2014/06/26
First at all, thanks for your great job.
My chinese tablet : Yuandao N12 FAST TAB (http://gadgetsshop.ecrater.com/p/12916323/window-n12-fast-tab-capacitive-7#)
Stock rom was 2.3.1, i've made a backup of the kernel, then downloaded the N12-2.3-20111104-ZZ-SDK2.1 rom (only one that is working).
I managed to try your roms.
I tried :
- Oma_Odys_Loox_JB_4.1.1_v1.2.1a
- Oma_Odys_Loox_JB_4.1.1_v1.2.2a
- CrewRKTablets_RK29_Loox_CM10.1_4.2.2_v1.2.4
I could boot but always with the same symptoms :
- With kernel_308_n12_yuandao -> touch screen problems, in landscape up and down inverted (right/left inverted in portrait) and touch point shifted about 1 cm and shaking.
- kernel_308_n12_jb_yuandao -> same thing.
- kernel_308_n50_yuandao -> no touch screen inversion but always shifted and shaking...
- With both kernels, screen rotations are completely inverted. I tried all sensors fixes but no one works. (CrewRKTablets_CM10.1_sensor__x=-y_y=-x_z=z.zip etc...)
        I've followed instructions with androsensor:
       - tab vertical, landscape (y=9.8) -> i have z=-9.8
       - turn left to portrait (x=9.8) -> ok
       - turn right to portrait (x=-9.8) -> ok
       - tab horizontal, screen up (z=9.8) -> i have y=-9.8
- Battery indicator works but seems a little crazy. (for exemple it go down quickly to 20%, i reboot then it indicate 40%.)
Well, i hope you could help me, because i enjoy CM 10 and doesn't want to return to gingerbread
Let me know if you need more informations (dmesg from 2.3? 2.3 stock kernel?...), i need your help.
Best Regards
Yandao N12 FAST TAB
Yuandao did not release an ICS firmware for the tab. Consequently there is no 3.0.8+ kernel.
Screen and touch controller driver is in the kernel.
Maybe you will find a working kernel here: http://forum.xda-developers.com/showpost.php?p=29649602&postcount=4
To change the kernel just tick paramter and kernel.
2014/06/26
Ok, i will try some of them...
Otherwise, i've just found this thread : http://forum.xda-developers.com/showthread.php?t=1800428
Any chance to apply to my tab ? (2.3.1 to 2.3.7 could be a solution).
Thanks for your answers.
Yandao N12 FAST TAB
Currently Online: Nazarevich
76 Guest(s)
Devices in use: Desktop (68), Phone (9)
jumbo65
kalkpits
m12k
StatusQ
helloyuen
melcis
