/28 - 21:25
From my PiPO M9 Pro test results, I am getting some kind of Android restart (not really a full reboot) after I did Add  / User and I clicked OK button. Still, it seems to have worked as I got the new user created and working.
I have posted a rebuilt firmware for the PiPO M9 pro with the multi-user patch in the M9 Pro section:
http://www.arctablet.com/blog/forum/pipo-max-m9/rom-pipo-m9-pro-wifi-model-android-4-4-2-kitkat-custom-root-firmware-20131226/page-7/#p38083
manupc
Forum Posts: 18
Thanks Received: 12
2014/01/28 - 23:10
Thanks didierm. I got it working now. I will implement it in my rom and share soon. Shame something like that wasnt working before. Nice find!
didierm
Forum Posts: 12
Thanks Received: 4
2014/01/28 - 23:15
If I am not mistaken, this is expected behaviour : the chain of events more or less forces the newly added user to promptly change his/her account details (display name, password mechanism, ...).
didierm
Forum Posts: 12
Thanks Received: 4
2014/01/28 - 23:22
Glad to be of help ; without your reference to Rockchip's KK source code, this would never have been possible. Thanks again !
didierm
Forum Posts: 12
Thanks Received: 4
2014/01/28 - 23:33
My pleasure.
Aren't you the manupc of the Rockchip-4.4.2 modified CWM and OC kernel ?
Do you mind me asking some questions ? Feel free to reply or not, as you see fit.
  1. Do you have any references to your CWM and/or kernel modifications ?
  2. Is your kernel RK3188-generic, or is it adapted to specific brands (Pipo, iFive, ...) ?
  3. What is your build environment for kernel development ?
Myself, I am looking into including Xposed/XPrivacy (and some system-oriented F-Droid OSS apps) into an iFive-oriented firmware roll-out. XPrivacy seems to be rapidly evolving into a decent multi-user aware app, which IMO is required when sharing a tablet with others (kids !).
2014/01/29 - 21:34
manupc
Forum Posts: 18
Thanks Received: 12
2014/01/29 - 23:53
didierm said
My pleasure.
Of course, no problem.
To be honest, i didnt build a CWM recovery and kernel from source. I just applied modifications to previous builds.
In case of CWM recovery, it is a simple copy-paste of files pointing to the right storage partitions and taken from the original kitkat recovery.
In case of the kernel modification, and since i dont have a kernel source, i hex searched a kernel file for a group or table of some specific voltages/frequencies. Once found, replaced them with desired values.
As i know, my kernel does only work on ifive x2, since no other rk3188 kernel ive tested was working on my device.
Im sure you could apply the same method with any other rk3188 kernel. It is just not that funny working with binary code XD
If you need more information im pleasured to help
jazzman123
2014/02/02 - 09:36
Is there any change a new ROM will be out with this patch for the ifive x3 ?
Thank you for your great work!
2014/02/02 - 19:29
jazzman123,
Maybe next week, once the current custom firmwares in the works are finished.
jazzman123
2014/02/02 - 21:11
Nilist
2014/02/24 - 05:55
The creation of new users work, but you are stuck with the name "New User". trying to change the name by tapping on it in setting causes settings to crash.
If you would like a different user name, I found this work-around:
From a Terminal window enter
"su"
"pm create-user someusername"
replace someusername with the name you would like to see on the lock screen (doesn't have to be your gmail name)
Very much appreciated by my kids when they can log on with their own names ;-)
162 Guest(s)
Devices in use: Desktop (157), Phone (4), Tablet (1)
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
hoholms
rammaiden
