2013/03/13
the Kernel I used is RK3026_kernel_3036_rc734h_3q and it got the audio working and every time I pull in or out de micro sd card it makes he notification sound from JB, but no luck having image, not even a light with a black screen, screen is simply off. I hope someone could help. my tablet is a iBSOL DUO I found a similar tablet but with a diferent ending serial number, I try to dump the kernel but wont work on my tablet.
the model is IBT0700A
FCC ID: XJN-PR0752X
I've got an IBT0700 original firmware but wont work on my IBT0700A. help please!
Where to find the IBT0700 original firmware?
What was on the tab: Jelly Bean or KitKat?
2013/03/13
Where to find the IBT0700 original firmware?What was on the tab: Jelly Bean or KitKat?
the original Firmware IBT0700 I got it from iBSOL support. then told them that the firmware they send me was for RK29 and I need it a rk3026 Firmware, but got no response from them anymore.
the tablet had Kitkat 4.2.2 but I think it was a Jelly bean trying to look like Kitkat.
I've got on my hands another iBSOL tablet IBT0700C and dumped the system image, recovery, boot, kernel and backup. but non of these worked on my tablet, so the problem I think is I don't have the correct Kernel. and I've tried all the Kernels that Y found on a previous post of rk3026 firmware but no luck, the most i can get is audio but no screen.
I try contacting iBSOL support again but no answer, maybe they don't have much control over serials and firmware. Help me please! I'm desperate
No further idea ... never seen that PCB. Sorry.
Keep on pushing iBSOL!
laes280285Per aspera ad astra, we rock the Tablets !
2015/01/12
laes280285 said
the Kernel I used is RK3026_kernel_3036_rc734h_3q and it got the audio working and every time I pull in or out de micro sd card it makes he notification sound from JB, but no luck having image, not even a light with a black screen, screen is simply off. I hope someone could help. my tablet is a iBSOL DUO I found a similar tablet but with a diferent ending serial number, I try to dump the kernel but wont work on my tablet.the model is IBT0700A
FCC ID: XJN-PR0752X
says if you served
55 Guest(s)
Devices in use: Desktop (49), Phone (6)
Dante1975
adb
amanita12
mony18
spiik
nikitamaan
