Long story short: I flashed the afore mentioned ROM and everything was fine (great ROM!). Then I mistakenly flashed kernel, uboot, and resources images from the Chuwi V17 HD and everything went to hell. Somehow I managed to flash back Kempler&Strauss' kernel and resources images but not uboot.img. Right now I am on a bootloop: Android loads and immediately shuts down because it can't detect battery charge, this gives some brief use of adb, but I can't manage to boot into recovery thru ADB nor keys combination.
Rockchip RK3168 Model:HDX053 Baseband: Unknown Imei: Null Wifi Can't swith on.whenever there is a power problem and I repair the android device. if i check the baseband it will indicate unknown...
Hola a todos espero son well'm nuevo en el foro y tenĂa la esperanza de que alguien me podrĂa ayudar con el firmware de mi tablet porque no arrancĂł permaneciĂł en modo de recuperaciĂłn y luego instale un firmware y no funcionaba y la pantalla quedĂł en blanco .
premium PT350 Rockchip RK3026 PENSIONES ID: c86 / 131113 / V02
LCD de 7 "Jellybean Android almacenamiento 4.2 RK3026 Dual Core de 1 GB de RAM DDR3 de 8 GB, soporte de la cámara delantera y trasera micro usb 3g dongle whit ranura micro sd, cd 5v wifi b / g / n
________
rk3026
scak38913 1.405
wifi
Realtek
rtl8188etv
placa C86 S (CPT)
xt140210
xt20140213030
C86 / 131113 / V02 si alguien me puede ayudar le agradecerĂa Muchas gracias.
