2014/11/20
hi everybody, I have a china tablet whit rk3026 processor and id c86/14 and the tablet responds to the follow firmware
http://crewrktablets.arctablet.com/?wpfb_dl=1691
but it works badly, the screen resolution is bigger than tablet hardware,I dont know if you can undertandme properly.
I know that the firmware isen't the correct, but i can't find another functional one. I would like you to help.
U9GTV is RK3188.
Every tab has its own specific kernel. So, do not flash anything strange into your tab!
What else is known from the tab? Do you have the stock firmware?
Given that information a scan on www is without any useful result.
So, tab is more or less scrap. You can try to flash this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-roverpad-trc7-android-4-2-2-jelly-bean-custom-root-firmware-20140421/
If the kernel does not work, in post #2 are a lot more to try. You can flash the kernel separately, only click parameter and kernel.
2014/11/20
the kernel of chuwi 17 2nd generation works, but anormally.
look
http://imageshack.com/a/img661/8830/z3yrCU.jpg
http://imageshack.com/a/img674/3212/RjGzMf.jpg
http://imageshack.com/a/img633/6808/Uh0dAT.jpg
http://imageshack.com/a/img538/6103/W741ie.jpg
http://imageshack.com/a/img913/6617/bzt4Wi.jpg
http://imageshack.com/a/img661/1671/zULYvV.jpg
http://imageshack.com/a/img911/1217/k4gojJ.jpg
http://imageshack.com/a/img633/8665/CotO29.jpg
http://imageshack.com/a/img673/4323/VuKuay.jpg
http://imageshack.com/a/img907/4493/kpS2uH.jpg
http://imageshack.com/a/img674/3315/Tgm403.jpg
http://imageshack.com/a/img537/1615/XwRtSe.jpg
http://imageshack.com/a/img674/3094/4vcV0D.jpg
Check with this kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1874
What does this mean exactly? No screen or screens fits now?
2014/11/20
the screen appears but it's displaced, and not advance to the operative system
http://imageshack.com/a/img540/3362/GpPNGQ.jpg
http://imageshack.com/a/img661/3391/7van4L.jpg
http://imageshack.com/a/img674/7032/TXea2K.jpg
Go on with the other kernel.
56 Guest(s)
Devices in use: Desktop (50), Phone (6)
Dante1975
adb
amanita12
mony18
spiik
nikitamaan
