2015/10/20
Hi Guys,
I would like to thanks this forum for the supporting, i succeed to root and install CWM for it.
Now i need a stock firmware or custom firmware with installation tools for Kuno 4 Tablet.
Device type:KUNO4
Battery:100%
Firmware:4.1.1
WiFi:On
ROOT:Rooted
Resolution:1024*768
Serial code:OUGRYUZ77H
IMEI:Unknown
IMSI:Unknown
Baseband:Unknown
Kernel:rk30sdk-user 4.1.1 JRO03H 20130715.134716 release-keys
MoboDaemon:2.6.306
mgra99Per aspera ad astra, we rock the Tablets !
2015/10/20
Dump the firmware first: http://www.arctablet.com/blog/forum/crewrktablets-rk3066-entwicklung-customroms-development-croms/rk3066-root-and-dump-the-stock-firmware/- Oma -
Thanks Oma7144
what i understand from above link that simple tool is taking an firmware image from the tablet and save it.
the problem in my kuno 4 tablet is i have a virus in ROM and i installed alot of antivirus but they can't delete it even i factory reset it same virus also while playing its freeze and bring white screen so i have to reboot.
please help me
No virus. Pls upload the dump.
Is the tab rooted? If not pls install superuser via CWM: https://download.chainfire.eu/696/SuperSU
2015/10/20
Is the tab rooted? If not pls install superuser via CWM: https://download.chainfire.eu/696/SuperSU- Oma -
yes it's Rooted, i tried to install superSu from CWM but said can't mount sd_card or can't mount external_sd card.
Donwload a terminal from Play Store and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd > /mnt/sdcard/mtd.txt
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd9 of=/sdcard/system.img bs=4096
Zip the files and upload the archive to a filehoster. Post the link here. I will check.
2015/10/20
Dear OMA,
Donwload a terminal from Play Store and type:su
dd if=/dev/mtd/mtd9 of=/sdcard/system.img bs=4096Zip the files and upload the archive to a filehoster. Post the link here. I will check.
Dear Oma,sorry for the delay and here is the link http://www.4shared.com/rar/10omMM3rba/SysLog.html
2015/10/20
OMA , Is there any update? don't forget me.
Ok, AP6330 wifi.
<4>[ 16.602196] FW_PATH = /system/etc/firmware/fw_RK903_ag.bin
<4>[ 16.602199] NVRAM_PATH = /system/etc/firmware/nvram_ap6330.txt
Latest build: http://crewrktablets.arctablet.com/?p=1913
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2760
Just change kernel in folder rockdev/Image before flash.
2014/12/08
I loaded one of the Kuno's with "CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.4" used the Kuno Kernal and then ran the NAND Fix, and the unit always boots to CWM Recovery. I can't seem to get past the recovery mode on the unit once flashed. If I flash it back to my old backup, it will work again.
Any suggestions?
2014/12/08
OMA, after playing with a few different units I was able to get it fully loaded. The only trouble that I have now is that the WiFi doesn't work (but the bluetooth does). Also the screen is 90 degrees off with the automatic adjustments. Do you have any idea on how I go about fixing the WiFi?
Thanks for your help,
-Falax41
60 Guest(s)
Devices in use: Desktop (44), Phone (16)
cutierogue
