RK 3188 MK809iv Please help!! Can't access developers option or Ethernet
MK809iv Rockchip RK3188
Bizarro
2016/02/09 - 03:51
I'm very new to android, (10 days now) I have a MK809iv (RK3188) running 4.4.2
There's no developer option under the system menu, I've clicked on "Build number" option 7-20 times and it says "no need, you are already a developer". Below is the "About device" info, and interestingly when I run Device Test Tool app under "System Info" it states the Kernel is 3.10.0
No matter what I've done the "Developer option" which should pop up between "Printing" and "About device" are no where to be found and also the Ethernet will not enable, just switches back to "OFF" position when I click it.
I'm using an Aukey USB Ethernet bridge, I've tested it on another device and it works, I have 4 mk809iv devices and one of them works fine, the other three have this issue.
Can anyone help with this or point me in the right direction? Thanks in advance.
Model: gxtdongle3188
Android version: 4.4.2
Kernel version: 3.0.36+
ren@gxt#485
Wed Jan 6 14:48:30 CST 2016
Build number:
gxtdongle3188-eng 4.4.2 KTU84Q eng.ren.20160112.174602 test-keys
Vendor software version:
RK3188R-BOXANDROID4.4.2-SDK
51 Guest(s)
Devices in use: Desktop (41), Phone (10)
cutierogue
