2015/03/31
Hi form Barcelona!!
First of all thank you all people of this forum, you make possible the impossible for some of us.
Sorry if it was asked before, I saw something similar but a little bit different...
Go with it. My baby broke touchscreen. So, I decided to change it for myself and I received reference XC-PG0900-003-A1, because vendor says it's the same as 300-N3849M-A00-V1.0 MHS, wich was the original one. It was quite similar and install it.
Things are never easy. And now the touchscreen is rescaled. I explain: in landscape mode when my finger push X=0,Y=50, I see really touch in position X=450,Y=50. X axis has changed; portrait Y displaced.
So, I need your advice. I'm not a noob, I'm a super-noob.
CPU: Rockchip RK3026 on chip (RK3066x2 1,66GHz 912Mhz eSTAR Zoom Duo in CPU-Z)
GPU: Mali-400P
9'' 800x480 120dpi
512Mb RAM
4Gb
Touch Silead GSL3680 on board
Realtek RTL8188ETV
Board rk30sdk in CPU-Z
eSTAR Zoom Duo (eSTAR MID9014) in CPU-Z
Write on Board:
7500-A8526C-06R
MID9526CM-v6.0
2014-02-27
Write on label:
0700-MD9526-07R
WH140313021
I attach you specs web:
http://www.estar.eu/en/zoom-dual-core-9-0-specifications/
I don't know if you need more data, please ask...
I tested a lot of calibration apk and they didn't work...
Question is: Is there a solution for this problem?? If yes, which is the best way to solve?? I think only way is flashing, but I'm not sure...
Thank you very much in advance.
65 Guest(s)
Devices in use: Desktop (57), Phone (8)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
