What tab is it? Did the manufacturer publish kernel sources? Do you have a defconfig?
If the kernel was compiled with /proc/config.gz support turned on, then you will find it the build. Other way is to look at the source tree that was used to compile the kernel.
73 Guest(s)
Devices in use: Desktop (65), Phone (8)
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
