need firmware for this tablet pc rk3026
TJderek
Forum Posts: 13
46
2014/08/25 - 16:06
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2063
I've tried. When start tablet, the screen saver "Oma" is rotated by 90 degrees to the left! after launch, horizontally displayed correctly, but if you rotate the tablet to the left or to the right, the screen is turned in the opposite direction (180 degrees)
..and what to do with the camera ???
47
2014/08/25 - 16:25
Well, it is a strange kernel ... reactions on your tab are different from what I can see here in the Jeka firmware.
For the cam we need the Hal from the stock firmware, so no way.
Orientation is maybe right in landscape with this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2064
If there is still a rotation problem use this as a workaroud: http://crewrktablets.arctablet.com/?wpfb_dl=1369
TJderek
Forum Posts: 13
48
2014/08/25 - 16:51
..nothing helped fix Cry ..and now saver "Oma" inverted (180 degrees) (((
TJderek
Forum Posts: 13
49
2014/08/25 - 17:09
by the way in recovery menu keys "vol +" and "vol -" inverted! ..Why?
50
2014/08/25 - 17:12
Just because the strange kernel "see" it in that way.
TJderek
Forum Posts: 13
51
2014/08/25 - 17:55
..so what should I do, how to fix these problems? ..or simply throw out the tablet? .. pity .. he is is not bad and fastest (((
52
2014/08/25 - 18:09
For most of the guys having no fallback before flashing anything into the tab it will end this way.
From this point of view you have luck to find a kernel which gives you screen, touch and wifi. Use the rotate-app to fix the screen and use the tab as is.
TJderek
Forum Posts: 13
53
2014/08/25 - 19:42
I so understand, the whole problem in the kernel? ..it is somehow possible to fix it?
54
2014/08/25 - 20:19
No, therefore one would need kernel sources.
TJderek
Forum Posts: 13
55
2014/08/25 - 20:57
ok .. thank you very much for your help! I will search further.. can all still find the correct kernel)) ... can you tell me, where I can see the firmware with the appropriate characteristics?
http://vericoglobal.com/unigb/overView.aspx?ID=387
Rockchip RK3026
Screen resolution - 800x480
Graphics - Mali-400MP2
RAM - 512 MB
ROM - 4 GB
Wi-Fi Atheros
board B52_V3.5 (think it is necessary to look specifically for this board)
56
2014/08/25 - 21:05
You will not see nor find hardware like screen, touch controller, pmu ... and most likely hardware changed from batch to batch  ... so you will need to know the serial-number to identify what the tab really is.
However, when you have the company data ask them for a download link of the firmware.
TJderek
TJderek
Forum Posts: 13
57
2014/08/25 - 21:49
OK... Thanks again Oma
TJderek
Forum Posts: 13
58
2014/08/29 - 14:56
Hello Oma! I managed to install your firmware from the "Cube U25GT2-H JB v1.0"
.. and this kernel for 1024x600 resolution! ..but I need at 800x480!
it can be fixed or not?
..and still not the correct orientation of the screen (the same as for other kernels)
But I think that this kernel works better))
157 Guest(s)
2 Guest(s)
Devices in use: Desktop (148), Phone (8), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
