Request firmware for KUNO 4 Tablet
Thanks Received: 1378
2016/05/05 - 07:27
Try with stock recovery first: http://crewrktablets.arctablet.com/?wpfb_dl=1036
Just change in folder rockdev/Image (rename old recovery to CWM first) and flash again, incl. eraseIDB.
2016/05/05 - 08:52
You can flash the CWM later on. Rename it to recovery and tick only parameter, recovery, misc.
For wifi install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2871
For rotation pls try the sensor fixes linked on the blog.
crstflln706
2017/07/31 - 00:21
Hello, I have several kuno 4s I successfully rooted with Kingoroot. Installed cm 10.1 v1.4 and kuno kernal, formatted the NAND, installed the sensor fix. My only issue is after install the wifi model fix posted the wifi turns off and on continuously. It never even turns on enough to detect a network. Secondly it randomly reboots alot.
2017/08/07 - 16:10
So what is the difference between Kuno 4 and Kuno 4s? Can you pls upload a dmesg log from the running stock firmware?
Falax41
2017/08/07 - 20:06
The 4 and 4s are identical as far as I can tell.  I have reloaded several thousand of each... internally they are the same (identical boards, chips, etc.)  I believe the 4s came into existence when CirriculumLoft was bought out.
I could only get Android 4.1.1 to work correctly on them.  I could get 4.4 to boot, but never could get all of the features to work properly.
The offer still stands... I can send you one if you like...
-Falax41
crstflln706
2017/08/07 - 20:32
My bad I meant multiple kuno 4 tablets not "kuno 4s" sorry about the confusion. I'll upload the dmesg once I'm off work. Thx so much for the reply Oma this tablet had been driving me crazy trying to get it working.
Falax41
2017/08/07 - 20:39
If you would like a stock image for these, let me know.  4.1.1 fully functional with the CL stuff loaded but not active.
crstflln706
2017/08/07 - 20:47
Sure, that would be helpful. I have one still on stock but I removed the curriculum loft software from it but it was laggy idk if that's normal or because I removed the the app. I got everything working on the cm 10.1 v1.4 except for wifi and random reboots.
crstflln706
2017/08/08 - 04:26
Here the the dmesg https://drive.google.com/file/d/0ByQfmeh26iVQNEc5b3JraTI0dFU/view?usp=drivesdk
2017/08/08 - 14:29
<4>[ 15.692893] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.60.WFD.JB4.1) init.
<4>[ 18.579213] Final fw_path=/system/etc/firmware/fw_RK903_ag.bin
<4>[ 18.579221] Final nv_path=/system/etc/firmware/nvram_ap6330.txt
Pls check the v3.4 build using the Kuno 4 kernel: http://crewrktablets.arctablet.com/?p=2315
crstflln706
2017/08/09 - 06:12
Will do asap. I recently sold my windows 7 laptop that I used to flash my kuno 4 what I didn't know was. Widows 10 for the life of me won't install the rockchip drivers.
crstflln706
2017/08/09 - 22:24
Okay so I installed the aosp 4.2.2 rom and fixes. Wifi still won't turn on, it isn't doing the switching off and on anymore. Just tried to turn on and then turns off. Also the orientation sensors aren't exactly right. Would the fixes for cm 10.1 work for this rom?
2017/08/09 - 22:36
Can I have a dmesg of this situation? Pls reboot tab and try to enable wifi a few times. Then do the dmesg.
crstflln706
2017/08/09 - 23:37
 Actually I flashed the Kuno 4 model fix, analyse sensor fix, and sensor fix 3 from the CM 10.1 v1.4 and rotation, orientation, and wifi work now. Thanks so much OMA if I experience any more issues I'll post them. Also is there anyway to get rid of the software volume button and the bottom like with the phablet ui and one issue I am experiencing is a lot of things are shades of blue instead of the right color.
2017/08/10 - 19:16
Fine.
77 Guest(s)
Devices in use: Desktop (70), Phone (5), Tablet (2)
beppebettini58@gmail.com
marcodigio77
marcodigio
dimitrifrom31
svilbg
theelf
