2014/05/23
Hello.
could you please help me to flash my device ?
it's a RK30** based device (maybe a RK3066).
I have yet tested a lot of possibility..... but now way to flash a custom recovery ;-(
I would like install TWRP or CWM
I tested :
Arctools.apk (don't work) / room manager (don't work) / a batch tool adb installer (don't work) / fastboot in bootloader mode (don't work_no device detected) / directly flash some update.zip from the original recovery (don't work).
My device is rooted buit nothing work for me.
I tried also to flash diferent recovery.img from RKFLASHKIT (ubuntu inside ).
so.... i'm a little bit lost.
For security I dumped these originals partitions :
misc.img
recovery.img
boot.img
kernel.img
I can also provide a complete dmesg in a second post.
So, I hope you will be able to help me to find a good version of recovery and the good way to flash it !
I thank you in advance !
2014/05/23
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.0.8+ (yudongsheng@ubuntu) (gcc version 4.4.3 (GCC) ) #233 SMP PREEMPT Mon Sep 2 18:37:15 CST 2013
<4>[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
<4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ 0.000000] Machine: RK30board
<6>[ 0.000000] memory reserve: Memory(base:0x91800000 size:80M) reserved for <ion>
<6>[ 0.000000] memory reserve: Memory(base:0x90c00000 size:12M) reserved for <fb0 buf>
<6>[ 0.000000] memory reserve: Memory(base:0x90600000 size:6M) reserved for <camera_ipp_mem>
<6>[ 0.000000] memory reserve: Total reserved 98M
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[ 0.000000] bootconsole [earlycon0] enabled
<4>[ 0.000000] CPU SRAM: copied sram code from c0aa7000 to fef00100 - fef023d0
<4>[ 0.000000] CPU SRAM: copied sram data from c0aa92d0 to fef03000 - fef03920
<6>[ 0.000000] L310 cache controller enabled
<6>[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
<4>[ 0.000000] DDR DEBUG: version 1.00 20130121
<4>[ 0.000000] DDR DEBUG: DDR3 Device
<4>[ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.000000] DDR DEBUG: init success!!! freq=300MHz
<4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
<4>[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
<4>[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.000000] rk30_iomux_init
<4>[ 0.000000] Boot mode: 6 flag: 0xc3524200
<7>[ 0.000000] On node 0 totalpages: 237056
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0aa6340, node_mem_map c152d000
<7>[ 0.000000] Normal zone: 1744 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 196400 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 304 pages used for memmap
<7>[ 0.000000] HighMem zone: 38608 pages, LIFO batch:7
<6>[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1d35000 s7072 r8192 d13408 u32768
<7>[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 235008
<5>[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00180000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00200000@0x00080000(userdata),0x00002000@0x00280000(kpanic),0x00190000@0x00282000(system),-@0x00412000(user) bootver=2013-06-20#1.34 firmware_ver=4.1.1
<6>[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Memory: 774MB 152MB = 926MB total
<5>[ 0.000000] Memory: 920020k/920020k available, 128556k reserved, 155648K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
<5>[ 0.000000] vmalloc : 0xf7000000 - 0xfe800000 ( 120 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xf6800000 ( 872 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .init : 0xc0408000 - 0xc048d000 ( 532 kB)
<5>[ 0.000000] .text : 0xc048d000 - 0xc0a411cc (5841 kB)
<5>[ 0.000000] .data : 0xc0a42000 - 0xc0aa6e60 ( 404 kB)
<5>[ 0.000000] .bss : 0xc0aaa024 - 0xc152c388 (10761 kB)
<6>[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:416
<4>[ 0.000000] rk30_gpio_init: 176 gpio irqs in 6 banks
<6>[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>[ 0.000000] Console: colour dummy device 80x30
<6>[ 0.004965] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
<6>[ 0.013833] pid_max: default: 32768 minimum: 301
<6>[ 0.019037] Mount-cache hash table entries: 512
<6>[ 0.024581] Initializing cgroup subsys debug
<6>[ 0.029240] Initializing cgroup subsys cpuacct
<6>[ 0.034099] Initializing cgroup subsys freezer
<6>[ 0.038983] CPU: Testing write buffer coherency: ok
<4>[ 0.145025] CPU1: Booted secondary processor
<6>[ 0.145071] Brought up 2 CPUs
<6>[ 0.152997] SMP: Total of 2 processors activated (3262.93 BogoMIPS).
<6>[ 0.160214] devtmpfs: initialized
<6>[ 0.171372] NET: Registered protocol family 16
<4>[ 0.176259] last_log: 0xf0100000 0xc0aae210
<4>[ 0.182918] ------------[ cut here ]------------
<4>[ 0.187958] WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x48/0x114()
<4>[ 0.196340] autorequest GPIO-183
<4>[ 0.199929] [<c04981c4>] (unwind_backtrace+0x0/0xf0) from [<c04c0ae0>] (warn_slowpath_common+0x4c/0x64)
<4>[ 0.210067] [<c04c0ae0>] (warn_slowpath_common+0x4c/0x64) from [<c04c0b78>] (warn_slowpath_fmt+0x2c/0x3c)
<4>[ 0.220438] [<c04c0b78>] (warn_slowpath_fmt+0x2c/0x3c) from [<c061a4f0>] (gpio_ensure_requested+0x48/0x114)
<4>[ 0.230984] [<c061a4f0>] (gpio_ensure_requested+0x48/0x114) from [<c061aba0>] (gpio_direction_output+0x7c/0xfc)
<4>[ 0.241938] [<c061aba0>] (gpio_direction_output+0x7c/0xfc) from [<c040e444>] (machine_rk30_board_init+0x34/0x288)
<4>[ 0.252985] [<c040e444>] (machine_rk30_board_init+0x34/0x288) from [<c040a4d8>] (customize_machine+0x1c/0x28)
<4>[ 0.263713] [<c040a4d8>] (customize_machine+0x1c/0x28) from [<c048d5d8>] (do_one_initcall+0x94/0x164)
<4>[ 0.273604] [<c048d5d8>] (do_one_initcall+0x94/0x164) from [<c0408350>] (kernel_init+0x88/0x130)
<4>[ 0.283027] [<c0408350>] (kernel_init+0x88/0x130) from [<c0493678>] (kernel_thread_exit+0x0/0x8)
<4>[ 0.292464] ---[ end trace 1b75b31a2719ed1c ]---
<6>[ 0.398156] rk29sdk_wifi_bt_gpio_control_init: init finished
<6>[ 0.408723] console [ttyFIQ0] enabled, bootconsole disabled
<6>[ 0.414889] Registered FIQ tty driver f008fc00
<6>[ 0.426987] bio: create slab <bio-0> at 0
<4>[ 0.431222] wm831x_dcdc_init
<4>[ 0.431404] wm831x_ldo_init
<5>[ 0.431758] SCSI subsystem initialized
<6>[ 0.431971] usbcore: registered new interface driver usbfs
<6>[ 0.432043] usbcore: registered new interface driver hub
<6>[ 0.434252] usbcore: registered new device driver usb
<6>[ 0.434711] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
<6>[ 0.434938] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
<6>[ 0.435151] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
<6>[ 0.435260] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
<6>[ 0.435379] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
<6>[ 0.483138] rk30-adc rk30-adc: rk30 adc: driver initialized
<4>[ 0.483433] timed_gpio_probe
<6>[ 0.483524] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[ 0.483920] Bluetooth: Core ver 2.16
<6>[ 0.483970] NET: Registered protocol family 31
<6>[ 0.483982] Bluetooth: HCI device and connection manager initialized
<6>[ 0.483999] Bluetooth: HCI socket layer initialized
<6>[ 0.484011] Bluetooth: L2CAP socket layer initialized
<6>[ 0.484036] Bluetooth: SCO socket layer initialized
<4>[ 0.485072] rk fb probe ok!
<4>[ 0.485164] wm831x_i2c_init
<6>[ 0.532516] cfg80211: Calling CRDA to update world regulatory domain
<3>[ 0.884439] rk30_i2c rk30_i2c.1: Addr[0x34] wait event timeout, state: 0, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x0
<4>[ 0.904437] rk30_i2c rk30_i2c.1: I2C_CON: start bit is set
<3>[ 0.924437] wm831x 1-0034: Failed to read parent ID: -110
<4>[ 0.924461] wm831x: probe of 1-0034 failed with error -110
<3>[ 1.324439] rk30_i2c rk30_i2c.1: Addr[0x2d] wait event timeout, state: 0, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
<3>[ 1.364436] tps65910 1-002d: tps65910_set_bits:read from reg 3f failed
<3>[ 1.764438] rk30_i2c rk30_i2c.1: Addr[0x2d] wait event timeout, state: 0, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
<3>[ 1.804436] tps65910 1-002d: read from reg 46 failed
<3>[ 1.804451] tps65910 1-002d: Error in configuring external control EN1
<4>[ 1.804465] tps65910 1-002d: Failed to initialise ext control config
<3>[ 2.204439] rk30_i2c rk30_i2c.1: Addr[0x2d] wait event timeout, state: 0, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
<3>[ 2.244436] tps65910 1-002d: tps65910_set_bits:read from reg 20 failed
<3>[ 2.244453] set_machine_constraints: VIO: failed to enable
<3>[ 2.244515] tps65910 1-002d: failed to register tps65910-pmic regulator
<4>[ 2.244536] tps65910-pmic: probe of tps65910-pmic failed with error -110
<4>[ 2.244680] tps65910_pre_init,line=38
<3>[ 2.644440] rk30_i2c rk30_i2c.1: Addr[0x2d] wait event timeout, state: 0, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
<3>[ 2.684437] tps65910 1-002d: Read from reg 0x40 failed
<3>[ 2.684451] Unable to read TPS65910_DEVCTRL2 reg
<3>[ 2.684463] tps65910 1-002d: pre_init() failed: -110
<4>[ 2.684601] tps65910: probe of 1-002d failed with error -110
<6>[ 2.684808] Switching to clocksource timer1
<4>[ 2.685016] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf701c000
<4>[ 2.685049] fb0:win1
<4>[ 2.685052] fb1:win0
<4>[ 2.685056] fb2:win2
<6>[ 2.685065] Switched to NOHz mode on CPU #1
<4>[ 2.685153] lcdc0: dclk:33000000>>fps:59 rk30_load_screen for lcdc0 ok!
<6>[ 2.694437] Switched to NOHz mode on CPU #0
<4>[ 2.713630] fb0:phy:90c00000>>vir:f8000000>>len:0xc00000
<4>[ 2.713896] rk_fb_register>>>>>fb0
<4>[ 2.714053] rk_fb_register>>>>>fb1
<4>[ 2.714227] rk_fb_register>>>>>fb2
<4>[ 2.714240] lcdc0 wakeup from stanby
<6>[ 2.714250] lcdc0 win1 open
<4>[ 2.731799] rk30 lcdc0 probe ok!
<4>[ 2.731858] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf7028000
<4>[ 2.731891] fb0:win1
<4>[ 2.731895] fb1:win0
<4>[ 2.731898] fb2:win2
<4>[ 2.731952] lcdc1: dclk:74250000>>fps:60 rk30_load_screen for lcdc1 ok!
<4>[ 2.731974] fb3:phy:90c00000>>vir:f8000000>>len:0xc00000
<4>[ 2.732253] rk_fb_register>>>>>fb3
<4>[ 2.732420] rk_fb_register>>>>>fb4
<4>[ 2.732568] rk_fb_register>>>>>fb5
<4>[ 2.732579] rk30 lcdc1 probe ok!
<4>[ 2.732637] -------------------------------------------------boot with some other pmu,this is important notify-------------------------------------------------pwm_regulator_probe:n_voltages=17
<4>[ 2.732844] pwm_regulator.0: driver initialized
<4>[ 2.732856] rk30 pwm regulator is ok with pmu tps65910
<4>[ 2.742902] pwm_regulator_probe set vdd_core=1100000mV end
<4>[ 2.870731] regbase f7080000 0x0, otg_phy_confed08184, 0x550
<6>[ 2.920980] rk30_adc_battery: driver initialized
<6>[ 2.921245] NET: Registered protocol family 2
<6>[ 2.921372] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 2.921722] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
<6>[ 2.923559] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[ 2.924621] TCP: Hash tables configured (established 131072 bind 65536)
<6>[ 2.924635] TCP reno registered
<6>[ 2.924648] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 2.924687] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 2.925056] NET: Registered protocol family 1
<4>[ 2.925231] RK29 Backlight Driver Initialized.
<6>[ 2.925425] Unpacking initramfs...
<6>[ 3.000775] Freeing initrd memory: 1536K
<6>[ 3.000973] rk30-tsadc rk30-tsadc: initialized
<6>[ 3.001830] Loaded driver for PL330 DMAC-1 rk29-pl330
<6>[ 3.001847] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
<6>[ 3.002002] Loaded driver for PL330 DMAC-2 rk29-pl330
<6>[ 3.002017] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
<4>[ 3.009188] highmem bounce pool size: 64 pages
<6>[ 3.009376] ashmem: initialized
<6>[ 3.014384] fuse init (API version 7.16)
<6>[ 3.015969] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 3.015988] io scheduler noop registered
<6>[ 3.015998] io scheduler deadline registered
<6>[ 3.016056] io scheduler cfq registered (default)
<6>[ 3.022108] rga: Driver loaded succesfully
<4>[ 3.022746] rk_serial.c v1.3 2012-12-14
<6>[ 3.022838] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
<6>[ 3.044916] rk_serial rk_serial.0: membase 0xf704c000
<6>[ 3.044980] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
<6>[ 3.084869] rk_serial rk_serial.3: membase 0xf7050000
<6>[ 3.085144] Rockchip ion module(version: 1.0) is successfully loaded
<6>[ 3.087680] loop: module loaded
<6>[ 3.087788] Android kernel panic handler initialized (bind=kpanic)
<6>[ 3.088503] PPP generic driver version 2.4.2
<6>[ 3.088688] PPP Deflate Compression module registered
<6>[ 3.088701] PPP BSD Compression module registered
<6>[ 3.089295] PPP MPPE Compression module registered
<6>[ 3.089311] NET: Registered protocol family 24
<6>[ 3.089390] usbcore: registered new interface driver asix
<6>[ 3.089440] usbcore: registered new interface driver cdc_ether
<6>[ 3.089486] usbcore: registered new interface driver dm9620
<6>[ 3.089532] usbcore: registered new interface driver SR9700_android
<6>[ 3.089577] usbcore: registered new interface driver net1080
<6>[ 3.089621] usbcore: registered new interface driver cdc_subset
<6>[ 3.089674] usbcore: registered new interface driver zaurus
<6>[ 3.089697] cdc_ncm: 04-Aug-2011
<6>[ 3.089741] usbcore: registered new interface driver cdc_ncm
<4>[ 3.089753] Rockchip WiFi SYS interface (V1.00) ...
<6>[ 3.089797] Initializing USB Mass Storage driver...
<6>[ 3.089858] usbcore: registered new interface driver usb-storage
<6>[ 3.089870] USB Mass Storage support registered.
<6>[ 3.089988] usbcore: registered new interface driver usbserial
<6>[ 3.090033] USB Serial support registered for generic
<6>[ 3.090086] usbcore: registered new interface driver usbserial_generic
<6>[ 3.090099] usbserial: USB Serial Driver core
<6>[ 3.090139] USB Serial support registered for GSM modem (1-port)
<6>[ 3.090193] usbcore: registered new interface driver option
<6>[ 3.090205] option: v0.7.2:USB Driver for GSM modems
<6>[ 3.300992] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
<6>[ 3.301017] usb20_otg usb20_otg: DWC OTG Controller
<6>[ 3.301042] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
<6>[ 3.301072] usb20_otg usb20_otg: irq 48, io mem 0x00000000
<6>[ 3.301081] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
<6>[ 3.301128] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.301141] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.301151] usb usb1: Product: DWC OTG Controller
<6>[ 3.301159] usb usb1: Manufacturer: Linux 3.0.8+ dwc_otg_hcd
<6>[ 3.301167] usb usb1: SerialNumber: usb20_otg
<6>[ 3.301501] hub 1-0:1.0: USB hub found
<6>[ 3.301516] hub 1-0:1.0: 1 port detected
<6>[ 3.302100] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xf7180000
<6>[ 3.512773] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 3.512796] usb20_host usb20_host: DWC OTG Controller
<6>[ 3.512818] usb20_host usb20_host: new USB bus registered, assigned bus number 2
<6>[ 3.512845] usb20_host usb20_host: irq 49, io mem 0x00000000
<6>[ 3.512887] DWC_OTG: Init: Port Power? op_state=1
<6>[ 3.512895] DWC_OTG: Init: Power Port (0)
<6>[ 3.512933] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.512945] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.512955] usb usb2: Product: DWC OTG Controller
<6>[ 3.512963] usb usb2: Manufacturer: Linux 3.0.8+ host20_hcd
<6>[ 3.512971] usb usb2: SerialNumber: usb20_host
<6>[ 3.513248] hub 2-0:1.0: USB hub found
<6>[ 3.513263] hub 2-0:1.0: 1 port detected
<6>[ 3.514441] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 3.514453] android_usb gadget: Number of LUNs=2
<6>[ 3.514462] lun0: LUN: removable file: (no medium)
<6>[ 3.514471] lun1: LUN: removable file: (no medium)
<6>[ 3.514625] android_usb gadget: android_usb ready
<6>[ 3.514812] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
<4>[ 3.515006] ==gsl_ts_init==
<4>[ 3.515038] GSLX680 Enter gsl_ts_probe
<4>[ 3.515045] ==kzalloc success=
<4>[ 3.515051] [GSLX680] Enter gslX680_ts_init
<6>[ 3.515241] input: gslX680 as /devices/platform/rk30_i2c.2/i2c-2/2-0040/input/input1
<4>[ 3.605422] I read reg 0xf0 is 0
<4>[ 3.625190] I write reg 0xf0 0x12
<4>[ 3.645345] I read reg 0xf0 is 0x12
<3>[ 3.645687] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ 3.646027] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ 3.646366] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<3>[ 3.745366] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ 3.745875] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ 3.746372] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<4>[ 3.814895] =============gsl_load_fw start==============
<6>[ 3.894947] usb 2-1: new high speed USB device number 2 using usb20_host
<6>[ 4.105961] usb 2-1: New USB device found, idVendor=0bda, idProduct=0179
<6>[ 4.106033] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 4.106081] usb 2-1: Product: 802.11n NIC
<6>[ 4.106116] usb 2-1: Manufacturer: Realtek
<6>[ 4.106150] usb 2-1: SerialNumber: 00AE0E0372CD
<4>[ 4.489292] =============gsl_load_fw end==============
<3>[ 4.535378] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ 4.535938] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ 4.536452] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<4>[ 4.695988] [GSLX680] End gsl_ts_probe
<4>[ 4.696156] ret=0
<4>[ 4.696796] sensor_register_slave:mxc6225,id=16
<4>[ 4.696838] sensor_register_slave:akm8975,id=18
<4>[ 4.697136] sensor_register_slave:l3g4200d,id=31
<4>[ 4.697175] sensor_register_slave:cm3217,id=34
<4>[ 4.697205] light_cm3217_init
<6>[ 4.698522] lirc_dev: IR Remote Control driver registered, major 250
<6>[ 4.698568] IR NEC protocol handler initialized
<6>[ 4.698600] IR RC5(x) protocol handler initialized
<6>[ 4.698632] IR RC6 protocol handler initialized
<6>[ 4.698662] IR JVC protocol handler initialized
<6>[ 4.698693] IR Sony protocol handler initialized
<6>[ 4.698724] IR RC5 (streamzap) protocol handler initialized
<6>[ 4.698758] IR LIRC bridge handler initialized
<6>[ 4.698787] Linux video capture interface: v2.00
<4>[ 4.699398] start_charge_logo_display
<6>[ 4.700715] device-mapper: uevent: version 1.0.3
<6>[ 4.701579] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>[ 4.702357] Bluetooth: HCI UART driver ver 2.2
<6>[ 4.702401] Bluetooth: HCI H4 protocol initialized
<6>[ 4.702436] Bluetooth: HCILL protocol initialized
<6>[ 4.702976] cpuidle: using governor ladder
<6>[ 4.703016] cpuidle: using governor menu
<6>[ 4.709081]
<6>[ 4.709092] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc0]
<6>[ 4.714321] rk29_sdmmc_change_clk_div..1928.. newDiv=83, newCLK=298Khz [sd_mmc]
<6>[ 4.714545] .Line3891..The End of SDMMC-probe Ver.5.00 The last modify date is 2012-11-05. [sd_mmc]
<6>[ 4.715141] .Line3891..The End of SDMMC-probe Ver.5.00 The last modify date is 2012-11-05. [sdio]
<7>[ 4.715296] Registered led device: button-backlight
<6>[ 4.717070] usbcore: registered new interface driver usbhid
<6>[ 4.717084] usbhid: USB HID core driver
<6>[ 4.717456] logger: created 256K log 'log_main'
<6>[ 4.717551] logger: created 256K log 'log_events'
<6>[ 4.717660] logger: created 256K log 'log_radio'
<6>[ 4.717755] logger: created 256K log 'log_system'
<4>[ 4.718339] i2c-core: driver [ES8323] using legacy suspend method
<4>[ 4.718354] i2c-core: driver [ES8323] using legacy resume method
<6>[ 4.718541] ES8323 audio_card_init
<6>[ 4.718553] XXXXEnter::audio_card_init----201
<4>[ 4.718789] es8323_probe
<6>[ 4.751094]
<6>[ 4.751098] mmc_attach_sd..1218.. ===== Begin to identify card as SD-card. [mmc0]
<3>[ 4.757661] ES8323 0-0010: Failed to add route Left DAC->Left Mixer
<3>[ 4.757708] ES8323 0-0010: ES8323.0-0010: Failed to add 3D Mode: -16
<3>[ 4.757805] ES8323 0-0010: Failed to add route Left DAC->Left Mixer
<6>[ 4.757821] Enter::rk29_es8323_init----138
<6>[ 4.757833] Enter::es8323_set_dai_sysclk----668
<3>[ 4.767002] ES8323 0-0010: asoc: failed to add kcontrol Left Line Mux
<3>[ 4.767030] ES8323 0-0010: asoc: failed to add kcontrol Right PGA Mux
<3>[ 4.767056] ES8323 0-0010: asoc: failed to add kcontrol Left PGA Mux
<3>[ 4.767079] ES8323 0-0010: asoc: failed to add kcontrol Right ADC Mux
<3>[ 4.767102] ES8323 0-0010: asoc: failed to add kcontrol Left ADC Mux
<3>[ 4.767126] ES8323 0-0010: asoc: failed to add kcontrol Differential Mux
<4>[ 4.767178] ES8323 0-0010: ASoC: Failed to create POST debugfs file
<4>[ 4.767197] ES8323 0-0010: ASoC: Failed to create PRE debugfs file
<4>[ 4.767214] ES8323 0-0010: ASoC: Failed to create RINPUT2 debugfs file
<4>[ 4.767229] ES8323 0-0010: ASoC: Failed to create RINPUT1 debugfs file
<4>[ 4.767245] ES8323 0-0010: ASoC: Failed to create LINPUT2 debugfs file
<4>[ 4.767261] ES8323 0-0010: ASoC: Failed to create LINPUT1 debugfs file
<4>[ 4.767276] ES8323 0-0010: ASoC: Failed to create VREF debugfs file
<4>[ 4.767292] ES8323 0-0010: ASoC: Failed to create ROUT2 debugfs file
<4>[ 4.767307] ES8323 0-0010: ASoC: Failed to create LOUT2 debugfs file
<4>[ 4.767323] ES8323 0-0010: ASoC: Failed to create ROUT1 debugfs file
<4>[ 4.767338] ES8323 0-0010: ASoC: Failed to create LOUT1 debugfs file
<4>[ 4.767354] ES8323 0-0010: ASoC: Failed to create Left Out 1 debugfs file
<4>[ 4.767370] ES8323 0-0010: ASoC: Failed to create Right Out 1 debugfs file
<4>[ 4.767387] ES8323 0-0010: ASoC: Failed to create Left Out 2 debugfs file
<4>[ 4.767403] ES8323 0-0010: ASoC: Failed to create Right Out 2 debugfs file
<4>[ 4.767420] ES8323 0-0010: ASoC: Failed to create Right Mixer debugfs file
<4>[ 4.767437] ES8323 0-0010: ASoC: Failed to create Left Mixer debugfs file
<4>[ 4.767453] ES8323 0-0010: ASoC: Failed to create Left ADC debugfs file
<4>[ 4.767469] ES8323 0-0010: ASoC: Failed to create Right ADC debugfs file
<4>[ 4.767487] ES8323 0-0010: ASoC: Failed to create Right Line Mux debugfs file
<3>[ 4.767507] ES8323 0-0010: asoc: failed to add kcontrol Left Line Mux
<4>[ 4.767524] ES8323 0-0010: ASoC: Failed to create Left Line Mux debugfs file
<3>[ 4.767543] ES8323 0-0010: asoc: failed to add kcontrol Right PGA Mux
<4>[ 4.767560] ES8323 0-0010: ASoC: Failed to create Right PGA Mux debugfs file
<3>[ 4.767578] ES8323 0-0010: asoc: failed to add kcontrol Left PGA Mux
<4>[ 4.767595] ES8323 0-0010: ASoC: Failed to create Left PGA Mux debugfs file
<3>[ 4.767613] ES8323 0-0010: asoc: failed to add kcontrol Right ADC Mux
<4>[ 4.767629] ES8323 0-0010: ASoC: Failed to create Right ADC Mux debugfs file
<3>[ 4.767648] ES8323 0-0010: asoc: failed to add kcontrol Left ADC Mux
<4>[ 4.767664] ES8323 0-0010: ASoC: Failed to create Left ADC Mux debugfs file
<3>[ 4.767683] ES8323 0-0010: asoc: failed to add kcontrol Differential Mux
<4>[ 4.767700] ES8323 0-0010: ASoC: Failed to create Differential Mux debugfs file
<4>[ 4.767717] ES8323 0-0010: ASoC: Failed to create Mic Bias debugfs file
<6>[ 4.767829] Enter::es8323_set_bias_level----929 level =1
<6>[ 4.769588] Enter::es8323_set_bias_level----929 level =2
<6>[ 4.772469] Enter::es8323_set_bias_level----929 level =3
<6>[ 4.772557] asoc: ES8323 HiFi <-> rk29_i2s.0 mapping ok
<6>[ 4.773027] ALSA device list:
<6>[ 4.773039] #0: RK29_ES8323
<6>[ 4.773144] GACT probability NOT on
<6>[ 4.773159] Mirror/redirect action on
<6>[ 4.773170] u32 classifier
<6>[ 4.773177] Actions configured
<6>[ 4.773188] Netfilter messages via NETLINK v0.30.
<6>[ 4.773244] nf_conntrack version 0.5.0 (14399 buckets, 57596 max)
<6>[ 4.773738] ctnetlink v0.93: registering with nfnetlink.
<6>[ 4.773784] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 4.773798] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 4.774051] xt_time: kernel timezone is -0000
<6>[ 4.774217] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 4.774402] arp_tables: (C) 2002 David S. Miller
<6>[ 4.774583] TCP cubic registered
<6>[ 4.775165] NET: Registered protocol family 10
<6>[ 4.775970] Mobile IPv6
<6>[ 4.776012] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 4.776160] IPv6 over IPv4 tunneling driver
<6>[ 4.777191] NET: Registered protocol family 17
<6>[ 4.777233] NET: Registered protocol family 15
<5>[ 4.777362] Bridge firewalling registered
<6>[ 4.779331] rk29_sdmmc_change_clk_div..1928.. newDiv=0, newCLK=49500Khz [sd_mmc]
<6>[ 4.779449] mmc0: new high speed SDHC card at address b368
<6>[ 4.779773] Bluetooth: RFCOMM TTY layer initialized
<6>[ 4.779795] Bluetooth: RFCOMM socket layer initialized
<6>[ 4.779807] Bluetooth: RFCOMM ver 1.11
<6>[ 4.779819] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 4.779831] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 4.779981] NET: Registered protocol family 35
<6>[ 4.780261] [BT_RFKILL]: Enter rfkill_rk_init
<6>[ 4.780369] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 4.780396] [BT_RFKILL]: ** disable irq
<6>[ 4.780591] mmcblk0: mmc0:b368 NCard 7.40 GiB
<6>[ 4.781886]
<6>[ 4.781890] msdos_partition..461... ==== Begin to parse sdcard-partition. [mmc0]
<6>[ 4.781908] msdos_partition..530... ==== The sdcard has MBR. [mmc0]
<6>[ 4.781923] msdos_partition..543... ==== partition-1, size=7760896KB [mmc0]
<6>[ 4.781938] msdos_partition..571... ==== main partition-1....[mmc0]
<6>[ 4.781951] mmcblk0: p1
<6>[ 4.782370] mmc_rescan_try_freq..1721.. ===== Initialize SD-card successfully. [mmc0]
<6>[ 4.782396]
<6>[ 4.782399] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc1]
<6>[ 4.806820] [BT_RFKILL]: bt shut off power
<6>[ 4.836600] [BT_RFKILL]: bt_default device registered.
<6>[ 4.836844] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<6>[ 4.837495] i2c i2c-0: sensor_probe: ak8975,0xf00a7a00
<4>[ 4.837649] rk30-camera version: v0.2.28 Zoom by ipp
<3>[ 4.837799] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
<3>[ 4.838078] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
<3>[ 4.838349] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
<3>[ 4.838625] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
<3>[ 4.838897] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
<3>[ 4.839169] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
<3>[ 4.839441] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
<3>[ 4.839720] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
<4>[ 4.839907] get cif ldo failed!
<3>[ 4.840023] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
<4>[ 4.840042] sensor_chip_init:fail to read ak8975 devid:0xff
<3>[ 4.840057] i2c i2c-0: sensor_probe failed -11
<4>[ 4.840076] sensors: probe of 0-000d failed with error -11
<6>[ 4.840107] i2c i2c-0: sensor_probe: l3g4200d_gryo,0xf00a7c00
<3>[ 4.842697] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 2...
<3>[ 4.842985] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 1...
<3>[ 4.843264] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 0...
<3>[ 4.843543] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 2...
<3>[ 4.843818] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 1...
<3>[ 4.844093] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 0...
<3>[ 4.844369] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 2...
<3>[ 4.844644] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 1...
<3>[ 4.844916] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 0...
<4>[ 4.844934] sensor_chip_init:fail to read l3g4200d_gryo devid:0xff
<3>[ 4.844949] i2c i2c-0: sensor_probe failed -11
<4>[ 4.844968] sensors: probe of 0-0069 failed with error -11
<6>[ 4.844997] i2c i2c-0: sensor_probe: gs_mxc6225,0xf00a7e00
<4>[ 4.845025] sensor_chip_init:gs_mxc6225:devid=0x0,ops=0xc0a8e1f0
<6>[ 4.846097] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-0015/input/input2
<4>[ 4.846242] sensor_irq_init:use polling,delay=30 ms
<4>[ 4.846386] sensor_misc_device_register:miscdevice: mma8452_daemon
<4>[ 4.846402] sensor_probe:initialized ok,sensor name:mxc6225,type:1,id=16
<4>[ 4.846408]
<6>[ 4.846444] i2c i2c-2: sensor_probe: light_cm3217,0xf01be600
<4>[ 4.846460] sensor_chip_init:light_cm3217:devid=0x0,ops=0xc0a8e430
<3>[ 4.846642] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 2...
<3>[ 4.846816] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 1...
<3>[ 4.846984] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 0...
<3>[ 4.847152] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 2...
<3>[ 4.847318] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 1...
<3>[ 4.847483] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 0...
<4>[ 4.847499] sensor_active:fail to active sensor
<4>[ 4.847510] sensor_init:line=97,error
<4>[ 4.847519] sensor_initial:fail to init sensor
<4>[ 4.847529] sensor_chip_init:fail to init sensor
<3>[ 4.847541] i2c i2c-2: sensor_probe failed -11
<4>[ 4.847558] sensors: probe of 2-0010 failed with error -11
<6>[ 4.847610] sensor_init: Probe name sensors
<3>[ 4.847624] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
<6>[ 4.847897] Freeing init memory: 532K
<3>[ 4.862918] init: /init.rk30board.rc: 91: invalid command 'mknod'
<3>[ 4.863016] init: /init.rk30board.rc: 126: invalid service name 'mt6620_supplicant'
<4>[ 4.863861] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<6>[ 4.928007] keychord: using input dev rk29-keypad for fevent
<3>[ 4.928234] init: cannot open '/initlogo.rle'
<4>[ 4.947233] get cif ldo failed!
<4>[ 4.947248] Probe gc2035_back success
<4>[ 4.947375] get cif ldo failed!
<4>[ 5.020185] gp_rknand_info = : 0xf02b1000
<4>[ 5.020277] rk30_chip_set:0
<4>[ 5.020359] request IRQ_NANDC irq , ret=0.........
<4>[ 5.020387] FTL INFO:Version = 438,Date = 20130620
<4>[ 5.020459] FlashCopyProgBuf1=0xc13d0000
<4>[ 5.020489] ATime: 40 ns AHB: 148 timming: 1081
<4>[ 5.020507] No.1 FLASH INFO:2c 44 44 4b a9
<4>[ 5.020872] ATime: 32 ns AHB: 148 timming: 1061
<4>[ 5.021053] ATime: 32 ns AHB: 148 timming: 1061
<4>[ 5.021066] randomizer = 2 , EccBits = 28 pSpec->pReadRetrial = bf009708
<4>[ 5.054950] get cif ldo failed!
<4>[ 5.054963] Probe gc0308_front success
<4>[ 5.082747] totalLogicBlkRaw = 1897
<4>[ 5.082770] gBootMedia = 1 gSdmmcFwPartOffset =0!
<4>[ 5.082782] rknand_buffer.c version: 4.38 20121130!
<5>[ 5.087176] 10 cmdlinepart partitions found on MTD device rk29xxnand
<5>[ 5.087193] Creating 10 MTD partitions on "rk29xxnand":
<5>[ 5.087210] 0x000000400000-0x000000800000 : "misc"
<5>[ 5.088284] 0x000000800000-0x000001000000 : "kernel"
<5>[ 5.089072] 0x000001000000-0x000002000000 : "boot"
<5>[ 5.089752] 0x000002000000-0x000004000000 : "recovery"
<5>[ 5.090466] 0x000004000000-0x000008000000 : "backup"
<5>[ 5.091215] 0x000008000000-0x000010000000 : "cache"
<5>[ 5.092032] 0x000010000000-0x000050000000 : "userdata"
<5>[ 5.093836] 0x000050000000-0x000050400000 : "kpanic"
<6>[ 5.095276] apanic: Bound to mtd partition 'kpanic'
<6>[ 5.095290] apanic: No panic data available
<5>[ 5.095312] 0x000050400000-0x000082400000 : "system"
<5>[ 5.097001] 0x000082400000-0x0000ed200000 : "user"
<4>[ 5.099583] startBlk = 80 sysProtAddr = 79
<6>[ 5.196238] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<6>[ 5.438596] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<6>[ 5.582263] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<4>[ 5.588042] UMP: Using OS memory backend, allocation limit: 536870912
<4>[ 5.588064] UMP: UMP device driver loaded
<4>[ 5.623372] Mali: init_mali_clock mali_clock c0a5f900
<4>[ 5.638950] Mali: @@@@@@@Mali device driver loaded success@@@@@@@@
<4>[ 5.639758] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
<4>[ 5.643932] ipp irq 47
<4>[ 5.644762] IPP init, version rk30-ipp 1.003
<4>[ 5.670171] mirroring: Unknown symbol video_data_to_mirroring (err 0)
<4>[ 5.670233] mirroring: Unknown symbol audio_data_to_mirroring (err 0)
<3>[ 5.892652] init: skipping insecure file '/data/local.prop'
<3>[ 6.040235] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
<3>[ 6.051610] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<3>[ 6.062798] init: cannot find '/system/bin/hald', disabling 'hald'
<4>[ 6.102956] vpu: power on
<6>[ 6.105653] VPU_SERVICE: checking hw id 4831
<4>[ 6.110654] vpu: power off...done
<6>[ 6.114009] VPU_SERVICE: init success
<3>[ 6.154931] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
<3>[ 6.162994] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
<3>[ 6.173234] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
<6>[ 6.215694] .409.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
<6>[ 6.215721] .440.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
<6>[ 6.308052] .409.. MMC0 receive the message sd-Pending from VOLD.[sd_mmc]
<6>[ 6.310821] .409.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
<4>[ 6.311330] [rknand_sys_storage_ioctl:90] rknand_sys_storage_ioctl in
<4>[ 6.311347] [rknand_sys_storage_ioctl:103] RKNAND_GET_DRM_KEY
<4>[ 6.311362] [rknand_sys_storage_ioctl:365] return ret = 0
<3>[ 6.311893] android_usb: already disabled
<6>[ 6.325727] adb_open
<3>[ 8.189655] gc2035 sensor_ioctl cmd(0x3) is unknown !
<3>[ 8.296864] gc0308 sensor_ioctl cmd(0x3) is unknown !
<4>[ 8.845225] rk fb use 3 buffers
<6>[ 19.304980] DWC_OTG: ********vbus detect*********************************************
<6>[ 19.508432] DWC_OTG: ********soft connect!!!*****************************************
<6>[ 19.514435] DWC_OTG: USB SUSPEND
<6>[ 19.610207] DWC_OTG: USB RESET
<6>[ 19.722420] android_work: sent uevent USB_STATE=CONNECTED
<6>[ 19.725849] DWC_OTG: USB RESET
<6>[ 19.770708] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<6>[ 19.789466] alarm_set_rtc: no RTC, time will be lost on reboot
<6>[ 19.851344] android_usb gadget: high speed config #1: android
<6>[ 19.851553] android_work: sent uevent USB_STATE=CONFIGURED
<4>[ 20.986377] rk30_adc_battery_poweron_capacity_check........new_capacity=30,old_capacity=16
<4>[ 20.986404] rk30_adc_battery_poweron_capacity_check...bat ->bat_capacity=16,new_capacity=30,old_capacity=16
<4>[ 33.490421] =======================================================
<4>[ 33.496763] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 33.504244] =======================================================
<6>[ 33.510184] acc_open
<6>[ 33.510208] acc_release
<4>[ 33.510695] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 1.12) init.
<4>[ 33.522799] wifi_usb_init
<4>[ 33.525500] wifi_activate_usb
<6>[ 33.934438] usbcore: registered new interface driver rtl8188eu
<4>[ 34.846224] cfg80211_rtw_change_iface, old_iftype=6, new_iftype=2
<6>[ 34.847300] ADDRCONF(NETDEV_UP): wlan0: link is not ready
<4>[ 36.294939] bssid=ce:06:13:cb:eb:14
<4>[ 36.294959] matched by bssid
<4>[ 36.295436] rtw_cfg80211_set_wpa_version, wpa_version=1
<4>[ 36.295454] got wpa_ie
<6>[ 36.393509] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
<6>[ 40.970833] .409.. MMC0 receive the message sd-Checking from VOLD.[sd_mmc]
<6>[ 40.989720] .409.. MMC0 receive the message sd-Mounted from VOLD.[sd_mmc]
<3>[ 41.028905] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
<6>[ 44.473253] alarm_set_rtc: no RTC, time will be lost on reboot
<3>[ 73.296942] init: untracked pid 1495 exited
<6>[ 124.382944] Enter::es8323_pcm_startup----805 es8323->sysclk=11289600
<6>[ 124.383046] Enter::rk29_hw_params----47
<6>[ 124.383061] es8323_set_dai_fmt----703, fmt[3000]
<6>[ 124.383071] es8323 in slave mode
<6>[ 124.384192] Enter:rk29_hw_params, 99, rate=44100
<6>[ 124.384211] Enter:rk29_hw_params, 107, LRCK=64
<4>[ 124.410163] fun:es8328_dapm_pre_event, event:1
<6>[ 124.410200] Enter::es8323_set_bias_level----929 level =2
<4>[ 124.422000] fun:es8328_dapm_pre_event, event:1
<6>[ 124.422023] Enter::es8323_set_bias_level----929 level =2
<4>[ 124.423929] fun:es8328_dapm_post_event, event:2
<4>[ 124.423946] fun:es8328_dapm_post_event, event:2
<6>[ 124.441070] Enter::es8323_set_bias_level----929 level =3
<4>[ 124.446543] Enter::es8323_mute----888--mute=0
<4>[ 128.263811] Enter::es8323_mute----888--mute=1
<4>[ 133.315434] fun:es8328_dapm_pre_event, event:4
<4>[ 133.315455] fun:es8328_dapm_pre_event, event:4
<4>[ 133.315467] fun:es8328_dapm_post_event, event:8
<6>[ 133.315481] Enter::es8323_set_bias_level----929 level =1
<4>[ 133.318559] fun:es8328_dapm_post_event, event:8
<6>[ 133.318574] Enter::es8323_set_bias_level----929 level =1
<3>[ 182.858393] init: untracked pid 1485 exited
<3>[ 187.694941] init: untracked pid 1854 exited
<3>[ 193.742567] init: untracked pid 1427 exited
<6>[ 234.724866] input input0: adkey[vol+]: report ev[115] state[1]
<6>[ 234.814872] input input0: adkey[vol+]: report ev[115] state[0]
2014/05/23
the RKFlashKit log:
============= 2014-11-09 10:00:14 ============
Loading partition information
MACHINE_MODEL:rk30sdk MACHINE_ID:007 MANUFACTURER:RK30SDK MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 3066 CHECK_MASK: 0x80 KERNEL_IMG: 0x60408000 #RECOVER_KEY: 1,1,0,20,0 CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00200000@0x00080000(userdata),0x00002000@0x00280000(kpanic),0x00190000@0x00282000(system),-@0x00412000(user)
============= 2014-11-09 10:03:01 ============
Writing file /media/samuel/1A86-DFE7/recovery de test/recovery.img to partition 0x00010000@0x00010000
writing flash memory at offset 0x00010000
writing flash memory at offset 0x00011000
writing flash memory at offset 0x00012000
writing flash memory at offset 0x00013000
writing flash memory at offset 0x00014000
Done!
Comparing partition 0x00010000@0x00010000 with file /media/samuel/1A86-DFE7/recovery de test/recovery.img
reading flash memory at offset 0x00010000
reading flash memory at offset 0x00011000
reading flash memory at offset 0x00012000
reading flash memory at offset 0x00013000
reading flash memory at offset 0x00014000
Done!
pffffff !!!
don't work again ;-( pipo smart S1 cwm unpacked and repacked with mkbootimg (my recovery.img-kernel.gz + recovery.img-ramdisk.cpio.gz) ....
realy lost
2014/05/23
ok ....
nobody to helping me
I stay in the topic .... if my research can help other people ..
so my tab is an " KidsPad 3 "
this cwm work like it is : http://www.filefactory.com/file/605l7c1mh11n/n/Pipo_S1_CWM_by_Danyrolux_rar
but no way to do a nandroid backup "it look like don't find the good partition".
if I want to repack it with my original recovery.img, I have to keep the original kernel (from original recovery.img) and the ramdisk from this cwm ..? right ?
2014/05/23
the original recovery.img unpack :
samuel@USB-UBUNTU:/media/samuel/1A86-DFE7/mytools$ sudo perl unpack-bootimg.pl recovery.img
[sudo] password for samuel:
kernel written to recovery.img-kernel.gz
ramdisk written to recovery.img-ramdisk.cpio.gz
cpio: ../init: impossible de créer un lien symbolique vers "sbin/ueventd": Opération non permise
gzip: ../recovery.img-ramdisk.cpio.gz: decompression OK, trailing garbage ignored
29922 blocs
extracted ramdisk contents to directory recovery.img-ramdisk/
2014/05/23
the cwm pipo smart s1 recovery.img unpack :
root@USB-UBUNTU:/media/samuel/1A86-DFE7/mytools# perl unpack-bootimg.pl recovery.img
5942 blocs
2014/05/23
the repack :
root@USB-UBUNTU:~/Bureau/mytools# perl repack-bootimg.pl recovery.img-kernel.gz recovery.img-ramdisk/ reovery.img
5942 blocs
repacked boot image written at recovery.img-ramdisk/-repack.img
after reboot in recovery mode ... the recovery is stil the original recovery ??? I don't understand.
repacked the original recovery + the cwm ramdisk .
68 Guest(s)
Devices in use: Desktop (63), Phone (5)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
